naumuk(at)alltel.net Guest
Posted: Sat Jan 03, 2009 7:35 pm Post subject: Molex crimping |
All-
My Icom A200 has a main connector with dozens of Molex connectors that have to be crimped. I think the crimps can be done with those provided in a standard wire stripper, then soldered. True/False?
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
SABorns(at)aol.com Guest
Posted: Sat Jan 03, 2009 8:09 pm Post subject: Molex crimping |
Bill,
Yes, Molex pins can be crimped by hand and then soldered, however there is a special tool for the purpose that "folds" the ears down first on the wire and then a second crimp to secure the wire. When using the tool no soldering is necessary. It is preferable from a fatigue standpoint to install the pins without soldering.
Steve CH701
Steven Bornstein
475 E. North Broadway
Columbus, Ohio 43214
614 263-5819
In a message dated 1/3/2009 10:35:54 P.M. Eastern Standard Time, naumuk(at)alltel.net writes:
Bill Naumuk
Townville, Pa.
Quote: |
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
latest news - from fashion trends to celebrity break-ups and everything in between.
psm(at)att.net Guest
Posted: Sat Jan 03, 2009 8:10 pm Post subject: Molex crimping |
Hi Bill,
It is considered better to crimp the connectors with the appropriate tool rather than soldering them. While solder will, indeed, hold the wires in place there are issues with vibration and wire breakage.
My advice to you is to spring for the crimper and do it right. You can locate the appropriate crimper at most electronics distributors or by looking at the Molex web site.
Paul
XL getting close
At 07:34 PM 1/3/2009, you wrote:
[quote]All-
Bill Naumuk
Townville, Pa.
pdn8r(at)yahoo.com Guest
Posted: Sat Jan 03, 2009 8:16 pm Post subject: Molex crimping |
Hey Bill,
Don't know what you mean by "standard wire stripper" but don't use the type of wire crimper you find at the local auto parts store. also, don't solder and crimp. Get a good set of crimpers from someplace that knows aviation systems such at B & C Specialty. Here's their website. http://www.bandcspecialty.com/ It'll make the job much easier and give you tremendous peace of mind.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Sat, 1/3/09, Bill Naumuk <naumuk(at)alltel.net> wrote:
Quote: |
Subject: Molex crimping
To: "zenith list" <zenith-list(at)matronics.com>
Date: Saturday, January 3, 2009, 10:34 PM
All-
Bill Naumuk
Townville, Pa.
jlatimer1(at)cox.net Guest
Posted: Sat Jan 03, 2009 8:25 pm Post subject: Molex crimping |
Bill,
Try this site:
http://www.aeroelectric.com/articles/matenlok/matenlok.html
Someone has already sent you to B&C for the tool.
Jerry
Bill Naumuk
Townville, Pa.
Posted: Sun Jan 04, 2009 8:09 am Post subject: Molex crimping |
Bill,
I had problems with soldered connectors in my A200 and after a
protracted effort, a repairman had to crimp the pieces to get the good
contact that was needed.
*June 6* After a search of the Matronics page, the Aero Electric
connection, a comment on poor contact between the edge connector and
pins used on the ICOM A200 was found. I went to the airport and wiggled
each individual wire and found the M and 11 power input wires adjacent
to each other would cause erratic variation in volume. The radio was
removed and then the two pins were carefully removed. The tabs were
spread and the pins were carefully reinserted. Then the volume had to be
lowered on traffic reporting at a 100 miles out even with the hanger
door still down. Wiggling the wires still cause the signal to vary
considerably, but the problem is identified and now only requires a
solution. Molex edge card connector p/n 09-50-6155 and pins p/n
08-03-0303 will be ordered from Mouser Electronics tomorrow by phone.
Thanks again to the Matronics subscribers.
*June 7* Pins and connector were ordered from Mouser and my insurance
was bound with AIG shortly after. A 3-piece set of 6-ft static-ground
wires with gator ends was made to allow refueling on a regular gas
basis. The Illinois Department of Aeronautics Registry was called and
forms were requested to get the airplane sticker needed to show
compliance with the state user tax. Out at the hangar, the radio was
again pulled and pins were adjusted outward with better results, but 30
new pins and connector pre-wired and glued in place may be in order.
There's just too much play in pin position with the radio in to fly
without fixing this. Tomorrow, Tim will take a look and hopefully adjust
the side tone and possibly offer suggestions.
