nfivesl(at)yahoo.com Guest
Posted: Mon Mar 20, 2006 1:00 pm Post subject: Motor (0-290 Engine) |
Here's what zenithair.com says on the 601XL engine
page:
"While all aircraft are designed within certain power
and engine weight guidelines, Chris Heintz did not
design the ZODIAC XL "around" a particular engine - to
maximize the customer's choice of installed
powerplant. Recommended power is 80 to 125
horsepower, up to 300 lbs. installed weight."
140 horsepower exceeds the recommended power.
Scott Laughlin
www.cooknwithgas.com
| Quote: | Unternaehrer" <shilocom(at)mcmsys.com>
>Does anyone have any knowledge of whether the
Lycoming O-290 will work in the Zenair 601 XL.
frank.hinde(at)hp.com Guest
Posted: Mon Mar 20, 2006 1:24 pm Post subject: Motor (0-290 Engine) |
I honestly think an XL with 140HP would be just fine...I mean there are
RV's flying around with over 300 and they are designed for 200HP max.
I was considering a 150HP conversion for the HDS for a while. Simply
means I will get off the ground in a hurry and cruise higher/faster.
The real question is the weight...if you think about it, the shock
loading on the engine mounts druing a hard landing is much more arduous
for the airframe than a bit of extra pull and torque reaction.
So how much does this beasty weigh?
Frank
Posted: Mon Mar 20, 2006 1:52 pm Post subject: Motor (0-290 Engine) |
263 lbs according to the website posted earlier.
--- "Hinde, Frank George (Corvallis)"
| Quote: | So how much does this beasty weigh?
Frank
shilocom(at)mcmsys.com Guest
Posted: Mon Mar 20, 2006 3:10 pm Post subject: Motor (0-290 Engine) |
Not really sure on the weight. It's still in pieces, but suspect is well
under 300, but wonder if the 300 lbs is firewall forward, including prop,
cowl etc. etc. I'm thinking it should be around 260 motor and accessories,
then add prop and cowl and motor mount. Bob U.
mijniljj(at)yahoo.com Guest
Posted: Mon Mar 20, 2006 5:23 pm Post subject: Motor (0-290 Engine) |
i think it would be about 235 lb, an o320 is 243lb and
the 036 is 265 lb.
Jim
