Troy Maynor
Posted: Sat Jan 31, 2009 8:18 pm Post subject: Wing Walk Tape |
Hey Fellow Europa Folks,
Hope all are flying or building well. Question: for you that have put wing walk on, how wide a path is best up the wing? ACS sell some that is clear and is 16" x 30" and another variety that comes in 6" or 12" wide, sold by the lineal foot. I was thinking of buying one of the 16" x 30" and splitting it down the middle to do both wings. I think the clear or translucent would be preferable to white or black. White would most likely not be the matching shade to the white on the plane and black would cook the wing. Thoughts?
Troy Maynor
nwcmc(at)tiscali.co.uk Guest
Posted: Sun Feb 01, 2009 1:30 am Post subject: Wing Walk Tape |
I didn’t want to spoil the finish of the painted wing so I have a strip of lightweight rubber matting for those who wish to walk onto the wing. This is then rolled up and stored in one of the headrests. This only gets used for guest passengers as we enter the aircraft by sitting on the leading edge and then swinging our legs straight into the footwells. This requires a little more agility but is easy once mastered.
Nigel Charles
Posted: Sun Feb 01, 2009 6:43 am Post subject: Wing Walk Tape |
Hi! Troy
Mine are approx 9” wide and only pass about 12” in front of the spar. They are a very abrasive stick on type but I thought green looked inviting ……until I felt the wing on a sunny hot day. Then I had to spray them white!
Bob Harrison.
loboloda(at)execulink.com Guest
Posted: Sun Feb 01, 2009 7:14 am Post subject: Wing Walk Tape |
Hi Troy,
I do the the same as Nigel, using some non skid matting, that I think is intended to line cupboard drawers etc,
The wing walk stick ons soon start to look ratty.
Dave, C-FBZI - snowed in since the beginning of November....
Nigel Charles
paul.the.aviator(at)gmail Guest
Posted: Sun Feb 01, 2009 8:02 am Post subject: Wing Walk Tape |
Hi Folks
I do this on my XS, but while doing an annual this year I noticed
cracking in the paint. This area isn't designed for loads, and in my
case it is obviously causing an issue so I will have to go back to
wing walk tape. Classic wings might be stronger in this area and may
just be fine.
I weigh 170 pounds / 77 Kg
Paul
Nigel Charles
karelvranken(at)hotmail.c Guest
Posted: Sun Feb 01, 2009 10:14 am Post subject: Wing Walk Tape |
Hi Troy,
I used the two 16" x 30" clear of ACS. Your feet are not always in flight direction when embarking. My shoes are about 12"; when they are transverse on the direction 16" of wing walk is not to large.
Best regards,
Karel Vranken # 447 F-PKRL.
Posted: Sun Feb 01, 2009 11:01 am Post subject: Wing Walk Tape |
Hi Karel,
I used to have the original white wing walk tape that came from
Europa, but it got "dirty" looking after a while and no amount of
scrubbing would clean it. Does the clear stuff from ACS hold up any
better ?
| Quote: | Hi Troy,
Best regards,
budyerly(at)msn.com Guest
Posted: Sun Feb 01, 2009 12:31 pm Post subject: Wing Walk Tape |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Wing Walk area tapes are notorious about looking dirty with any other color but black. A piece of carpet with a rubber non stick mat sewn on the bottom works well. The non skid mat is a soft dimpled thin rubber material used by woodworkers for routing pads or sold in stores for use in kitchen sinks. Jerry Hope has a carpet piece of carpet about 10 inches wide by 20 inches long for the wing and an 8x12 for a seat protector when stepping in. Just brush it off when seated and throw in the back.
As for those nasty cracks in the filler due to flexing near the spar and wing fillet, only the extra layers of glass support can cure that. In the future, wings will have the rib numbers increased in this area and skin stiffed to provide for added stiffness for the not so svelte guys like me.
Bud Yerly
Custom Flight Creations.
Posted: Sun Feb 01, 2009 1:40 pm Post subject: Wing Walk Tape |
Paul,
Some people clean their plane after each flight, and perhaps it ought to be
so. I am rather of that kind who clean when there is no evidence to escape.
Sometimes you will see footprints on the walk tape but cleaning is not a big
problem. The problem is that I can't compare with other materials due to
lack of experience.
Best greetings,
Karel Vranken.
rick(at)amimotormanagemen Guest
Posted: Mon Feb 02, 2009 3:59 am Post subject: Wing Walk Tape |
Hi Bud
I've always used the bottom on leg swing method but recently (500 hours) I've noticed two 6" cracks in the paint on the top spar line about 8" out from the wing fillet. My inspector is slightly worried and says he will talk to Andy about it. Have you seen much of it?