*June 8* On this semi-rainy morning the aircraft was open and accessible
at 9:00 a.m. Tim arrived and after checking out the contacts, wires and
intercom, he soon resolved that the radio problems are with my
connector, some incorrect shielding and the manner in which I soldered
the pins. He removed two screws holding the connector using a foot long
screwdriver and pushed it out from the inside to gain more direct access
to pins while remaining connected. He determined another less abused
connector was needed. I closed the hangar, had lunch with the guys at
the Lucky 8 and visited Warren electric without success. Then I called
ICOM parts and was able to order one in stock from them. Now we wait for
one in the mail from ICOM and one backordered from Mouser Electronics to
see which gets here first. Thirty pins are already on their way from Mouser.
*June 9* It rained on and off today. The ground wires that FAA inspector
wanted tie-tied off were finally secured. A standard oil filler neck
from my spare EA-81 was compared to the customized Stratus design. One
could conclude that the filler should be turned toward the other side
proximate to the dipstick so that the access door would suffice for both
checking and adding oil. It doesn't seem it would be a lot of work to
remake the tube to get it there. Tim was unable to get the external snap
ring off the 90-degree coax fitting inside the radio case, so I made a
tool for reaching it like Tim's so it might be out before we resume.
*June 14* With thunder and rain this morning, the hangar door was opened
and there was enough light to remove the new oil filler tube and
reassemble it with a proper amount of gasket sealer. The short 40-degree
off angle 6mm Allen wrench was cut to 5/8" and the other end was bent as
well as twisted by the width of one flat. This made it possible to
tighten the nearly inaccessible bolt in short increments alternating
ends. Tim arrived after noon and began cutting wires from the old
connector and putting proper crimps to new pins and snapping each in
place one by one into the new connector. I was humbled as I watched him
crimp the pins so perfectly. I had incorrectly assumed they could be
crimped and soldered, but they just don't fit well in the connector as a
soldered pin. Within an hour or more, the radio was slid in and a radio
check to ground control was very clear both ways in both headsets. Later
in the evening, Lee and I visited the hangar to add a little insulating
tape and some tie-ties to secure things again and the radio work was
finally done.
What a hassle! Recommend you crimp the pieces, not solder. Also, do
this prior to installation of the connector and support tray.
Bill Naumuk
Townville, Pa.
Posted: Sun Jan 04, 2009 9:32 am Post subject: Molex crimping |
Larry-
Three questions-
1. What crimper finally worked?
2. "Prior to installation of the connector and support tray". I was
planning on "Nailing down" the tray after the BNC antenna connection had
been installed. How does the pre-installation of the Molex connector to the
tray have an effect?
3. I thought you had a Becker com.
Attached is a picture my brother and I found over Christmas of my dad at
the end of WWII. What is the twin behind him? NO FAIR LOOKING IT UP!!
Description: |
Filesize: |
147.74 KB |
Viewed: |
362 Time(s) |
Posted: Sun Jan 04, 2009 11:52 am Post subject: Molex crimping |
Bill,
The crimper he used was specifically the three stage fold and crimp, but
it was his crimper and the ability to do the job without soldering that
made it work.
I found it really awkward to wire the Molex connector in place with the
tray already installed. We worked around that with close proximity to
the header tank and that just made the job much longer. A wired Molex
connector and "free tray" would at least offer and easier opportunity to
examine the
plug and wiring installation prior to a final push-in connection with
the radio. I have a Becker transponder and an ICom A200. My pathetic
crimp/solder
work wasn't discovered as a poor connection until all was in place.
Removal of the connector was an especially difficult complication. Thank
God I made the forward
top skin removable!
Golly, it looks like cross between a single tailed P-38 and a U-2
cockpit for camera or light bomber work. Surely a fast plane, but what
is it?
I don't know.
Larry McFarland
Bill Naumuk wrote:
Quote: | Larry-
Three questions-
had been installed. How does the pre-installation of the Molex
connector to the tray have an effect?
dad at the end of WWII. What is the twin behind him? NO FAIR LOOKING
IT UP!!
bryanmmartin
Posted: Sun Jan 04, 2009 4:05 pm Post subject: Molex crimping |
That's a Grumman F7F Tigercat. The single engine tail dragger on the
other side is an F6F Hellcat.
what is it?
I don't know.
Larry McFarland
> LOOKING IT UP!!
> Bill
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Jan 04, 2009 6:17 pm Post subject: Molex crimping |
Bryan-
Correct. I forgot I was on-list instead of talking to Larry direct. I
should have cropped out the Hellcat and it would have been harder to
identify. Gotta admit, not too many pictures of them around!
