DuaneFamly(at)aol.com Guest
Posted: Wed Nov 05, 2008 11:08 am Post subject: Time to Paint? |
Good day all,
I just came from my Flight Physical and since I have a real old flying doctor, we chatted over my build. When I brought up having to find someone to paint my bird or go out and learn to do it myself...and buy the equipment....he stated that he and friends that have built 6 planes over the past 10 years....from Long EZ's to RV's....that they never painted their planes until after they flew off their 40 hours of test flying! This came as a surprise to me.....how about to you folks? Pros and Cons would be a big help in the upcoming discussion.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300A
Sensenich R64Z N
Ground Adjustable Prop
AOL Search: Your one stop for directions, recipes and all other Holiday needs. [url=http://pr.atwola.com/promoclk/100000075x1212792382x1200798498/aol?redir=http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=emlcntussear00000001 ]Search Now[/url].
terrys(at)cisco.com Guest
Posted: Wed Nov 05, 2008 11:41 am Post subject: Time to Paint? |
Hi Mike,
We decided not to fly until painted for the following reasons;
1) the color must be white to keep from getting too hot. One plane we know of had light grey primer on a control surface that warped in the sun.
2) even with white primer, the primer is usually more porous than paint, and may get impregnated with engine oils, bug juice, etc, that may cause problems later on when you do paint.
just my two cents worth,
Terry Seaver
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of DuaneFamly(at)aol.com
Sent: Wednesday, November 05, 2008 11:07 AM
Subject: Time to Paint?
Good day all,
Mike Duane A207A
Redding, California
Jabiru 3300A
Sensenich R64Z N
AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now.
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
karelvranken(at)hotmail.c Guest
Posted: Wed Nov 05, 2008 11:47 am Post subject: Time to Paint? |
Mike,
If you crash in the first 40 hours then you would have saved the paint costs.
Still smiling,
Karel Vranken # 447 F-PKRL 200 hours and upholstery to be done.
craigb(at)onthenet.com.au Guest
Posted: Wed Nov 05, 2008 11:52 am Post subject: Time to Paint? |
hard to say, I thought about it, that way if u need to make any changes you wont wreck your paint job, but to know you still
haven't finished when you do your test flights would bug me I think, also what damage will you do to the structure due to UV
unless you plan on doing your 40 hours at night : )
regards
craig
[quote] --
Paul Boulet
Joined: 09 Jan 2006 Posts: 57 Location: Malibu, California
Posted: Wed Nov 05, 2008 12:05 pm Post subject: Time to Paint? |
I've been flying in primer for quite a few years. One less worry about messing up the paint when the seemingly never ending work/mods happen. Still only have 25 hours on the plane- trying to find the time and money to get back out to Phoenix to continue the rest of the hours
Paul Boulet, N914PB, Malibu, CA. 914 tri gear
--- On Wed, 11/5/08, Terry Seaver (terrys) <terrys(at)cisco.com> wrote:
Quote: | From: Terry Seaver (terrys) <terrys(at)cisco.com>
Subject: RE: Time to Paint?
Date: Wednesday, November 5, 2008, 11:40 AM
Hi Mike,
Terry Seaver
Good day all,
Mike Duane A207A
Redding, California
Jabiru 3300A
Sensenich R64Z N
| [quote][b]
acrojim(at)cfl.rr.com Guest
Posted: Thu Nov 06, 2008 5:36 am Post subject: Time to Paint? |
Mike
When we completed our monowheel, we completed painting the a/c before we had our first flight. It was still in the shop, and we were in the right frame of mind to complete the plane with a coat of paint. Once we started flying, we never had to look back.
A few years later we built a Van's RV 7A, once the a/c was ready to fly, we made the decision to fly off the 40 hours, before painting.. We ended up with almost 200 hours before we started the paint process.
What a mistake...... We had to bring the a/c back into the shop clean off the grime and gunk, then we had to take off all the fairing, cowling, wheel paints, etc (you get the picture)
We had to seal off the cockpit area, as the panel was installed, It took about a week of all these preparations before we could move the plane to the shop. Then about a week of prep work before we could start painting.
I would say we lost about six weeks before the plane was ready to fly again...
Jim and Augustene Brown
discussion.
Mike Duane A207A
Redding, California
Jabiru 3300A
Sensenich R64Z N
**************AOL Search: Your one stop for directions, recipes and all other
-aol-search/?ncid=emlcntussear00000001)
budyerly(at)msn.com Guest
Posted: Thu Nov 06, 2008 7:04 am Post subject: Time to Paint? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> After nearly eight of these, flying the plane in the raw has pro's and cons.
Pro:
If you are concerned that the flying qualities are bad and extensive exterior mods will need to be made, don't paint.
On the Tri-gear, the common mistake is to not allow the moldings to flex. Flying the gear legs unpainted can show you where you made a mistake.
Fiberglass requires clearancing for filler and paint. Your wing fillets will require the sides to be filled to get a good fit. Filler accepts dirt/grease very well.
Paint adds weight.
Jabiru cooling is a real problem, so do your homework with the other Jab owners to get your cowl right. Biggest problem is the exit area and oil cooler allowing the lower cowl to increase pressure. My opinion.
Cons:
Flight characteristics of the stab are different unless smooth and painted. Not bad, but noticeable.
A Europa which has been built square has rarely needed exterior work, and if it did, just repaint the area.
Leaks are easy to clean up and don't ruin polyurethane paint.
The Europa wing is susceptible to roughness. If you fly the wing raw with bumps, don't lift off below 55 knots or she will settle.
With the conventional gear being that far forward and short, the bounces are, well, sporty to say the least. Try 10-15 degrees of flap to aid in early control.
General:
Do your work properly during the pre-finishing phase such as:
Make sure all your electrical, fuel and plumbing is correct, tight and leak free before paint.
Test everything and calibrate your fuel system and make sure the radios and electrical do-dads all work.
If a clearance looks tight, fill and sand the area and make sure it clears with allowances for paint.
A Jabiru rarely sheds oil and grease during engine operations. Clearance your exhaust well, make sure your oil breather is operating and you won't have problems.
I have always felt that a good flying airplane is assured when the plane owner makes sure every system is perfect prior to going on to the next step. Flaps, ailerons, stab and trim systems should be tight and ready to fly. Shim your aileron QD's and adjust your linkages. Make sure your liquid systems are tight. Fill the engine with oil and turn it over, start it if you like and check the systems. Now is the time to find your wiring problems and ensure all is well. If you are going to paint before you fly, you will have the burden of making sure your work is correct.
When is the plane ready to fly...When you are ready to knock on the test pilots door and tell his wife he is dead, and there was nothing you could have done to better prepare the aircraft to prevent it.
That philosophy will give you an honest airplane. You will still have little electrical do-dad glitches and one component not talking to another, but the engine and flight systems will be sound.
Bud Yerly
Custom Flight Creations
(813) 653-4989
rampil
Posted: Thu Nov 06, 2008 9:57 am Post subject: Re: Time to Paint? |
hi all
I agree with Terry. Paint before
Bug splats make a good finish
Impossible. My trigear is a most
Efficient bug splatter.
Posted: Thu Nov 06, 2008 8:19 pm Post subject: Time to Paint? |
Well, I want to thank all those who replied.....I have decided to paint before flight but will go through all the systems before I paint, as per Bud's reply. That seems to be the most practical way to approach the final stages of this project.
Mike Duane A207A
Redding, California
Jabiru 3300A
Sensenich R64Z N
