ron.mcgann(at)baesystems. Guest
Posted: Thu Nov 06, 2008 9:33 pm Post subject: Cutting & buffing |
Ok, John Cox prompted the question when talking of Deems' spectacular paint job.
How do you cut and buff without exposing rivet heads?? Most aircraft I have seen that have come out of a paint shop after some rework have too much paint removed over the rivet heads, leaving many nicely polished but unpainted..
In my paint job, I have a number of rivets where the paint has not flowed into the rivet countersink properly and look like they have 'black rings' around the rivet head. Not many, but very obvious in the White paint. What causes this and how to fix? There has really been precious little discussion in this forum about painting techniques and problems. Tim's site (as always) is a starting point, but what other sources of info are there??
Cheers,
Ron
187, almost done painting [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
AV8ORJWC
Posted: Thu Nov 06, 2008 10:02 pm Post subject: Cutting & buffing |
1500 to 2000 grit "wet" and dry. A discerning eye, a light loving touch, years of experience and the desire not to reshoot the work. After knocking about 50% to 75% of the natural clearcoat orange peel off , you read the white foam that floats off with the constant water rinse. Then, you buff it using no less than three different cuts of Mequire's compounds. One of our RV-10 dinners will feature the Mequires rep showing exactly that process. They leave Free samples.
The real secret is to lay enough clearcoat to sacrifice over the color topcoat. Oh, did I mention that clearcoat adds weight, increases gloss, protects the topcoat too.
I have had a lot better result with a poly foam pad rather than the lambs wool of my youth. My hotrod days are long gone and I have had my share of zealous over-buffing. I now know when to put down the tool and resort to elbow grease and Karate Kid moves. Compound ON/ Compound Off.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Thursday, November 06, 2008 9:32 PM
Subject: Cutting & buffing
Cheers,
Ron
187, almost done painting [quote]"Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toyour computer." [b][b][b][b]http://www.matronics.com/contribution[b][b][b][/b][/b][/b][/b][b]http://www.matronics.com/Navigator?RV10-List[b][/b][b]http://forums.matronics.com[b][b]
Posted: Thu Nov 06, 2008 10:28 pm Post subject: Cutting & buffing |
Go to sleep John!!!! WTF was that??? ;)Rick S 40185Do not archive
Sent via BlackBerry by AT&T
Date: Thu, 6 Nov 2008 22:01:38 -0800
Subject: RE: RV10-List: Cutting & buffing
1500 to 2000 grit "wet" and dry. A = discerning eye, a light loving touch, years of experience and the desire not to = reshoot the work. After knocking about 50% to 75% of the natural clearcoat = orange peel off , you read the white foam that floats off with the constant = water rinse. Then, you buff it using no less than three different cuts = of Mequire's compounds. One of our RV-10 dinners will feature the = Mequires rep showing exactly that process. They leave Free samples. =
The real secret is to lay enough clearcoat to = sacrifice over the color topcoat. Oh, did I mention that clearcoat adds = weight, increases gloss, protects the topcoat too.
I have had a lot better result with a poly foam pad = rather than the lambs wool of my youth. My hotrod days are long gone and I = have had my share of zealous over-buffing. I now know when to put down the = tool and resort to elbow grease and Karate Kid moves. Compound ON/ Compound = Off.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of =McGANN, Ron
Subject: RV10-List: Cutting & buffing
How do you cut and buff without exposing rivet heads?? Most aircraft I = have seen that have come out of a paint shop after some rework have too much = paint removed over the rivet heads, leaving many nicely polished but = unpainted..
In my paint job, I have a number of rivets where the paint has not flowed = into the rivet countersink properly and look like they have 'black rings' around = the rivet head. Not many, but very obvious in the White paint. = What causes this and how to fix? There has really been precious little = discussion in this forum about painting techniques and problems. Tim's site (as = always) is a starting point, but what other sources of info are = there??
