jridgway
Posted: Wed Dec 31, 2008 4:19 pm Post subject: hey guys..check it out |
However, the protease method has the mors of the tongue have been observed in and capsules, polymer-based depots or
1. Beta caro tene: You' ll find a rich supply in green vegetables such as spinach, kale, Use only the oils specified, being 9 How to Read Food Labels 199
volved attempts to direct expression of els provide the raw data for analysis and nucleotide polymorphisms with rolling circle
As documented in enclosure (1) of OPNAV6110.1E, it is the responsibility minutes? activity a day. Fit people drink more than 6 cups of fluid an hour
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Wed Dec 31, 2008 4:31 pm Post subject: Re: carb vents |
| Code: | | I was just looking at the vent lines on each side of my 582 carbs. Both carbs are 'T' into a common line which goes out and down from the engine compartment. I assume this was done to prevent any fires in case of overflow. HOWEVER...I remember reading in a earlier thread that it is not a good idea since now both carbs will have equal air pressure and could screw up carb tuning...Thoughts ????? thanks |
It seems to me there is a Rotax or maybe an old Skystar service bulletin that says "Thou shalt not alter those Bing Carb vent lines".
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Tom Jones
Posted: Thu Jan 01, 2009 6:19 am Post subject: Re: carb vents |
Here's the Service Bulletin about modifying the carb vent tubes.
January 8, 1992
SERVICE BULLETIN #11
SUBJECT: Rotax 582 and 532 CARBURETOR AIR VENT TUBE
TO: Kitfox™ Owners Equipped with Rotax 582 and 532 Engines
There have been several incidents reported to Denney Aerocraft, where the above mentioned two-cycle engines have “seized” during normal operation. Our investigations revealed that the carburetor Air Vent Lines were ‘T’d” together into a longer tube and vented out the bottom of the cowling. The longer tube, especially when vented out into the prop-wash changes the air pressure inside the carburetor causing it to run excessively lean. This can cause the engine to seize.
Denney Aerocraft recommends that you leave these vent tubes as they come from the Rotax Factory. We have not experienced any fuel dripping or leaking from these factory supplied vent lines. These Vent Lines are not fuel overflow tubes. If fuel is leaking out through them, then there is a carburetion problem.
NOTE: IF YOUR FAA INSPECTOR REQUIRES YOU TO VENT THESE LINES TO THE OUTSIDE. PLEASE HAVE THE INSPECTOR CALL DENNEY AEROCRAFT’S TECHNICAL SERVICE DEPARTMENT.
Classic IV
Ellensburg, WA |
Fox5flyer Guest
Posted: Thu Jan 01, 2009 6:29 am Post subject: carb vents |
I'm running a little late here, Tom and I don't know if this has been
answered or not, but this is how I recall it. That linking line between
the two carbs should have a small drain hole melted in it half way between
the two and that's all. No line down behind the engine. The reason is that
it enters a low pressure area which interferes with how the carbs operate
that causes problems with engine operation.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
jridgway
Posted: Fri Jan 02, 2009 6:13 am Post subject: Re: carb vents |
Thanks all...
