Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Mon Jan 05, 2009 4:28 pm Post subject: C90 Brakes |
I am about to order the brakes for my Kolb M3X and am wondering if the C90 brakes, that Kolb offers, is adequate. Looking at them they seem kinda of wimpy. What are the pro and cons? I really like the neat installation but wonder if they will do the job.
Rick Lewis
Description: |
Filesize: |
195.34 KB |
Viewed: |
409 Time(s) |
JetPilot
Posted: Mon Jan 05, 2009 4:47 pm Post subject: Re: C90 Brakes |
I have those brakes by Obrien, and they are not strong enough in my opinion. There are times when I am pressing on the pedals about as hard as I can just to get normal deceleration, I can not stop quick with them.
They have been very trouble free and work perfectly, I have not had to touch the brakes in 2 years, but my MK III just needs more braking power than they are capable of.
Mike
Kolb MK-III Xtra, 912-S |
sspence801(at)sbcglobal.n Guest
Posted: Mon Jan 05, 2009 5:05 pm Post subject: C90 Brakes |
I have the same opinion about my Obrien brakes. In fact they don't want to hold the plane inplace on pavement for even a modest run-up of 3000 rpm. I went to the Matco eminar at Airventure, the speaker suggested that major factor in braking power is the geometry of the pedal to the master cylinder piston. I have thought about extending the toe of the pedal to exert more force/preasure on the calipers and enhance the stopping power.
Steve Spence
Auburn Hills, MI
M3X
Sent: Monday, January 5, 2009 7:47:19 PM
Subject: Re: C90 Brakes
--> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
They have been very trouble free and work perfectly, I have not had to touch the brakes in 2 years, but my MK III just needs more braking power than they are capable [quote][b]
ElleryWeld(at)AOL.COM Guest
Posted: Mon Jan 05, 2009 6:30 pm Post subject: C90 Brakes |
I Purchased that same set of brakes from TNK and installed them on my Firestar they work great I would install them on an Xtra with no hesitation
Ellery in Maine
In a message dated 1/5/2009 7:28:59 P.M. Eastern Standard Time, cktman(at)hughes.net writes:
New year...new news. Be the first to know what is making headlines.
Thom Riddle
Posted: Tue Jan 06, 2009 7:54 am Post subject: Re: C90 Brakes |
I test flew a re-assembled Challenger this past weekend. It had the Black Max brakes on it which I've heard were good and inexpensive. I can say with certainty that these Black Max brakes are outstanding and wish I had them on my airplane. See them at the following link.
http://flyfbi.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=FS&Category_Code=BKS
or
http://tinyurl.com/9mm3f9
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Dana
Posted: Tue Jan 06, 2009 10:24 am Post subject: C90 Brakes |
with certainty that these Black Max brakes are outstanding...
I have the Black Max brakes on my UltraStar and as Tony the Tiger says,
they'rrrre Grrrrreat!
Can't speak for the birds with larger engines, but they'll hold my US for a
full power runup with no trouble at all. Mine has Hegar heel brake master
cylinders, though, instead of FBI's single hand brake master cylinder.
-Dana
Giving money and power to government is like giving whiskey and car keys
to teenage boys.
Posted: Wed Jan 07, 2009 7:10 am Post subject: C90 Brakes |
Rick
Wow I thought you were selling your plane. It's super your still working on
it.
I have the stock Matco brakes and they will hold the plane at least till the
tail comes up with the stock wheel size. A bigger issue is how the brake
peddle to master cylinder leverage is configured. With toe peddles you are
pushing against the rudder peddles and the bigger concern the rudder cables
during brake activation. I have the heal peddles but I understand Paul Petty
had a arrangement with more mechanical advantage. This may be the same set
up that Mark German developed.
Rick Neilsen
Redrive VW Powered MKIIIC
Rick Lewis
Posted: Sun Jan 18, 2009 3:32 pm Post subject: Re: C90 Brakes |
Thanks for all the input on this. I believe I will be going with the Matco brakes with a 6" tire instead of the 5". I will also modify the ratio of the brake pedal as I saw some time ago that this may be a problem, 1:1 just won't do it.
Rick Lewis
sky-king(at)inbox.com Guest
Posted: Mon Jan 19, 2009 4:43 pm Post subject: C90 Brakes |
How do you change the ratio of the brake pedal?I think it would help me and maybe someone else
[quote] --
Rick Lewis
Posted: Mon Jan 19, 2009 4:55 pm Post subject: Re: C90 Brakes |
sky-king:
I have some idea's on how to change the ratio on the brake cylinders and when done I will post, with pictures. I don't really think it will be to hard, since I had to do this on another aircraft I buildt back in 1993. I'm going to try and make it so others will be able to adapt easily.
Rick Lewis
I'm editing this post to report the company that makes the C-90 brake recommends a ratio of 4:1. This is good information, will post more on this later. Check it out at http://www.tracyobrien.com/moreinfo.asp?id=46
JetPilot
Posted: Mon Jan 19, 2009 6:51 pm Post subject: Re: C90 Brakes |
I'm glad you are going to come up with a solution for the Matco Master cylinders also, even though the Obrien brakes are to small for the MK III Xtra, it would be nice if I did not have to press the pedals so hard to get normal braking.
It is very easy for me to get the Obrien brakes on my Kolb so hot that they fade at the end of a long taxi on pavement, leaving me almost no braking at all.
Mike
Posted: Mon Jan 19, 2009 7:05 pm Post subject: C90 Brakes |
Why reinvent the brake peddles. Paul Petty had a set that has more ratio in
his Kolbra. He posted photos that are likely in the archives. Seems like
there was even a video. If I remember correctly Mark German develop the
brake peddles and may have made a copy for Paul. The guys that now own one
of their planes are on the list.
Rick Neilsen
Redrive VW powered MKIIIC
Rick Lewis
Posted: Tue Jan 20, 2009 5:28 am Post subject: Re: C90 Brakes |
All I could find in the archives is the starting of the peddles he used, nothing else. If you or anyone can find anything on this it would be a great help to us all.
Rick Lewis
