Phoenix3(at)cox.net Guest
Posted: Mon Mar 13, 2006 6:26 pm Post subject: 701 Elevator twist? |
Hello,
Despite my best efforts, I seem to have built some twist into the
horizontal stabilizer of my 701. When getting ready to attach the
elevator hinge plates, I checked the level of the stab and it appears to
be off. Over the 2220 mm length, there is about 7 mm of twist. That
is, with the left end level and the right end trailing edge at the same
height, the right hand front is raised about 7 mm. I calculated a 0.34
percent twist and think this is probably acceptable, but really don't
know. I assume that with all rivet holes drilled and most riveted, it's
pretty much locked into this configuration. Any insights? Thanks.
Chuck Kyle
Posted: Mon Mar 13, 2006 7:34 pm Post subject: 701 Elevator twist? |
Hi Charles,
I can only speak from my Radio Control experience. In that arena
Anything Will Fly.
I suspect your small amount of twist will be completely unnoticeable
in flight. Perhaps a small amount of roll trim will be needed for
complete hands-off level flight. If that is the worst problem you
have with your new plane than all I can say is "Congratulations on a
job well done."
Paul
XL wings
graham(at)601hd.com Guest
Posted: Mon Mar 13, 2006 9:17 pm Post subject: 701 Elevator twist? |
Chuck,
You can probably fix it by drilling out the skin rivets, mounting it dead
flat on the table - perhaps even with a hint of reverse twist, and
re-riveting. It fixed a similar problem that I had on my rudder though I
didn't really expect it to. I guess there is some play in the rivet holes.
Alternatively you could redrill it to the next rivet size or just accept
that you subconciously but deliberatly built in a cunning and clever torque
compensation feature - assuming the prop spins the right way.
Graham Kirby
601HD
Posted: Tue Mar 14, 2006 7:15 am Post subject: 701 Elevator twist? |
Chuck,
I played with ailerons that were out from the prescribed twist and also
had my center section out a considerable
amount and both were corrected by drilling the rivets out and jigging to
correct the twist. The center-
section on one line across the seat pan had to go to A5s to get
correction. Each were measurably dead on
after this was done.
It's likely your stabilizer would be correctable by just drilling out
the rivets, adjusting and re-riveting. It would certainly
be worth the small amount of time to fix it. Clecos will show you how
much you can correct after the rivets are out.
Good luck,
Larry McFarland - 601HDS
Charles Kyle wrote:
Hello,
Chuck Kyle
JAPhillipsGA(at)aol.com Guest
Posted: Tue Mar 14, 2006 7:29 am Post subject: 701 Elevator twist? |
Chuck, the fellow with the idea of putting it on a flat table and re-drilling
and riveting is probably the right answer. Every time you deviate from
standard design on some surface contributes to the whole package and they might add
up to some instability or reduced performance. I had a problem with the
elevator skin and had to re-drill and rivet some. What I found was that putting J B
Weld in the extra holes sealed them up just fine and a little light sanding
made them smooth again. After primer and paint they are gone. FWIW, Bill
Phillips N505WP
rjscep(at)yahoo.com Guest
Posted: Tue Mar 14, 2006 10:17 am Post subject: 701 Elevator twist? |
| Quote: | I'd like to know if your scratch building or from
the kit??
--- Charles Kyle <Phoenix3(at)cox.net> wrote:
Hello,
twist into the
to attach the
mm of twist. That
I calculated a 0.34
but really don't
insights? Thanks.
Chuck Kyle
browse
Subscriptions page,
FAQ,
Admin.
ding(at)tbscc.com Guest
Posted: Tue Mar 14, 2006 1:55 pm Post subject: 701 Elevator twist? |
Charles,
As others have said, I think you can correct this if you
choose to. The Avex rivets seem to swell to fill even slightly oversize or
offset holes. I had to make a similar slight correction on my stabilizer
after partial riveting. I drilled out the rivets and had to jig it slightly
opposite to correct, as the rivets tended to pull it back to the same twist
as they were set. Came out perfect.
Lynn
Corry, PA
PS- By the way, an FAA inspector once told me that "jig" is now politically
incorrect. The proper word is now "fixture".
