etienne.phillips(at)gmail Guest
Posted: Wed Feb 04, 2009 1:39 pm Post subject: Old transponder interface details |
Hi All
I'm building a converter from the serial protocol used by Garmin to
the old Gilham encoding used by the older transponders. I'm lacking
detail on the voltages used to send a transponder the encoded
altitude. I'm using a old Narco AT 150 TSO... The binary values for
each pin is pretty much done, so I'm looking for the electrical
details now.
Can anyone help me out?
Etienne
jdubner(at)yahoo.com Guest
Posted: Mon Feb 16, 2009 12:35 pm Post subject: Old transponder interface details |
Etienne,
The transponder inputs are TTL logic levels with inverted polarity
(active low). The converter should use open collector outputs as all
encoders do AFAIK but I don't see any problem using active outputs
unless you intend to parallel additional encoders.
I built a similar converter some years ago and you may find something it
it that is helpful.
http://www.mail2600.com/EncoderConverter/EncoderConverter.html
Best,
Joe
Independence, OR
Aircraft Position: http://www.mail2600.com/position
Aircraft Last Track: http://www.mail2600.com/track
Etienne Phillips wrote:
<etienne.phillips(at)gmail.com>
Hi All
I'm building a converter from the serial protocol used by Garmin to the
old Gilham encoding used by the older transponders. I'm lacking detail
on the voltages used to send a transponder the encoded altitude. I'm
using a old Narco AT 150 TSO... The binary values for each pin is pretty
much done, so I'm looking for the electrical details now.
Etienne
Posted: Mon Feb 16, 2009 10:18 pm Post subject: Old transponder interface details |
That is most useful. Thanks very much!
2009/2/16 Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com)>
[quote]--> AeroElectric-List message posted by: Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com)>
Etienne,
The transponder inputs are TTL logic levels with inverted polarity (active low). The converter should use open collector outputs as all encoders do AFAIK but I don't see any problem using active outputs unless you intend to parallel additional encoders.
I built a similar converter some years ago and you may find something it it that is helpful.
Best,
Joe
Independence, OR
| Quote: | --> AeroElectric-List message posted by: Etienne Phillips <etienne.phillips(at)gmail.com (etienne.phillips(at)gmail.com)>
Hi All
I'm building a converter from the serial protocol used by Garmin to the old Gilham encoding used by the older transponders. I'm lacking detail on the voltages used to send a transponder the encoded altitude. I'm using a old Narco AT 150 TSO... The binary values for each pin is pretty much done, so I'm looking for the electrical details now.
Etienne
ref="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
p; -Matt Dralle, List Admin.
Posted: Wed Feb 18, 2009 3:56 am Post subject: Old transponder interface details |
Hi Joe
I noticed that the encoding is somewhat different to Gray coding, despite the terms Gilham and Gray being used interchangably in all the aviation documentation.
As far as I know, Gray code is constructed by applying the -1200 offset, taking the binary value, and XOR-ing it with the same binary right-shifted by one position. All is well for the first few values, but after the 5th value (-800 odd), the two codes diverge, with Gray being 000000111, and Gilham being 000000100...
Do you by any chance have the method for generating Gilham code? I've spent days looking for it on the web, but without any success! I've also tried to distill the solution looking a the table on your website, also without any joy.
Etienne
2009/2/17 Etienne Phillips <etienne.phillips(at)gmail.com (etienne.phillips(at)gmail.com)>
[quote] That is most useful. Thanks very much!
| Quote: | --> AeroElectric-List message posted by: Joe Dubner <jdubner(at)yahoo.com (jdubner(at)yahoo.com)>
Etienne,
Best,
Joe
Independence, OR
Hi All
Etienne