Cheers
Rick
G-RIKS Tri 500 hours.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of ALAN YERLY
Sent: 01 February 2009 20:23
Subject: Re: Wing Walk Tape
Bud Yerly
Posted: Mon Feb 02, 2009 6:50 am Post subject: Wing Walk Tape |
Hi! Rick.
My classic wing was built with a multi bid layer behind the wing spas and slightly forward of the spa to take the weight of feet , I guess the quick build skinned wings will have less numbers of bid lays for “bony bums”? However the down side is that on a trike with the onset of the persons age it does get to be a challenge to not tread on the flap and sometimes with a full compliment of fuel the a/c tends to tip back.
Bob H G-PTAG
Posted: Mon Feb 02, 2009 7:09 am Post subject: Wing Walk Tape |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Yes, for those of you who enter from the leading edge, the forward D tube of the wing is foam and glass sandwich only supported by the root rib and the next rib is nearly 16 inches further outboard. I'm afraid the flexing of this area means any filler in that area will crack. The depth of the filler is quite thick here due to the transition from the wing fillet. That is why I have started to add glass layers over the filler from the fillet outboard to try to stiffen this area. The inner structural glass will hold up to our butts sitting here, but the filler won't. I'm afraid the area needs a couple more ribs to prevent this as was done on the trailing edge walk area.
Bud
fklein(at)orcasonline.com Guest
Posted: Mon Feb 02, 2009 8:15 am Post subject: Wing Walk Tape |
On Feb 2, 2009, at 7:02 AM, ALAN YERLY wrote:
| Quote: | | the forward D tube of the wing is foam and glass sandwich only supported by the root rib and the next rib is nearly 16 inches further outboard. I'm afraid the flexing of this area means any filler in that area will crack. The depth of the filler is quite thick here due to the transition from the wing fillet. That is why I have started to add glass layers over the filler from the fillet outboard to try to stiffen this area. |
Bud,
After following this thread, I'm tempted to suggest another possible solution.
I have some 1/8 inch Lastafoam; after sanding off the gelcoat, I could bond a piece say 6 inches wide and say 10 inches (fore and aft) onto the top of the D tube abutting the edge of the wing root fairing...then sanding it down (inboard) level with the thickness of the fairing and carefully feathering it down to nothing (outboard)...this would avoid excessive depth of filler...then cover what's left of the foam w/ some FG, say 2 layers of BID lapping over the wing root fairing.
Caution, of course, should be observed for any alteration of the airfoil, but conceptually, one would strive to maintain what results from the use of filler in this area...merely substituting foam for filler.
Your reaction?
Fred
PS: I appreciated your post a while back which cautioned against any attempts to close the trim tab control arm slots in the fuselage, saving me some time and potential grief...thanks!
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. [quote][b]
Posted: Mon Feb 02, 2009 9:04 am Post subject: Wing Walk Tape |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Fred,
A foam core would work but filler would be more solid and resist those high heels.
In my answer to Ron Parigoris on my experiment:
My use has been with standard 7725 Bid, two layers on the bias. That is the strands run at 45 degrees to the wing root rib.
To stiffen the area, once the fillet is on and filled, then add layers on top, peel ply, then fill again. You can use flox as the filler but expand cell will do. Figure it this way. The filler is now another core material. That makes a very stiff core and will aid in making the elasticity lower. If you add carbon fiber rather than E glass, it will make it even more stiffer as the carbon will make the layer nearly rigid..
I do not know without building a panel if the carbon is more effective. Flox and carbon would prevent a Stilleto heel from going through the skin, but at what cost in weight. A layer of carbon then filler then more carbon would be super hard, very ridged and cost about another $200 in material...
This only need be done for the guy who puts weight ahead of the spar. Behind the spar is OK for the tail dragger crowd. Just don't put your foot beyond the spar.
Bud.
Posted: Mon Feb 02, 2009 10:58 am Post subject: Wing Walk Tape |
ALAN YERLY wrote:
| Quote: | If you add carbon fiber rather than E glass, it will make it even
Bud.
Bud
trouble is the carbon will take all of the load because of it's very
high modulus, that will tend to create a sharp discontinuity in strength
at the edge of the carbon.
Graham
Posted: Mon Feb 02, 2009 12:43 pm Post subject: Wing Walk Tape |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Exactly right Graham, but the force I am trying to fix is not a flight load but just a wing surface plate skin stiffness for my wide butt. If I were to use carbon fiber, the joint needs to be tapered in to where the next rib is. That rib will relieve some of the discontinuity of the carbon/glass interface. The loaded outer skin compression over the rib should take the discontinuity.
