LarryRosen
Posted: Sun Mar 12, 2006 6:47 am Post subject: cowl/fuse hinge shims |
The message below is from back in August 2005.
I just received my finish and FWF kits. Included are 2 thin (.020
or .025) strips 1/2" by 48". I cannot find them on my inventory list.
Are these the shims for the cowling hinges or are they needed for the
finish kit or FWF?
Larry Rosen
http://lrosen.nerv10.com
Marcus Cooper wrote:
I'm trying to locate the material to make the shims for the hinges that
attach to the firewall and cowling. It's 020 X 1/2" but for the life of me
I can't find it in the shipping list or lying around. I could make it from
the trim pack, although one piece is supposed to be 15" long and the trim
pack is only 12" (I think), besides it seems strange not to supply the 1/2"
material to be cut to length.
Anyone else run into this or have a solution? In case it matters, mine is a
QB.
Marcus
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
coop85(at)bellsouth.net Guest
Posted: Sun Mar 12, 2006 9:39 am Post subject: cowl/fuse hinge shims |
Larry,
I may be off, but I think that material is used on the inside of the
fuselage top when riveting to the side skins. I recommend you check that
out before using it on the cowling hinges, although it would be nice if it
were provided.
Marcus
40286
dav1111(at)cox.net Guest
Posted: Mon Mar 13, 2006 4:31 am Post subject: cowl/fuse hinge shims |
Larry:
NO shims are provided for the cowl / fuse hinge. The two side shims for the inside bottom of the cabin cover are provided either in the fuselage or finish kit I can't remember which. Mine had parts numbers on them. The top back inside shim for the cabin cover came with my Emp. Kit I think.
I had to make the shims for the cowl / fuse as shown by the plans.
Russ
N710RV Reserved
RV-10 close to flying I hope
Date: 2006/03/12 Sun AM 09:46:30 EST
Subject: Re: cowl/fuse hinge shims
finish kit or FWF?
Larry Rosen
>QB.
>Thanks,
>Marcus
