Dana
Posted: Tue Dec 16, 2008 4:24 pm Post subject: Kolb Ultrastar: How to take-off |
At 07:41 AM 12/16/2008, pj.ladd wrote:
| Quote: | From what I remember of the story the refuelling crew were instructed to
put in a specific amount of fuel but instead filled the tanks.
I am not going to get into the question of whether Gann should have
checked the amount. It is just the story as I remember it and its years
since I read it.
I don't remember the details from when I read it, either, but also IIRC it
was during wartime... when people often must do things with a much lower
margin of safety than they'd otherwise find acceptable.
| Quote: | Incidentally if you have never come across Ganns books I think his
initials are D.W and there was at least one film derived from one of his
stories.
Ernest K. Gann... all of his numerous flying books are worth reading. He
also wrote several sea stories but I haven't read any of those.
-Dana
"The difference between death and taxes is death doesn't get worse every
time Congress meets." -- Will Rogers
Posted: Wed Dec 17, 2008 4:17 am Post subject: Kolb Ultrastar: How to take-off |
Ernest K. Gann.!
Of course. Stupid me. Senior moment. Thanks Dana
Pat
Posted: Wed Dec 17, 2008 4:21 am Post subject: Kolb Ultrastar: How to take-off |
I'm sure you're talking about Ernest K. Gann,>>
Hi Russ,
quite right. Just me being thick. The High and the Mighty was the film
which I had in mind,. Thanks for the list of books, there were a few there
I hadn`t read.
Cheers
Pat
Posted: Wed Dec 17, 2008 4:50 am Post subject: Kolb Ultrastar: How to take-off |
Agreed. If you haven't read it, do it. So real you will feel you are
there.>>
Hi Robert,
I remember there was a passage in one book describing a flight into a fijord
in Iceland(?) during a transatlantic flight. Clag closed the top and the
Airforce base was right at the inland end . There were a couple of bad
direction changes to be negotiated and the it was straight into the
airstrip with no room to turn round and try again. One try only. It had me
on the edge of my seat. great stuff.
thanks for putting me right on the initials, everybody
Pat
Posted: Wed Dec 17, 2008 5:44 am Post subject: Kolb Ultrastar: How to take-off |
Time: 12:15:56 PM PST US
Subject: Re: Kolb Ultrastar: How to take-off
I'd like to watch you demonstrate those maneuvers for me, as soon as I
finish making double tie downs on my mkIII.
John,
I am some what puzzled by your cross wind problem. I have thought about it
a little and may be I can help out a little.
You have said you are self taught and I wonder if you are proficient at
cross controlled flying especially side slipping? I assume you are.
Not all Kolbs are the same and this includes your MKIIIC. There are several
changes that you have done to your plane that make it more yaw sensitive.
First, you have moved your main gear forward. This moves the cg further
behind the main gear. What you gained in nose over prevention you lost in
making the plane more squirrelly in yaw on the ground. To compound this you
have added additional fuel capacity and weight. If you do not have baffles
in the tank, fuel sloshing while making a take off run in a gusty cross wind
will cause yaw problems.
With your admitted aft cg and flying heavy, you will lose some roll
authority at low speed, and this will reduce ones ability to hold the plane
steady in gusty cross wind on take off. VG's can help overcome this
situation, in that, they will improve aileron effectiveness at low speed,
and they will move the center of lift back from the cg.
A couple of other factors that can make your plane less ground yaw stable is
incorrect toe in, camber and tire pressure. If the toe in is not neutral
and/or camber is not positive under load, the plane will be squirrely on a
gusty cross wind take off. If you are running low pressure tires the
rolling resistance is a function of the load, and so as the plane rocks from
side to side it will want to turn in that direction.
For what it is worth.
Fly safe!
Jack B. Hart FF004
Winchester, IN
Posted: Wed Dec 17, 2008 6:49 am Post subject: Kolb Ultrastar: How to take-off |
Jack
I think you have misunderstood John's message. First let me assure you John
and his plane are more than up to the task of handling the upper limits of
any Kolb cross wind landing.
Two things. First, we all need to be very careful not to overstate the
capabilities of our airplanes so that less experienced pilots will not try
to handle weather they think is safe because someone has said it was safe.
Second, less experienced pilots tend to over estimate the actual cross wind
component that they have landed in.
I think we should follow John's lead in reporting accurate limits of our
aircraft. Pounding our chests and stating "I can land in a higher cross
wind" isn't a good thing to do here.