Cheers,
Ron =
187, = almost done painting Quote: | "Warning:The information contained in this email and = any attached files isconfidential to BAE Systems Australia. If you = are not the intendedrecipient, any use, disclosure or copying of = this email or anyattachments is expressly prohibited. If = you have received this emailin error, please notify us immediately. = VIRUS: Every care has beentaken to ensure this email and its = attachments are virus free,however, any loss or damage incurred in using = this email is not thesender's responsibility. It is your = responsibility to ensure viruschecks are completed before installing any = data sent in this email toThe information contained in this email and = any attached files is | 0 Quote: | The information contained in this email and = any attached files is | 1 Quote: | The information contained in this email and = any attached files is | 2 Quote: | The information contained in this email and = any attached files is | 3 Quote: | The information contained in this email and = any attached files is | 4 Quote: | The information contained in this email and = any attached files is | 5 Quote: | The information contained in this email and = any attached files is | 6 Quote: | The information contained in this email and = any attached files is | 7 Quote: | The information contained in this email and = any attached files is | 8 Quote: | The information contained in this email and = any attached files is | 9 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 0 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 1 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 2 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 3 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 4 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 5 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 6 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 7 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 8 Quote: | confidential to BAE Systems Australia. If you = are not the intended | 9 Quote: | recipient, any use, disclosure or copying of = this email or any | 0 Quote: | recipient, any use, disclosure or copying of = this email or any | 1 Quote: | recipient, any use, disclosure or copying of = this email or any | 2 Quote: | recipient, any use, disclosure or copying of = this email or any | 3 Quote: | recipient, any use, disclosure or copying of = this email or any | 4 Quote: | recipient, any use, disclosure or copying of = this email or any | 5
Quote: | recipient, any use, disclosure or copying of = this email or any | 6
Posted: Thu Nov 06, 2008 10:31 pm Post subject: Cutting & buffing |
Well you can do what I'm doing.. Learned it at OSH looking at a trick fast back RV 8. Wipe proseal into each. Rivet line...clean with MEK. Really not as time consuming as you think.Rick. S
Date: Fri, 7 Nov 2008 16:01:31 +1030
Ok, John Cox prompted the question when ta= lking of Deems' spectacular paint job.
How do you cut and buff without exposing r= ivet heads?? Most aircraft I have seen that have come out of a paint = shop after some rework have too much paint removed over the rivet heads, le= aving many nicely polished but unpainted..
In my paint job, I have a number of rivets= where the paint has not flowed into the rivet countersink properly and loo= k like they have 'black rings' around the rivet head. Not many, but v= ery obvious in the White paint. What causes this and how to fix? = ; There has really been precious little discussion in this forum about pain= ting techniques and problems. Tim's site (as always) is a starting po= int, but what other sources of info are there??
Cheers,
Ron
187, almost done painting Quote: | "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D _-=3D -- Please Support Your Lists This Month -- _-=3D (And Get Some AWESOME FREE Gifts!) _-=3D _-=3D November is the Annual List Fund Raiser. Click on _-=3D the Contribution link below to find out more about _-=3D this year's Terrific Free Incentive Gifts! _-=3D _-=3D List Contribution Web Site: _-=3D _-=3D --> http://www.matronics.com/contribution _-=3D _-=3D Thank you for your generous support! _-=3D _-=3D -Matt Dralle, List Admin. _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
Posted: Thu Nov 06, 2008 10:33 pm Post subject: Cutting & buffing |
Thanks John - great feedback.
I am not using a clear coat - just a base of solid white, so no clear to protect from over zealous buffing.
I have used 2000 grit wet on a DA sander followed up by Meguiars M105 Ultra Cut - truly amazing stuff. Works brilliantly on the composites, but a little too aggressive on the rivet heads.
cheers,
Ron
dlm46007(at)cox.net Guest
Posted: Fri Nov 07, 2008 9:35 am Post subject: Cutting & buffing |
Just a reminder; if you don't want to see rivet heads in your cowl where there are hinges, cover them with a glass tape after riveting. If not the rivet heads will work through the paint after about a hundred hours or so.How do I know? missed four rivets around the oil door on my Glastar. Did not miss any on the cowl or the top on the 10.
Sent: Thursday, November 06, 2008 10:32 PM
Cheers,
Ron
your computer."
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
RandyL
Posted: Sat Nov 08, 2008 7:58 am Post subject: Cutting & buffing |
Another approach: don't use clearcoat and don't cut n buff. Take the time in shooting to flow the paint correctly to get that virgin wet look. Then you'll never have to worry about rivet heads, no unsightly buffing compound in the cracks and around the rivets that can never be removed, lighter weight without the clearcoat, and easier to blend in should repairs ever be needed. Of course a cut-n-buff job on an RV-10 must take forever those things are so huge.
I've painted three RVs this way and all came out good and get frequent compliments. I had to do a repair on a section of the lower cowl on my RV-8 and was able to blend it in so that it literally could not be seen (spray pure reducer over the repaired area right after you shoot the paint).
Info here...
http://www.romeolima.com/RV3works/Paint/paint.html
http://www.romeolima.com/RV8/Paint.htm
Personally, I don't think you can ever get a cut-n-buff surface to look quite as glossy as the wet look of properly flowed paint.
FWIW,
Randy Lervold
