Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Sat Jan 17, 2009 6:54 pm Post subject: Another Windshield Install Question |
I didn't want my question to get lost in the other windshield install post so I'm making another one.
I will be installing my windows soon and am wondering if once the windshield is clamped into place can you apply heat with heat lamps at a distance so the lexan would take the shape of the bend. It seams like a mild heat would make the lexan take the new shape and therefore would not have continuous strain on the rivets. Maybe this happens naturally over time, out in the sun. Whats ya think?
Rick Lewis
Posted: Sat Jan 17, 2009 7:16 pm Post subject: Another Windshield Install Question |
| Quote: | I will be installing my windows soon and am wondering if once the
Rick Lewis
Hi Rick L:
The way I see it, a rivet, if pulled properly, will always be under strain,
no matter what the application. My experience, after installing and
removing many of my own Kolb windshields, is the Lexan will not necessarily
take on the shape it has been in after many years. I would not use heat on
Lexan to stress relieve it.
_________________ John Hauck
Titus, Alabama |
Posted: Sat Jan 17, 2009 7:47 pm Post subject: Another Windshield Install Question |
| Quote: | I will be installing my windows soon and am wondering if once the windshield is clamped into place can you apply heat with heat lamps at a distance so the lexan would take the shape of the bend. It seams like a mild heat would make the lexan take the new shape and therefore would not have continuous strain on the rivets. Maybe this happens naturally over time, out in the sun. Whats ya think?
Rick Lewis
Rick,
My MkIII spent this last summer on my large flatbed trailer, outside, in the sun, with a 10 mil black visqueen cover. I was building my shop at the time.
My windshield was installed with clecos only. I checked underneath the visqueen a couple of times, and the heat was phenominal! My guess would be it was 160 degrees in there. Maybe more!! I had spiders and bugs that crawled in the fuselage, and immediately died from heat exhaustion.
The main point I'm making is that the windshield was so hot you could literally fry an egg on it.
A few days ago I unclecoed it, and took it off, to get ready for some fuselage paint. It has a slight curve to it. After a few months of unmercifully hot, scorching, black visqueen covered heat, it barely has a curve in it.
What this tells me is , is that for you to obtain any "real" curve to it, like enough to relieve the stress on the rivets, this would take an enourmous EVEN heat. I can not imagine you could do it without ruining the clarity.
My advice would be to not try it. Can it be done under very precise controlled conditions, yes. But, can you that at your shop? Probably not, and darn sure not for the trouble, the risk, or the gain.
Shaping and forming Lexan, Plexiglass, and other polycarbinates can be done, but it is usually by large commercial operations. You have to have an exact shape you are after, heat the Lexan laying over your shape, to a precise temperature for a few hours, and let it slowly mold itself onto the final shape you want. Rather involved. Not impossible, just a lot of work.
Just my opinion,
Mike Welch
MkIII
Windows Live™ Hotmail®: Chat. Store. Share. Do more with mail.
http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_hm_justgotbetter_howitworks_012009
Posted: Sat Jan 17, 2009 8:00 pm Post subject: Another Windshield Install Question |
Rick Lewis
Rick,
Oh yeah, one more thing. I noticed that when my windshield was clecoed in place, it has a slight
ability to "indent" (flex in), if you push down hard enough in the middle. The slight curve of the mounting may give the windshield an extra resistance to denting due to the airstream pushing down on it.
If you took away some of the induced strength of this curved mounting method, by preshaping it, I think it might be more likely to indent.
Just my thoughts on the matter,
Mike Welch
Windows Live™: Keep your life in sync.
http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_012009
Posted: Sun Jan 18, 2009 7:59 am Post subject: Another Windshield Install Question |
At 06:54 PM 1/17/09 -0800, you wrote:
Rick,
A few years back I was involved with the design and construction of TV
component manufacturing equipment. We hid numerical controls in out of the
way places and to protect them from dust and moisture we used thin lexan
covers. These covers were mechanically formed up using sheet metal forming
equipment. Thin lexan will form a permanent right angle bend with out
cracking.
I believe that if you used some blankets for surface protection and a few
two by fours on a smooth garage floor, plus the front wheel of a car, you
could bend your windshield to the desired curvature.
Before trying heat, I would check out what it does to a piece of scrap.
Jack B. Hart FF004
Winchester, IN
