Deems Davis
Posted: Sat Mar 11, 2006 3:33 pm Post subject: Engine questions - Feedback Please |
I had my 1st visit from my EAA Tech Councilor who is a long time A&P
IA, he made some compelling points about anything other than a factory
engine. His point is that engine parts have 'limits' set by the FAA, if
they are within limits the part can be reused. And at most engine
rebuilders facilities it goes into a 'bin/shelf/storage area' for future
use in an engine rebuild. Say for instance a crankshaft can be .003
undersize (just an example I have no idea what the allowable limits
really are)and still be OK, so the engine builder puts it in the 'good
parts' bin where it gets used to build your engine. But say shortly
after installing your 'new' engine the crank wears to .004, then you are
actually blissfully flying around with a crank that is not within
service limits. I'm assuming this is true, if not could someone please
set me straight. I was close to making up my mind about an
engine/supplier/source. But this has caused me to _seriously_ reconsider
anything other than a factory engine. My TC says that as an A&P he
receives correspondence from the FAA about engine shops that have been
found to use parts that are not within limits, his comment was 'even
some of the larger ones have had some instances'. I find all of this
unsetteling. Any feedback?
Additionally, In my Prior aircraft, I always flew with 'Factory Remans'
Are factory remans subject to the same 'limits' issue as in the above
example? Or are Factory Reman's to 'New' Limits?
Thanks for your enlightment
Deems Davis # 406
Fuse
http://deemsrv10.com/
Tim(at)MyRV10.com Guest
Posted: Sat Mar 11, 2006 4:01 pm Post subject: Engine questions - Feedback Please |
This isn't as detailed as your question, but... As far as what I found
during my search, yes, cranks can either be to new limits, or various
undersized sizes. If it's got wear, they can grind them down one size
and get a matching bearing. When I shopped from America's Aircraft
Engines, I was able to get them to get me the specs on all the
IO-540 cranks they had and choose the one I wanted. Some were new
limits, some were undersized. I think as long as it's ground well,
undersized would be fine, but of course everyone wants new if they
can, right? When I got my engine from Aerosport, the crank was
to new limits, and I don't think Bart normally will use something
that's not to new limits. Also, everything in the top end is
new, and the case is used. By the time the rebuild is done, from
one of those good places, there's very little to worry about. Of
course, it's definitely a reason to buy only from a reputable rebuilder,
which is why I chose Aerosport. America's Aircraft Engines is also
known to be good, as are some others. In the end, I actually believe
that by getting a smooth running, well built engine, you don't have
much risk over new, and in fact with Lycomings crank issues recently,
I kind of trust their old cranks more...funny as that may seem. Of
course, I wouldn't argue with a brand new engine either. Everyone
seems to comment on how smooth my engine seems. I can't be outside
to hear it run, but inside it sounds fine to me. It sure runs well.
Anyway, just find yourself a good facility before you buy.
Deems Davis wrote:
Deems Davis # 406
Fuse
LarryRosen
Posted: Sat Mar 11, 2006 4:38 pm Post subject: Engine questions - Feedback Please |
Tim,
You say:, "I can't be outside to hear it run, but inside it sounds fine
to me."
I am sure there are many on this list that would be more than happy to
solve this "problem" for you.
Larry
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Sat Mar 11, 2006 4:55 pm Post subject: Engine questions - Feedback Please |
I think you'll just have to make a trip up here then so I can
take you for a ride, and after we're done you can hold the brakes
while I jump out and listen.
Larry Rosen wrote:
Tim,
to me."
Larry
jhasbrouck(at)woh.rr.com Guest
Posted: Sat Mar 11, 2006 5:13 pm Post subject: Engine questions - Feedback Please |
Deems,
Overhauls come in a couple of different flavors. Most of us want an
overhaul to "new limits" and that makes sense. An overhaul to "service
limits" can, as you say, be on the ragged edge and go over it during use.
Factory overhauls can be to either new or service limits but most nowadays
are to new limits. Factory "remans" are a zero timed engine with a new log
book. Only the factory can do a "reman". Any others ( than remans )
continue the time on the engine logs, ie: TT3500 with TSMOH1500. With
competition in the after market, new cylinder assemblys have gotten pretty
reasonable and it's hard to justify reworking old jugs. Cams are the same
way. So, in reality, when you are buying a used engine (core) what you want
is a good case and crank since you'll probably replace the rest with new
anyway. Lots of 540's out there with prop strikes. Lycoming requires a
teardown with ANY prop strike no matter how severe. The crank in one of
these can be a crapshoot. Besides the prop flange being bent, you risk a
crack in the crank that would render it useless. Buying new from Lycoming
COULD be a good bet if they don't recall anything else!
John Hasbrouck
#40264
Kellym
Posted: Sat Mar 11, 2006 6:15 pm Post subject: Engine questions - Feedback Please |
Let me clear up a few things for you Deems. My perspective...I have
spent the last 350 hours flying behind an IO-360-A1A that I personally
overhauled, in my Mooney. Yes, I have an A&P certificate, that was
issued after 9/11. I don't know where your tech counselor got his
information, but it is not all correct. Only the factory actually puts
used parts on the shelf for future use, unless you are talking a big
repair station operation. The average shop and A&P must keep all the
reusable parts of an engine together, along with the log books, to be
able to track the time. Only the factory can do what the FAA calls a
rebuild, resulting in a zero time engine. That is by regulation. That is
what the marketing folks call a reman, which is a term not recognized by
the FAA.
Everyone else produces overhauled engines, and Lycoming does as well.
