nfivesl(at)yahoo.com Guest
Posted: Fri Mar 17, 2006 7:05 pm Post subject: Cable ties (Use PVC instead) |
Hi Don:
Scott Laughlin here. It was nice meeting you last
week at the EAA meeting. I chose to install thin-wall
pvc pipe in my wings and I'm really glad I did. Since
you haven't closed up the wing, this would be your
last chance to do this. I found that it was nice to
be able to close up the wing, then worry about wires
later. I ended up adding a few more wires after the
fact and it was nice to have the pipe in there. Here's
a photo or two:
http://www.cooknwithgas.com/5_20_04_WingInside.JPG
Here you can see the .025 brackets I riveted to the
ribs. Use a hole saw that is just smaller than the
pipe and file the holes larger with a round file for a
tight fit. Use JB weld to permanently affix the pipe
at the bracket holes.
http://www.cooknwithgas.com/5_20_04_Leftwing.JPG
Take care,
Scott Laughlin
EAA Chapter 80
--- Don Mountain <mountain4don(at)yahoo.com> wrote:
The local EAA tech counselor did an inspection on
the left wing I am getting ready to close up, and
had me tie the wires down better.
marinegunner(at)gmail.com Guest
Posted: Fri Mar 17, 2006 8:17 pm Post subject: Cable ties (Use PVC instead) |
Scott,
Grand idea - those pvc pipes. I am reopening my 701 wings and will install
the pipes while inside.
Semper Fi,
Steven R. Hulland
CH 701, Amado, AZ
This and all other incoming/outgoing email, attachments and replies scanned
prior to opening/sending and uses an external firewall to help insure virus
mountain4don
Posted: Sat Mar 18, 2006 6:15 am Post subject: Cable ties (Use PVC instead) |
Hello Scott:
I already have all of my wiring running through the ribs in rubber grommets in the conventional manner. But you will have the same problem that I am while running your wingtip light wires from the ends of your PVC pipe out through the lightening hole in the end of the main rib. How do I tie the bundle of wires in the middle of that hole as suggested by the inspector with cable ties? And how are you going to get the aileron trim wire fished into the side of that PVC pipe?
Also, I noticed in your photos that you appear to have two stiffener angles on every rib down your wing? What are these for? Or did you change the design and use a lighter metal sheet to fabricate your main wing ribs? I wonder how much your plane is going to weigh when you get it finished with all of this extra stuff?
Don
Bring photos to life! New PhotoMail makes sharing a breeze.
_________________ Zenith 601XL, tail done, working on wings |
dredmoody(at)cox.net Guest
Posted: Sat Mar 18, 2006 6:42 am Post subject: Cable ties (Use PVC instead) |
PVC might be cheaper and more readily available but what about soft aluminum
tubing from A.S? It is probably lighter and will form to any reasonably
gentle bend that is needed.
Ed Moody II
Rayne LA
601XL working on tail
| Quote: | Scott,
Semper Fi,
Steven R. Hulland
CH 701, Amado, AZ
Posted: Sat Mar 18, 2006 7:03 am Post subject: Cable ties (Use PVC instead) |
" How do I tie the bundle of wires in the middle of that hole as suggested
trim wire fished into the side of that PVC pipe? "
I suggest using soft aluminum tubing for conduit. You can choose from
several sizes to use the smallest (lightest) one that will do. Scott's
brackets look like a good way to avoid drilling extra holes through the ribs
(except for a couple of rivet holes for the bracket of course). I also
suggest snap bushings in the bracket to reduce wear on the tubing from
vibration (lighter and easier to slide the tubing through).
As for the second wire from the aileron trim, run a second small daimeter
tube using a second hole in those same brackets. One of the reasons I like
the aluminum tubing is that it can be formed to any reasonably gentle curve
you desire. That allows you to bring the end of the tube at the wingtip, for
instance, right to the underside of the postion light/ strobe fixture incase
you ever need to access the end of the tube again through the fixture hole.
Also, the wire is supported all the way along its run. Pull the wire through
before forming to help minimize kinking. The stuff is available from
Aircraft Spruce.
Ed Moody II
Rayne LA
Posted: Sat Mar 18, 2006 8:27 am Post subject: Cable ties (Use PVC instead) |
Hi Don:
Not sure what you mean by a main rib. My XL wings go
all the way to the fuselage and the PVC passes through
all of the ribs. This photo may show it better:
http://www.cooknwithgas.com/3_1_04_SomePlumbing.JPG
You can also see from this picture that I have
grommets installed for the trim wire. I haven't
installed the trim wire yet so I'm not dead set on
this yet.
For the passage through the center spar under the
yoke, I use split loom and use a cable clamps to hold
it in place.
The stiffners on the ribs are just for extra support
because it was easy to do. The weight is
insignificant. We will know soon enough how much my
airplane weighs since I'll be weighing it soon. Today
I plan to weigh the engine and I'll report on that.
SL
Hello Scott:
pmaxpmax(at)hotmail.com Guest
Posted: Sat Mar 18, 2006 9:07 am Post subject: Cable ties (Use PVC instead) |
No offense intended, but I think the "conduit" idea is overkill. Why not
just use simple grommets from the hardware store penetrating the wing rib.
If you are worried about the wire moving back and forth through the grommet,
just put a wire tie on either side of the grommet. This is common practice
in penetrations through sheet metal. There should only be a couple of wires
going throug each grommet anyway.
Phil Maxson
N601MX
XL/Corvair
3 hours on the Hobbs.
| Quote: | From: "Edward Moody II" <dredmoody(at)cox.net>
Subject: Re: Cable ties (Use PVC instead)
I suggest using soft aluminum tubing for conduit. <<SNIP>>
gboothe(at)calply.com Guest
Posted: Sat Mar 18, 2006 9:15 am Post subject: Cable ties (Use PVC instead) |
I think his idea was routing and/or re-routing of wires in the future. Not a
bad idea for those of us who want to build a more simple aircraft with the
option of updating later.
Gary Boothe, Cool, CA
<gboothe(at)calply.com>
601HDSTD, WW Corvair Conv. - complete
Tail Group - complete. Working on wings...
Posted: Sat Mar 18, 2006 9:19 am Post subject: Cable ties (Use PVC instead) |
" No offense intended, but I think the "conduit" idea is overkill."
No offense taken Phil. I think a Corvair engine conversion is overkill in
pusuit of economy. That's why they're called experimental aircraft.
Ed
mountain4don
Posted: Mon Mar 20, 2006 6:43 am Post subject: Cable ties (Use PVC instead) |
Hello Scott,
The PVC makes your wing look very clean inside. Not much extra stuff like I seem to have. Where I am having trouble tying the wires down is after they pass up the wing through the main ribs in grommets, they make a turn and go through a lightening hole in the main spar extention, just like you will have to do after they come out of the end of your PVC. I have the flasher unit mounted on the back side of the main spar like the instructions from ZAC have it. And if I ever had to remove the wingtip marker lights, I can take out the headlight, reach in through the headlight hole and unplug the wires from the flasher light and running light, and remove the socket from the end of the wing. So I was looking for a removal method of strapping down the wires through the lightening hole.
Any chance of coming over sometime and looking at your plane. You are much farther along than I am. And I need all the help I can get on the stuff not included in ZAC's instructions.
Don
this yet.
it in place.
Brings words and photos together (easily) with
