TXYak
Posted: Thu Feb 26, 2009 7:05 am Post subject: Voltage Regulation |
Question regarding Voltage Regulation in a Yak 52.
First, this is a project airplane and has not been flown yet in the US. I have gotten it running, but have no voltage regulation. When I first started it, I had the Gen Fail light at low RPM...as I increased power (at) 40% the light went out(started charging) Around 45% the Gen Fail light would come back on and pop the overvoltage breaker. I connected a voltmeter to the DMR-200 as I ran it even if I adjusted the regulation screw...I got no change in voltage. Volts increase with throttle until 45%RPM and kicks Gen offline at (at)30.5 volts. I have tried another voltage regulator(it had been sitting for 6-7 years unused) got the same symptoms.
Can anyone recommend more places to look, as most of you have a better understanding of this electrical system than I do. My level of frustration is tempting me to go with a B & C alternator/regulator. Any advice for or against. If there is a problem in the system somewhere elsse...I don't want to start frying B & C's.
Chris Keating
Posted: Thu Feb 26, 2009 4:34 pm Post subject: Voltage Regulation |
Your problem is... As you have said, ....is clearly a voltage regulation
issue. Your generator is working fine, but is not regulating what-so-ever.
In this mode of operation, the voltage will increase as the speed of the
generator increases. Your over-voltage protection is merely doing it's job
which is a good thing.
Nothing wrong with B&C products. If ease of getting parts and weight is an
issue, go that route! I would not advise the small PMG 10 amp model unless
you seriously think you need it. The bigger 35/45 amp model is the best
investment.
As for fixing yours... Since you tried a new voltage regulator, I suspect
that is not the problem. So it's bound to be a wiring problem. OR.. And
this is the first thing I would check... You have a bad voltage control
potentiometer in the cockpit. Rule of thumb. In electrical systems, things
that fail first usually either move, or are something that human hands mess
with! You need to get a meter and someone who knows how to use it. Ring
out the wiring from the voltage regulator back to the voltage control
resistor in the cockpit and read through it to see if it is working
correctly.
If that checks OK, then check the wiring from the voltage regulator BACK to
the generator (the middle wire on the generator terminal board).
Really.... Going into each and every wire would be too difficult over the
internet and with the written word. There should be a fairly good diagram
pasted to the cover that goes over the electrical panel .. I hope you know
where that is.
If you give up, there is nothing really in the aircraft that will end up
damaging a new B&C system. Most of what is in there is just BY-PASSED and
removed. The over-voltage device, the bucking transformer, the regulator,
the main contactor relay... All come out. You just end up connecting the
output voltage of the new system directly to the output bus bar of the main
contactor relay.
Mark Bitterlich
 Download |
| Filename: |
smime.p7s |
4.81 KB |
| Downloaded: |
496 Time(s) |
gill.g(at)gpimail.com Guest
Posted: Fri Feb 27, 2009 9:57 am Post subject: Voltage Regulation |
This maybe generator related. I would check the generator brushes and
springs. Make sure brushes are clean, move easily and are seated and brush
springs are properly installed.
Gill
Posted: Fri Feb 27, 2009 12:53 pm Post subject: Voltage Regulation |
Gill, with respect... If the generator puts out voltage, and the gen
light goes out when the engine RPM is increased past 40%, and then the
over-voltage circuit breaker pops at 30-31 volts, this is not a brush or
spring problem.
If the brushes or springs are completely bad, (either / or) you will
have no voltage at all out of the generator. If a spring is weak, you
will have intermittant voltage. I.E.: It will be turning on and off
rapidly.
Brushes and springs push against the commutator windings taking the AC
output of the windings and essentially giving you a DC output. Thus the
brushes and springs are critical to the generator putting out any output
AT ALL.
This is a regulation problem dealing with the probable loss of field
current from the voltage regulator.
For a complete understanding of the theory involved here, you might want
to check out this site.
http://www.rowand.net/Shop/Tech/AlternatorGeneratorTheory.htm
Mark Bitterlich
Posted: Fri Feb 27, 2009 1:34 pm Post subject: Voltage Regulation |
Mark,
The problem originally described was that the generator light went off at
the normal point and then came on with increasing RPM, this suggests that
brushes may not be making solid contact and should be easily checked as
previously suggested. I am not there so the mic (mechanic in command) will
have to decide.
Gill
TXYak
Posted: Fri Feb 27, 2009 5:11 pm Post subject: Re: Voltage Regulation |
Thanks for the replies. I'll follow up on Monday or Tuesday after I get back in town.
Chris Keating
TXYak
Posted: Tue Mar 17, 2009 5:46 am Post subject: Re: Voltage Regulation |
Well, I finally gave up on the Russian system after chasing wires and trying 3 different voltage regulators. I installed the 35 amp B & C alternator and regulator. Thanks to Mark Bitterlich for the technical advice. He made it an easy installation. Was able to remove 42 lbs. and replace it with 6.5 lbs.
Chris Keating
yakplt(at)yahoo.com Guest
Posted: Tue Mar 17, 2009 3:47 pm Post subject: Voltage Regulation |
Thanks Chris, that was nice to say.
Mark Bitterlich
To: yak-list(at)matronics.com
Sent: Tuesday, March 17, 2009 9:47:00 AM
Subject: Re: Voltage Regulation
--> Yak-List message posted by: "TXYak" <CKeating(at)peoplepc.com (CKeating(at)peoplepc.com)>
Chris Keating
http://forums.matronics.com/viewtopic.php?p=234964#234964[b]