Those must have the parts kept together and the total time follows the
major pieces. That said, everything on the engine but the data plate can
be changed and still have the same engine with the same TT. Lycoming
puts out SB240 which specifies the parts that must be changed at
overhaul time if the engine is to be used for hire. It isn't mandatory
for Part 91, nor experimental. While an engine can be put together only
meeting service limits, it typically is only done to fix a broken plane,
such as a prop strike.
Anyone in their right mind, including virtually all overhaul shops will
build to new specifications and limits, because it isn't that hard, nor
does it change the overall cost much. The name shops, like BPA, Lycon,
Mattituck, etc. do more than just new limits, they use their experience
to make the engine better balanced, both in rotating mass and in flow.
The smoother the engine runs, the less likely they are to see a warranty
issue.
The problem with factory new, overhauled and reman, right now, is that
Lycoming outsources manufacture of every single part in the engine. That
is right, 15 years ago, more or less, they survived by selling every
single piece of manufacturing equipment they owned. They only do QC and
assembly on the engines. While you will get more new parts in a reman,
you are not guaranteed new production dimensions. For example, they can
use a crank turned .003 undersize. You will not get any history of any
of the parts and will have no idea whether the case or crank have 2000
hours or 10000 hours on them. Their overhauled engines, while cheaper,
also have shorter warranty, and while normally built to new limits, you
are only guaranteed service limits, if you read the fine print. You also
have no control on the TT on the engine you get. You might exchange a
2000TT core for a 6000TT 0SMOH overhaul.
I think you will fine most of the well respected engine overhaul shops
will give you better warranty, more control over your choices, and a
better running engine than the factory. JMHO.
KM
KCHD, A&P
DO NOT ARCHIVE
Deems Davis wrote:
Deems Davis # 406
Fuse
KCHD |
rvbuilder(at)sausen.net Guest
Posted: Sat Mar 11, 2006 7:03 pm Post subject: Engine questions - Feedback Please |
Couple of things I would like to add to this. At least one of the respected shops is apparently not very good at overhauling engines. I know of at least one instance of a popular northern shop sending a unairworthy overhauled engine out but they built perfectly fine "new" kit engines, which is what that person ended up with. If the shop doesn't do many overhauls, you might want to find one that does.
There has been some discussion on how Mattituck is less expensive than other well known shops such as BPE and Aerosport. Make sure you are comparing apples to apples. For instance, I believe that if you add what BPE does standard to the Mattituck price, it is more than a BPE. I'm sure Allen will chime in on this, but you get the idea.
Michael Sausen
-10 #352 Fuselage
Dick Sipp
Posted: Sat Mar 11, 2006 7:34 pm Post subject: Engine questions - Feedback Please |
Deems,
Taking what Michael S. said just a bit further. I believe with the price of
core engines what it is now it appears that the Lycoming new kit engines,
built by the approved shops cost little if any more than an overhauled used
engine.
Prices are going up substantially though, literally in a few days, so for
those on the fence this is the time to decide.
I ordered mine last week. Delivery is running 3-4 months at least according
to my shop.
Just something else to throw into the mix.
Dick Sipp
40065
LloydDR(at)wernerco.com Guest
Posted: Sat Mar 11, 2006 8:32 pm Post subject: Engine questions - Feedback Please |
Does that mean you are open to visits?
I would love to see your work, and the interior from Abby and pay for
allot of Avgas!
Dan
GRANSCOTT(at)aol.com Guest
Posted: Sun Mar 12, 2006 5:04 am Post subject: Engine questions - Feedback Please |
Deems,
I don't know if you've got a core to trade in but if you do, please keep in mind that they apparently have been returning to the exchange person with a bill up to $5k well after the over haul telling them that the case exchanged is TU and that the person must immediately pay a service core charge...and that the case has been destroyed and they have no proof of their claim but you owe them $XX immediately. The core/service charge well after the overhaul, without proof has caused a lot of discussion in the engine community, along with their cranks.
By the way this did happen to a friend of Kelly and mine in the Piper community.
If you really want the Lycoming engine and you've gotten a core to trade, before committing, I'd check out the total package of costs from Lycoming and get a full statement as to total charges current and future. In addition to all that Kelly gave you on the parts manufacturing situation, you'd hate to have a surprise on a case return charge. And you'd probably get the bill about the time when you are getting ready to crank up your first flight. Putting you in one great mood! FYI---
Patrick
Posted: Sun Mar 12, 2006 5:05 am Post subject: Engine questions - Feedback Please |
In a message dated 3/11/06 8:15:15 P.M. Eastern Standard Time, jhasbrouck(at)woh.rr.com writes:
| Quote: | Lycoming requires a
teardown with ANY prop strike no matter how severe. |
Or minor...if you hit a small bird in flight or a rock strikes your prop according to Lycoming the engine needs tearing down.
Patrick
wcurtis(at)core.com Guest
Posted: Sun Mar 12, 2006 3:29 pm Post subject: Engine questions - Feedback Please |
GRANSCOTT(at)aol.com wrote: > >I don't know if you've got a core to trade in but if you do, >please keep in mind that they apparently have been returning to >the exchange person with a bill up to $5k well after the over >haul telling them that the case exchanged is TU and that the >person must immediately pay a service core charge...and >that the case has been destroyed and they have no proof of their >claim but you owe them $XX immediately. The core/service charge >well after the overhaul, without proof has caused a lot of >discussion in the engine community, along with their cranks. > Patrick, I think your info is a little outdated. Per the memo dated 03 April 2005, at the below link, there is no longer a core charge as long as it is a "like" core, it is running, and it is the same engine. So any boat anchor will do. It only makes sense for them to get rid of the "junk" out in the field. http://www.lycoming.textron.com/corepolicy/corepolicy.pdf If the above link does not work go to the below link and click on "Open Letter to Our Customers." Or do a Google search on "Lycoming Core policy" William Curtis http://wcurtis.nerv10.com/
