george.mueller(at)aurora. Guest
Posted: Mon Dec 01, 2008 6:46 am Post subject: Prop Pitch |
Is there anyone on this list with a flying 701 with a Rotax 912UL (80HP) and a warp drive three blade prop? What pitch (measured at the tips) do you have on the prop and what kind of climb and cruise are you seeing? With me (230 lbs), my BRS chute and full tanks I am about 50 lbs shy of gross and am seeing 500 fpm climb and 75 mph cruise at about 5400 rpm. Is this normal performance? I only have about 5 degrees pitch on the prop which gives me 5650 rpm with full throttle in straight and level flight at about 2000 MSL.
George in Milwaukee
N701GM 55hours flying
CONFIDENTIALITY NOTICE: This email, including any attachments, is for the sole use of the intended recipient/s and may contain confidential and privileged information. Any unauthorized review, use, disclosure, or distribution is prohibited. If you are not the intended recipient, please contact the sender by phone or return email and destroy all copies of the original message.
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
John75142
Posted: Mon Dec 01, 2008 7:46 am Post subject: Prop Pitch |
Seems like I recall others setting (at) 12 deg. but not 100% sure as I do not have this set up.
John (Scratch building 701) 50% done/100% to go
Kaufman, Tx
_________________ John Short |
zsmith3rd(at)earthlink.ne Guest
Posted: Mon Dec 01, 2008 8:50 am Post subject: Prop Pitch |
George,
I'm in the office, not anywhere near a prop, so this is from faint memory.
First of all, I do recall that it was something on the order of 15 degrees but definitely not measured at the tip.
Mine is a 912, three-blade Warp Drive, RPM limited to 5500.
Long version of old story:
Prop came with the Warp protractor, but at the time an old WWII pilot/crop duster/A&P was still alive and offering advice.
He loaned me a high-dollar prop protractor complete with wood case, and promised to hurt me if I damaged it.
He offered that any protractor needs to be placed at the 'widest' place on a prop in order that the protractor sit across as much width as possible to insure repeatable measurements.
He went on to instruct that the blade being adjusted need to be 'level' using a small bubble level each time, and at the same point on each blade; that the 'number of degrees' will vary from station to station along the blade, and what ends up being 'correct' is what you get.
Said differently, because the 'twist' in the blade changes as you move outboard, the resulting protractor reading changes as you move it along the blade. Therefore, according to this receipient of the 'Charles Taylor Award', you simply pick a wide place, mark it with masking tape (on each blade) and apply the protractor.
Following his instructions, I set mine, then fired it up. Had too much at 20 degrees, so I reduced it 2 degrees and tried again. Still too much. After three more attempts I was satisfied.
A run-up on the ground gave me 5400 and slid the tires on wet grass. On takeoff it would go to 5500 RPM at about 40 knots, but never above about 5550.
The preceeding was on a pusher airplane. On the 701 (same engine, tractor prop) I've not done a final setting, but did set the pitch a few degrees too much specifically to limit RPM until I'm ready to adjust it.
One other comment about measuring at the tip: My old friend was really specific about NOT using a narrow portion of the blade.....too easy to have one or two degrees difference between blades and then have them tracking all over the place. He stressed that placement of the measuring device will dictate the 'reading' you get; and that the pitch YOU get may not agree with what some other fellow gets who placed his protractor at a different station (distance from the hub) on the same prop.
Hope this makes sense!
Have a great week, best regards, and surely somebody will jump in with truth & justice!
Zed
Posted: Mon Dec 01, 2008 8:51 am Post subject: Prop Pitch |
George,
Zed
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Mon Dec 01, 2008 12:05 pm Post subject: Re: Prop Pitch |
Hi George,
We finally set our Warp Prop at 12 degrees at the tip using the warp protractor and the prop blades level. At gross weight with me an a pax, full fuel, we get about 5350 rpm on climout at 60 mph and 850-900 fpm (assuming our VSI is correct). We can easily go to 5500 rpm in level flight at max throttle. we are cruising around 70-75 at 4800 rpm. We have a 912ULS 100 HP.
Tommy Walker
Do Not Archive.
PS I like Zed's idea. You could measure one blade at 12 degrees at the tip, then check the measurement at the widest part of the blade, then do the other two at that setting.
[quote="george.mueller(at)aurora."]Is there anyone on this list with a flying 701 with a Rotax 912UL (80HP) and a warp drive three blade prop? What pitch (measured at the tips) do you have on the prop and what kind of climb and cruise are you seeing? With me (230 lbs), my BRS chute and full tanks I am about 50 lbs shy of gross and am seeing 500 fpm climb and 75 mph cruise at about 5400 rpm. Is this normal performance? I only have about 5 degrees pitch on the prop which gives me 5650 rpm with full throttle in straight and level flight at about 2000 MSL.
George in Milwaukee
_________________ Tommy Walker
N25A - Anniston, AL |
b.carl@sympatico.ca
Posted: Sun Dec 07, 2008 6:10 pm Post subject: Prop Pitch |
I've got a 912 ul with 70" WD 3 blade but my config is Amphibs. I often fly at or near gross of 1200# and like to set 8.5 to 9.5' as a compromise for climb and cruise.
This should give you 5100-5200 static on ground.
Carl