I too believe the best fix is to use E or S glass and epoxy as a band-aid fix. The real fix is to add ribs and change the glass layup sequence to add more surface stiffness for those Stilleto heels and boney butts.
For those following this, anytime that you add carbon fiber to a glass surface, all the load is transferred to the strongest element i.e. the glass fiber, and the epoxy is for a better word, a bonding agent. If you put a layer of carbon on glass, the carbon then will take all the load until the point where the epoxy bonds surrounding the carbon fail, then the glass would pick up the load (probably to failure). In the case we are discussing above, this may result in a complete de-lamination of that stiff carbon sheet which is only held on by the filler/foam or whatever between it and the glass skin or worse yet a buckling of the skin and failure. Glass epoxy structures are interesting animals in that in the event of an extra layer of carbon is put over the glass, the difference in stiffness (modulous of elasticity) will cause a stress riser at the edge of the carbon layer. This can cause numerous problems. The outer skin of the Europa XS is for shape and stiffness. It is not a heavy weave like the Classic wing. Under loading, the upper skin is under compression and as the glass takes up the load, a sudden junction of very stiff carbon can cause the skin to wrinkle or even debond under compression. The area over the rib is transferring some of it's shear load to the rib and is somewhat less stressed, so in my opinion, this would be an acceptable place to make the transition. (Look at the wing in loading some time and you can see every rib at 3 gs as the glass upper surface in compression slightly bends under the compression load.) In my education on aircraft structures, it was always drummed into our heads that the common failure mode in aircraft is a compression failure due to buckling. Glass structures are designed to take the compression and sheer loads together through the orientation of the fibers. Most of the strength of a wing is that shell. The tension loads that are easily carried by the lower wing skin, through the strands of glass oriented at anywhere from 0-30 degrees, allow some of the linear stress to be taken by the shear load of the D tube and transferred by contact and ribs to our extremely overbuilt (thankfully) main spar and of course the upper skin.
As I said and Graham has eluded to: Without testing on the panel, we will never know for sure. The theoretical solutions for analyzing glass/epoxy structures is beyond my shops time and money. That is why my bandaid is bid cloth over the skin tapered to the first rib from the root. The thicker, now double sandwich will make that hollow leading edge a little stiffer and the glass over the top of the filler may preclude those cracks in the filler made by the depression of that skin on the forward D section.
Just my opinion.
Bud
johnwigney(at)windstream. Guest
Posted: Mon Feb 02, 2009 1:07 pm Post subject: Wing Walk Tape |
Hi Troy,
You might want to consider an inexpensive material which I used. I
bought a roll of plain white self-adhesive kitchen drawer liner
(hardware store supply). As I remember, I applied it about 10 inches
wide ahead of the flap on each side. It is inexpensive and surprisingly
durable. Mine have been on since Day 1 and are still in good condition
after 7 years.
Noting that frost will destroy lift on a wing, I have never been keen on
the idea of a rough wing walk surface and this is why I chose the smooth
surface. I have never slipped on it in the wet and also, for those
people wanting that extra knot??, it is definitely low drag.
Cheers, John
ORIGINAL MESSAGE
Subject: Wing Walk Tape
Troy Maynor
jeff(at)rmmm.net Guest
Posted: Mon Feb 02, 2009 1:30 pm Post subject: Wing Walk Tape |
HI Troy,
For what it's worth I've never used anything other than making sure
nobody gets on the wing feet first or with jeans of the old fashion
back pocket rivets. Just sit on and swing legs in has worked and my
wings still look perfect. If you put wing walk on you may be asking for
the wing walk from some unknowing sole.
Just a thought...
Best Regards,
Jeff R.
A258 - N128LJ / Gold Rush 176 hours and climbing slowly.
On Feb 2, 2009, at 3:05 PM, John & Paddy Wigney wrote:
<johnwigney(at)windstream.net>
Hi Troy,
surprisingly durable. Mine have been on since Day 1 and are still in
good condition after 7 years.
on the idea of a rough wing walk surface and this is why I chose the
smooth surface. I have never slipped on it in the wet and also, for
those people wanting that extra knot??, it is definitely low drag.
Cheers, John
ORIGINAL MESSAGE
is
wide,
Troy Maynor
jrgowing(at)bigpond.net.a Guest
Posted: Mon Feb 02, 2009 1:56 pm Post subject: Wing Walk Tape |
Good one Jeff!
JR
Posted: Mon Feb 02, 2009 2:40 pm Post subject: Wing Walk Tape |
ALAN YERLY wrote:
| Quote: | I too believe the best fix is to use E or S glass and epoxy as a
boney butts.
Just my opinion.
Bud
Bud
you described the issue much better than I could, your opinion is valued
Graham