Rick Neilsen
Redrive VW powered MKIIIC
Posted: Wed Dec 17, 2008 6:59 am Post subject: Kolb Ultrastar: How to take-off |
| Quote: | I am some what puzzled by your cross wind problem. I have thought about
it
| Quote: | Jack B. Hart FF004
Hi Jack:
All aircraft have a ultimate cross wind component limit. I don't know what
Kolbs limits are, but probably around 15 mph in a direct cross wind. After
that there just ain't enough rudder to align the aircraft with the runway.
Landing is much more critical than takeoff in high cross wind conditions,
probably because there is much less air moving over the rudder, and other
flight controls, during landings. I have found it helpful to use short
burst of power to help align the aircraft just prior to and during touch
down, especially on paved strips. Grass and gravel strips are much more
forgiving when touching down or taking off while crabbing.
If all cross winds were steady, it would make operating in them much easier.
But, normally, they are not. Gusty wind conditions play havoc on very light
aircraft. Many times we find ourselves, momentarily, in a "along for the
ride" condition.
I find my modified Kolb as good or better handling rough air and cross winds
than the standard Kolbs I fly. Maintaining runway alignment during takeoffs
is not a problem, normally.
I do a lot better negotiating rough air and cross winds the more I fly.
Lately, I haven't been flying much. In fact, I'm pushing three months since
my last flight, returning from the Kolb Homecoming in Kentucky.
_________________ John Hauck
Titus, Alabama |
vicsv(at)verizon.net Guest
Posted: Wed Dec 17, 2008 7:34 am Post subject: Kolb Ultrastar: How to take-off |
Jack
That reminds me of another question, Pats brain cramps are catching.
I noticed while taxying with a cross wind if rudder input was not enough, aileron in the opposite
direction would bring it in line. Soooo how would you (I) be able to keep a wing down into the x wind?
Vic
Hey Jack,
As a novice with 3.5 legal hrs. with Instructor and only 6 seconds of solo I don't under stand Why you would crab into the wind on take off if you already weather vaned into it.
"After it leaves the ground, you can let it weather vane into the wind, level
the wings and crab into the wind on climb out."
How do you slip and crab simu, simul, together?
"If the wind blows you off, then you have to decide whether to use a
combination of side alip and a crab to get to the runway, and at the last "
Thanks in advance for the free instruction.
Vic
Ed in JXN
Posted: Wed Dec 17, 2008 9:48 am Post subject: Kolb Ultrastar: How to take-off |
Hi,
IIRC, it was Narssarssuaq (sp?) in Greenland. An ADF approach with
4 or 5 heading changes, all the while descending with granite on both sides.
Had to go in there about 10 years ago in a Cessna 421, fortunately it was
VFR. Quite the graveyard back in the day, I understand.
BTW, why are we teaching folks to fly via the interweb? My HP
laptop doesn't do well in ground effect, so I leave the flight instructin'
to the airdrome.
Ed in JXN
MkII/503
Do not archive.
Posted: Wed Dec 17, 2008 10:55 am Post subject: Kolb Ultrastar: How to take-off |
Narssarssuaq (sp?) in Greenland.>>
Yeah. Well I knew it was partway across the Atlantic
Thanks. Must 30 years since I read that book
Cheer
Pat
russ(at)rkiphoto.com Guest
Posted: Thu Dec 18, 2008 5:06 pm Post subject: Kolb Ultrastar: How to take-off |
Dana
Apparently Pat hadn't found it in various posts, but of course he
was Ernest K Gann; the Taj incident was before WW2 -- and ALL of his
books are well worth reading. I'd recommend A HOSTAGE TO FORTUNE as a
start. I may even go back and re-read it; it's that good.
Merry Xmas,
Russ
On Dec 16, 2008, at 7:20 PM, Dana Hague wrote:
> instructed to put in a specific amount of fuel but instead filled
> the tanks.
> have checked the amount. It is just the story as I remember it and
> its years since I read it.
IIRC it was during wartime... when people often must do things
with a much lower margin of safety than they'd otherwise find
acceptable.
> of his stories.
reading. He also wrote several sea stories but I haven't read any
of those.
-Dana
every
Posted: Fri Dec 19, 2008 8:30 am Post subject: Kolb Ultrastar: How to take-off |
Apparently Pat hadn't found it in various posts, >>
Hi,
I found it. I found it, and every single person on the list told me what I
was to old and stupid to remember.
Thanks everybody
Pat
Posted: Fri Dec 19, 2008 2:24 pm Post subject: Kolb Ultrastar: How to take-off |
Pat
Pilots may be old, but they're never stupid.
Otherwise they wouldn't get old
Merry Xmas to you!
On Dec 19, 2008, at 11:29 AM, pj.ladd wrote:
Hi,
what I was to old and stupid to remember.
Thanks everybody
Pat
