Posted: Sat Feb 28, 2009 8:21 am Post subject: Installing Hartzell prop on IO540 |
Does the metal cup pressed into the end of the crank have to be removed
before installation of the constant speed prop?
I assume that cup is in place for fixed pitch props. But I can't find a
specific reference to the need or procedure for removing it in the
documentation. Even reading the procedure for changing between constant
speed and fixed configurations doesn't directly address removal of the
metal cup.
Thanks in advance
Bill
jim(at)CombsFive.Com Guest
Posted: Sat Feb 28, 2009 8:32 am Post subject: Installing Hartzell prop on IO540 |
Yep, I needs to be removed. Oil from the prop governor gets to the prop via the center of the crank shaft.I don't the methods used to remove it.Jim CN312F - Flying (Phase I - 38.2 Hours!)--> RV10-List message posted by: Bill Mauledriver Watson<MauleDriver(at)nc.rr.com>Does the metal cup pressed into the end of the crank have to be removedbefore installation of the constant speed prop?I assume that cup is in place for fixed pitch props. But I can't find aspecific reference to the need or procedure for removing it in thedocumentation. Even reading the procedure for changing between constantspeed and fixed configurations doesn't directly address removal of themetal cup.Thanks in advanceBill [quote][b]
bgill1(at)charter.net Guest
Posted: Sat Feb 28, 2009 8:33 am Post subject: Installing Hartzell prop on IO540 |
Hi Bill:
I attached a copy of the Lycoming SI1435 that should cover it pretty
well. I went through the same questions. If it doesn't show up you can
search the nes and locate it.
Byron
N253RV Assigned
Description: |
 Download |
Filename: |
SI1435.pdf |
Filesize: |
307.34 KB |
Downloaded: |
1061 Time(s) |
Posted: Sat Feb 28, 2009 8:34 am Post subject: Installing Hartzell prop on IO540 |
Aahhh, nevermind. I've re-read SI-1435 a third time and see that I must
"Remove expansion plug for Constant Speed operation". Seems pretty
clear now.
Thanks.
removed before installation of the constant speed prop?
a specific reference to the need or procedure for removing it in the
constant speed and fixed configurations doesn't directly address
removal of the metal cup.
Thanks in advance
Bill
Posted: Sat Feb 28, 2009 8:42 am Post subject: Installing Hartzell prop on IO540 |
I don't know the method to remove it either. Drill a hole and pry seems
crude. Looks like it has some sealant on it.
Thanks.
jim(at)CombsFive.Com wrote:
Quote: | Yep, I needs to be removed. Oil from the prop governor gets to the
Jim C
metal cup.
Thanks in advance
Bill
Posted: Sat Feb 28, 2009 8:43 am Post subject: Installing Hartzell prop on IO540 |
Another comment, I have a used engine from a Piper Aztec. The prop on the Aztec goes to full feather on low oil pressure (Course Pitch / Low RPM). The Hartzel prop used on our application goes to fine pitch / high RPM on low oil pressure. With the Aztec governor, we were able to cycle the prop at low RPM on the ground during run-up, but not in flight. Changing the governor for the MT unit from Vans solved the problem. Jim Combs 40192 - N312F - Flying [quote][b]
dlm46007(at)cox.net Guest
Posted: Sat Feb 28, 2009 9:42 am Post subject: Installing Hartzell prop on IO540 |
Yes remove it.
Posted: Sat Feb 28, 2009 9:46 am Post subject: Installing Hartzell prop on IO540 |
I believe we used slotted screwdriver to punch a hole and it came out easily.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com
Sent: Saturday, February 28, 2009 9:30 AM
Subject: Re: RV10-List: Installing Hartzell prop on IO540
Jim C
metal cup.
Thanks in advance
Bill
Posted: Sat Feb 28, 2009 10:03 am Post subject: Installing Hartzell prop on IO540 |
If I remember right ...... Along with removing the front plug, you
must also put in the aft plug. In the fixed-pitch mode, oil flows past
the nose bearing into the hollow crank and back out through a hole next
to the #1 crank throw. With the constant speed, you need to pressurize
that hollow part of the crank .... hence the aft plug. Since I've never
played with an IO-540 before I may just be blowing smoke, but .......
Linn
must "Remove expansion plug for Constant Speed operation". Seems
pretty clear now.
Thanks.
> find a specific reference to the need or procedure for removing it in
> the documentation. Even reading the procedure for changing between
> Thanks in advance
> Bill
Checked by AVG - www.avg.com
toaster73(at)embarqmail.c Guest
Posted: Sat Feb 28, 2009 1:37 pm Post subject: Installing Hartzell prop on IO540 |
Funny you mention this I just finished putting the prop on to do cowling
/spinner fitting and went through the same questions last night. My Van's
IO-540 came with a sheet of warnings one of which was to remove the plug,
but no method. I found in archives where someone used a dent puller, I'll
probably punch a hole and then use the dent puller if its stubborn.
-Chris
#40072
AirMike
Posted: Sun Mar 01, 2009 12:12 am Post subject: Installing Hartzell prop on IO540 |
Oppps - Is that why my prop doesn't cycle ???????????
_________________ See you OSH '18
Q/B - sold. |
hotwheels
Posted: Sun Mar 01, 2009 6:29 am Post subject: Re: Installing Hartzell prop on IO540 |
Also related... I had to remove a prop flange bushing to drill holes in the case for LSE crank sensor plate mount as my engine didn't have any bracket holes. It sounds pretty scary, but wasn't actually too bad.
When I went to install the prop, it was discovered that several bushings were caked with junk and needed to be rethreaded as they started coming out when the bolts were tightened. I called Lycoming and they said it was okay to re-tap if needed.
I came across Lycoming Prop Flange Bushing Location doc SI1098G (attached) which explains proper location and type of bushing required for different flanges.
Jay
Cowl hell
Description: |
 Download |
Filename: |
Lycoming Prop Flange Bushing Location SI1098G.pdf |
Filesize: |
836.17 KB |
Downloaded: |
517 Time(s) |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Sun Mar 01, 2009 4:06 pm Post subject: Re: Installing Hartzell prop on IO540 |
jayb wrote: | Also related... I had to remove a prop flange bushing to drill holes in the case for LSE crank sensor plate mount as my engine didn't have any bracket holes. It sounds pretty scary, but wasn't actually too bad. |
I got a couple 1.5" bolts and center drilled 2 of them I used them as a centering guide for the tap drill. Once drilled, remove the bold and tap the hole with a bottoming tap. I was able to get 5 holes using this method. Have not started the engine yet but I believe I got a really good fit without having to remove any bushings.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Posted: Fri Mar 06, 2009 7:44 pm Post subject: Installing Hartzell prop on IO540 |
I ended up drilling a hole, taping it, and using a screw through a piece
of scrap to pull the plug out. I tried prying the cap out using tools
thru the hole. That didn't work.
There is a rear plug installed that seals this section of the crank. A
shaft with a cut-out in it is installed across the mouth of the hollow
crank which must be where the oil enters/exits the crank.
Thanks for the help all.
speed and fixed configurations doesn't directly address removal of the metal
cup.
Thanks in advance
Bill
