7suds(at)Chartermi.net Guest
Posted: Fri Jan 02, 2009 8:07 pm Post subject: Wing Repairs |
All,
I thought it might be time for a new topic,
I have a Model 5 I am rebuilding after a ground loop (No, I did not ground loop it, I bought it that way). The main wings have 13 gallon wing tanks in each and it appears the builder installed a full cap strip on a spacer that is glued to the bottom of the wing tank where the wing rib would normally be if the tank was not there. . I removed the sumping port and used a bore camera with a 3’ lead slid in between the fabric and the tank to inspect it. I did not see anything in the build manual that indicated installing this capstrip across the tank; has anyone else installed this capstrip across the bottom center of their 13 gallon wing tanks? The reason I am asking is because it has come loose from the spacer it was glued to and is now only attached to the fabric, the spacer is still attached to the wing tank. My thought was to install 2 inspection access ports next to it and either repair it or remove it. It does not appear that it came loose as a result of the ground loop, looks to have been that way for a while, both wings have them and they both appear to be loose.
Lloyd Cudnohufsky
Model 5 912ul IVO IFA
Upper Mi.
Checked by AVG.
1/1/2009 5:01 PM
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jan 02, 2009 9:03 pm Post subject: Wing Repairs |
Lloyd, that rib is part of the kit. I have it on mine - 1992 Model IV
Lowell
Lynn Matteson
Posted: Sat Jan 03, 2009 12:20 pm Post subject: Wing Repairs |
Lloyd-
Here's a shot of my capstrip, and the false ribs I built on both
sides of it. I don't think the manual calls for the false ribs on the
tank, but I figured to keep the same look for the whole wing they
needed to be added. The second shot is of the top false ribs over the
tank. These were 1/8" spruce from the model airplane store.
Lynn Matteson
Jabiru 2200, #2062, 596+ hrs
Sensenich 62x46
flying again after rebuild, and new Electroair direct-fire ignition
system;
also building a new pair of snow skis
Lloyd Cudnohufsky
Upper Mi.
Checked by AVG.
1/1/2009 5:01 PM
Description: |
Filesize: |
447.97 KB |
Viewed: |
341 Time(s) |
Description: |
Filesize: |
494.35 KB |
Viewed: |
298 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sun Jan 04, 2009 11:29 am Post subject: Wing Repairs |
Lynn,
Thanks for the reply.
Now that I like, if I were to open the wing in that area I would definitely
steel you idea and duplicate it.
Lloyd
Lynn Matteson
Posted: Sun Jan 04, 2009 11:51 am Post subject: Wing Repairs |
Ideas here are free for the taking...thanks for the kind words, Lloyd.
Lynn Matteson
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system;
On Jan 4, 2009, at 2:27 PM, Cudnohufsky's wrote:
<7suds(at)chartermi.net>
Lynn,
definitely
Lloyd
N369LM |
temco(at)telusplanet.net Guest
Posted: Sun Jan 04, 2009 5:16 pm Post subject: Wing Repairs |
Lloyd
If your aircraft is the same as mine, then the piece you are looking at is part #27023 and it is the partial rib that goes under the tank to the wing trailing edge. The rear of the partial rib forms the airfoil from the back of the tank (rear spar) to the wing trailing edge metal piece. >From your description I would suspect that what has happened is only the cap strip under the tank has come lose but the web, upper cap strip and lower cap strip rearward of the tank are still intact.
Hope this helps.
Ted Palamarek
Model IV/912
Edmonton, Alberta
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Cudnohufsky's
Sent: Friday, January 02, 2009 9:05 PM
Subject: Wing Repairs
All,
Lloyd Cudnohufsky
Upper Mi.
Checked by AVG.
1/1/2009 5:01 PM Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Posted: Sun Jan 04, 2009 5:44 pm Post subject: Wing Repairs |
Ted,
You are correct; the rib behind the rear spar is fine, it is only the cap strip part that is under the tank that has come loose from the spacer between it and the tank. Cap strip is still attached to the fabric.
Lloyd
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Ted Palamarek
Sent: Sunday, January 04, 2009 7:16 PM
Subject: RE: Wing Repairs
Lloyd
Hope this helps.
Ted Palamarek
Model IV/912
Edmonton, Alberta
All,
Lloyd Cudnohufsky
Upper Mi.
Checked by AVG.
1/1/2009 5:01 PM Quote: | http://www.matronics.com/Navigator?Kitfox-List http://forums.matronics.com http://www.matronics.com/contribution | 0123456789 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 1 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 2 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 3 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 4 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 5 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 6 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 7
Checked by AVG.
1/3/2009 2:14 PM
Checked by AVG.
1/3/2009 2:14 PM
