Wingrider
Joined: 22 Nov 2006 Posts: 34 Location: Tullahoma, TN
Posted: Wed Dec 31, 2008 8:22 am Post subject: GPS Tracking |
I thought I'd pass on a great little application I found yesterday. It's named TrackMe and can be found at http://www.luisespinosa.com/trackme_eng.html. It uses your cell phone to send coordinates to a webserver so your position can be tracked in real time from Google Earth or from Google Maps.
After reading about a guy who wrote his own program that does this I began looking for something similar. There are several fee based applications, gpsgates Buddy Tracker being one of the better low cost options based on what I've read.
However TrackMe is free and can use your own server if you don't want to use his. I've only played with this a little so I don't know how well it will work in flight but it certainly looks promising.
This interested me because family can monitor my position either live or from the saved data on the server and if something happened I wouldn't be relying on just the ELT. Might have been good for Steve Fossett to have.
Just passing it on for what it's worth. Have a happy New Years
_________________ Rich Whittington
Tullahoma, TN
Zenith 601HDS
Corvair 3 Liter 120HP |
bryanmmartin
Posted: Wed Dec 31, 2008 8:34 am Post subject: GPS Tracking |
Sounds like it would work well as long as you travel in areas that
have cell phone service. There are a lot of areas where cell phone
service is unavailable though.
Google Maps.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Wed Dec 31, 2008 9:14 am Post subject: GPS Tracking |
Another "free" solution to GPS tracking is the Automatic Position Reporting
System (APRS) which relies on ham repeater stations that are spread across
the country. See, e.g.,
http://groups.yahoo.com/group/canard-aviators/message/47541
APRS coverage is apparently excellent, and hardware cost is low. You need
the lowest level ham license to use APRS. Equipment cost is 2 or 3 hundred
bucks, but there is no monthly charge as with SPOT.
Terry
At 11:32 AM 12/31/2008 -0500, you wrote:
Quote: | Sounds like it would work well as long as you travel in areas that
>http://www.luisespinosa.com/trackme_eng.html . It uses your cell phone to
>Google Maps.
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Gig Giacona
Posted: Wed Dec 31, 2008 10:03 am Post subject: Re: GPS Tracking |
But doesn't APRS require an HAM lic.?
601XL Under Construction
Wingrider
Posted: Wed Dec 31, 2008 10:49 am Post subject: Re: GPS Tracking |
I've been reading up on APRS and believe this is the way to go. TrackMe is completely free if you have a gps enabled phone and a data plan but you are relying on cell phone coverage which will diminish with altitude.
For roughly $300 I believe you can have a reliable APRS package. I'm still researching.
Tullahoma, TN
Zenith 601HDS
Posted: Wed Dec 31, 2008 11:26 am Post subject: GPS Tracking |
Here is a good article about installing an APRS node in an RV-6:
http://home.hiwaay.net/~sbuc/journal/tracker.htm
The Ham license basically requires studying for, and taking a test. The is
no Morse code requirement.
-- Craig
