Paul A. Franz, P.E.
Posted: Fri Jan 23, 2009 9:38 am Post subject: checking spark - voltage range on tester |
On Fri, January 23, 2009 8:46 am, patrick reilly wrote:
Roger, OK, I am sold. I Googled up the Greenlee tester. Yours (thanks for the picture)
is 50-1000 volts. Greenlee has 2 models, yours and a low voltage model for 12-90
volts. I would guess I want the low 12-90 volt model for our application. But, as I
stated, yours is the high voltage model. Does it work on 12 volt ignition systems?
This is an a/c tester (alternating current) so it won't detect DC voltage. The higher
voltage range is what I'd think you'd need for spark detection.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
patreilly43(at)hotmail.co Guest
Posted: Fri Jan 23, 2009 9:52 am Post subject: checking spark - voltage range on tester |
Paul C Thanks for the info. I wondered about the fact that it is an AC tester.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | Date: Fri C 23 Jan 2009 09:35:32 -0800
Subject: Re: checking spark - voltage range on tester
--> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com>
On Fri C January 23 C 2009 8:46 am C patrick reilly wrote:
> Roger C OK C I am sold. I Googled up the Greenlee tester. Yours (thanks for the picture)
> is 50-1000 volts. Greenlee has 2 models C yours and a low voltage model for 12-90
> volts. I would guess I want the low 12-90 volt model for our application. But C as I
> stated C yours is the high voltage model. Does it work on 12 volt ignition systems?
Paul A. Franz
Bellevue WA
