jfrjr(at)adelphia.net Guest
Posted: Sat Mar 11, 2006 12:46 pm Post subject: AOA wing skin location |
Group: I have both the Duckworks HID Wing Landing Light as well as an AOA. The directions have both units in the outboard wing bay. There is plenty of room but the AOA location directions would put the superior skin pressure unit behind the landing light. I am concerned that the air pressures at that location will be altered because of the slight change in wing contour secondary to the light. Should I be concerned? Maybe move the two units a few more inches inboard? I think I remember than Randy D.has the same setup but I can't find any info. on his site. Thanks, Jay Rowe #40301.
RobHickman(at)aol.com Guest
Posted: Sat Mar 11, 2006 1:25 pm Post subject: AOA wing skin location |
If you move the ports you will need to calibrate the system.
You should not have a problem having the ports behind the lights. The calibration data that we use is from a plane with the lights in front of the ports.
Anyone going to Sun-N-Fun needs to stop by Booth D-92 and see our new RV-10 Panel.....
Rob Hickman
Advanced Flight Systems
(503) 263-0037
rvbuilder(at)sausen.net Guest
Posted: Sat Mar 11, 2006 1:36 pm Post subject: AOA wing skin location |
This has been discussed a couple of times before, please check the archives.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jay Rowe
Sent: Saturday, March 11, 2006 2:43 PM
Subject: AOA wing skin location
Posted: Sun Mar 12, 2006 11:03 am Post subject: AOA wing skin location |
Thanks Rob: I'll be putting the pressure ports in the recommended locations today. One more question (and remember you are dealing with a first time builder): Is there any particular location that the access hole for the water drain probe should go? Maybe right directly below the drain? I will see you at Sun and Fun toward the end of the week. Thanks again. Jay
