BobbyPaulk(at)comcast.net Guest
Posted: Tue Nov 04, 2008 12:16 pm Post subject: Carburetor |
List,
my 3300 Jab idles fairly good at 800 ~ 900 Rpm when i crack the throttle off
idle at about 1050 to 1300 it will puff black smoke. at 1500 rpm it will smooth
out.
has any one changed jets or needle to fix the idle and low end mixture.
i think if i change the needle jet to a smaller size then it would run too lean
at cruise.
this would call for a change in needle configuration.
i gotta do something. any help would be appreciated.
bobby
N131BP
601 XL
crvsecretary
Joined: 18 Mar 2007 Posts: 38 Location: Naugatuck, CT
Posted: Wed Nov 05, 2008 1:03 pm Post subject: Carburetor |
Hello Bobby:
Although I am FAR from an expert on Bing CV (constant velocity) carbs, i can attempt to explain the theory of what is happening....
At idle you are running exclusively through the idle circuit. As you crack open the throttle, there are transition circuits that come into play. When you get to 1500 you are running "on the needle" that sticks through the main jet, efffectively closing off the size of the main jet fuel flow until the needle retracts....from 3/4 throttle to wide open you're on the main jet only.
Transition circuit problems are very difficult to diagnose. Sounds like you are running very rich through this circuit. I would recommend a note to Jabiru USA - Pete knows these things better than anyone. The other source of information is "The Carb Doctor"
http://www.bingcarburetor.com/
who is the official importer of Bing carbs and parts here in the USA. The manual is worth every penny. It's been a long time since I had to access this info, but every owner of an old BMW "airhead" motorcycle has had to deal with these carbs at least once !!
After some thought...check your float height. If it is set too high that would cause a rich running engine.....
Good Luck
Tracy Smith
N458XL reserved
610XL
Quote: | Quote: |
Time: 12:16:34 PM PST US
From: BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)
Subject: Carburetor
List,
out.
at cruise.
bobby
N131BP
601 XL |
[quote] [b]
_________________ Zenith 601XL N458XL (reserved)
Naugatuck, CT
Tail Complete; working on wings |
hills(at)sunflower.com Guest
Posted: Thu Nov 06, 2008 5:32 pm Post subject: Carburetor |
Bobby;
Contact Bing, they have a manual that will help you tune the carb and pick replacement jets.
Roger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of crvsecretary(at)aol.com
Sent: Wednesday, November 05, 2008 3:02 PM
Subject: Carburetor
Hello Bobby:
Good Luck
Tracy Smith
N458XL reserved
610XL
Quote: | Quote: | Time: 12:16:34 PM PST USFrom: BobbyPaulk(at)comcast.netSubject: Carburetor List,my 3300 Jab idles fairly good at 800 ~ 900 Rpm when i crack the throttle off idle at about 1050 to 1300 it will puff black smoke. at 1500 rpm it will smoothTime: 12:16:34 PM PST US | 0 Quote: | Time: 12:16:34 PM PST US | 1 Quote: | Time: 12:16:34 PM PST US | 2 Quote: | Time: 12:16:34 PM PST US | 3 Quote: | Time: 12:16:34 PM PST US | 4 Quote: | Time: 12:16:34 PM PST US | 5 Quote: | Time: 12:16:34 PM PST US | 6 Quote: | Time: 12:16:34 PM PST US | 7 Quote: | Time: 12:16:34 PM PST US | 8 Quote: | Time: 12:16:34 PM PST US | 901 |
23456789 Quote: | Subject: Carburetor | 0 Quote: | Subject: Carburetor | 1 Quote: | Subject: Carburetor | 2 Quote: | Subject: Carburetor | 3 Quote: | Subject: Carburetor | 4 Quote: | Subject: Carburetor | 5 Quote: | Subject: Carburetor | 6 Quote: | Subject: Carburetor | 7 Quote: | Subject: Carburetor | 8 Quote: | Subject: Carburetor | 9012345
