LIGHTNING AUSTRALIA
Joined: 02 Dec 2008 Posts: 11 Location: Kingston SE AUSTRALIA
Posted: Tue Dec 02, 2008 1:15 am Post subject: Lightning gear leg shimmy |
To those experiencing landing gear shimmy - here in Australia I have experimented with our first demonstrator aircraft and through trial and error have found that by taking the wheel alignment to a tow out setting instead of the suggested tow in setting, the problem is eliminated. I have used the same tow out as was suggested for the tow in. Over a 12 month period we have monitored the tyres and there is no evidence of any excess wear. Due to the success of this trial, we have used the same settings on several other aircraft that are flying with the same positive result. These results we obtained regardless of weight loading of the said aircraft.
Dennis Borchardt
Lightning Aircraft Australia
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Dick
Posted: Tue Dec 02, 2008 10:28 am Post subject: Lightning gear leg shimmy |
The gear legs in my lightning were set to 1deg toe out in June of this
year. The speed at which shimmy occurs changed from about 40mph to about
20mph. I have balanced the wheels with not much change. I am now making
the wooden stiffeners used by the RV folks and hope to have them installed
in a couple of weeks. An old hand RV builder told me last week that they
set the gear legs straight, ie no toein or toeout and have seen no wander or
other problems. I plan to try that if the gear leg stiffiners have'ent
solved the problem.
selwyn
Posted: Tue Dec 02, 2008 2:28 pm Post subject: Re: Lightning gear leg shimmy |
Has anyone measured the effect of loading on fore and aft wheel alignment? What I am thinking of is measuring the more or less empty aircraft, filling it with fuel, adding two large lads, rolling it along in a straight line for a bit to let things settle and then measuring it again.
This would be useful information to put into thinking about effects of alignment, especially as we have this difference in observed effects.
_________________ Cheers, Selwyn
Kit 66 VH-ELZ |
staufferm
Posted: Tue Dec 02, 2008 3:37 pm Post subject: Lightning gear leg shimmy |
Selwyn,
Here in Shelbyville we load up the plane to around 1250 lbs using sand bags
on the wings and then roll it fore and aft a few times (2'-3'). At that
point we set the toe on the gear. Currently we're setting the toe to 1
degree out.
We've never measured the difference in toe between empty and loaded.
Mark
