Dareha
Posted: Tue Mar 03, 2009 7:48 pm Post subject: Engine choice |
Hi,
I'm a new kid on the block and it looks like I may be able to buy a kitfox Mark IV. I am really excited and wondering what people are using for engines and why. We all want the best bang for our bucks and hopefully I can learn from all of you why you chose your engine. Thanks for any help you can provide.
Darrell Haas
Live near Portland, Oregon
Paul A. Franz, P.E.
Posted: Tue Mar 03, 2009 9:29 pm Post subject: Engine choice |
provide.
Engine selection advice is like asking for someone to pick you a religion. You're
going to have to study this issue if you don't already have an engine. Here's some
things to consider.
1) Will the engine be appropriate for the type of propeller you want. For example, if
the engine is only furnished and can use a wood propeller and you're definitely going
to be using floats, then you might rule that engine out.
2) Economics are an important consideration. There are two parts to this - initial
cost and operational cost. The two stroke engines cost less, are a little lighter but
use more fuel and have more scheduled maintenance costs.
3) Weight of the installed engine, gear reduction and propeller are very important. A
heavy engine is going to limit your useful load. That could greatly influence your
engine selection. An example of a light, powerful and reliable engine well suited for
a Kitfox model IV with a big selection of propellers is a Rotax 912. But the initial
investment is high but it is in the lower range of operational costs. There are
several choices utilizing certified aircraft engines. These are somewhat heavier but
don't require a gear reduction (redrive) and can have close to the best operational
cost but they too have a fairly high initial cost.
4) Consider the most likely uses of the airplane. How you're going to fuel it mostly.
If you can always fuel on your home airport you have the greatest flexibility but if
you have to carry oil for trips and have a two stroke engine, and higher fuel
consumption that would be an influence on your decision whether or not to use a Rotax
582.
5) Consider the firewall foreward part of your kit and factory support. I'd favor a
supported engine installation. It's your airplane so you can pick what you want
though.
6) The weak point of some of the better auto engine conversions is the redrive. Most
of the auto engine conversions are heavier than the designed for aircraft selections.
They have a lot of appeal for die-hard do-it-yourselfers though. Lots of flexibility
and there is a common belief that they can achieve a lower cost of completed
installation and possibly do it without a big weight penalty. Lots of room for
argument and contention here though.
Because of the sensitivity of this issue, people are probably not going to go right to
their conclusion which is the best engine choice. I can tell you what I chose. I have
a Rotax 914. I wanted to have a turbo charged engine for frequent over a mountain
range flying and wanted light weight and a constant speed prop. Although I didn't find
one of those suitable so I bought an NSI CAP. Since those have had problems on Rotax
912/914's and NSI isn't in business anymore, that would no longer be my
recommendation.
You might want to have something unique too, like a Rotec radial. You might also
consider the dealer support aspect of your engine purchase. You can probably chat with
Lockwood about Rotax or John McBean from Kitfox about engines, what kind of support
and costs.
One thing for sure, making the choice will be a fun process but will require some
effort to get the best result for your needs.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Dick Maddux
Posted: Wed Mar 04, 2009 4:26 am Post subject: Engine choice |
Nicely said Paul ! That in a nutshell is it !
Dick Maddux
Fox 4-1200
912 UL
Pensacola,Fl
Need a job? Find employment help in your area.
patreilly43(at)hotmail.co Guest
Posted: Wed Mar 04, 2009 6:38 am Post subject: Engine choice |
Paul C Well I am a relatively new kid too. I bought a Model 3 a little over a year ago. It that had been damaged and stripped of engine and instruments and disassembled. It was originally built with a 912 and everything was there for that setup including the mount. My intention was to install a 912. But C I saw a 100 hr 582 firewall forward on Barnstormers. It included everything C mount C gages C prop radiator C everything. I figured the cost would be 1/3 to 1/4 of the 912. I should be air worthy in 2 months. It was extra work to set up for 582 C but the engine weighs 1/2 a 912 installation C I don't plan on extended cross country flights in that plane. It's for low and slow. I have alot of experience with 2 stroke motorcycle engines and actually prefer them for dirt bike applications. Despite what others think a 2 stroke engine is just as reliable as a 4 stroke if properly maintained and aren't that harrd to maintain C especially one like a Rotax that is a proven design. Twenty years ago I owned an ultrlaight powered by a Kohler 30 horse engine ( designed for John Deere snow mobiles ) that required no maintainance in the 70 hours we flew it over a 3 year period. It didn't even hiccup once in that 3 years. I stand corrected C I think we changed spark plugs once as routine maintance.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Tue C 3 Mar 2009 19:44:16 -0800
Subject: Engine choice
Hi C
Darrell Haas
Live near Portland C Oregon
Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
msm_9949(at)yahoo.com Guest
Posted: Wed Mar 04, 2009 7:18 am Post subject: Engine choice |
Darrell,
I put this spreadsheet together awhile ago when we last had this discussion. It's incomplete and prices need updating but it's a start at empirical anaylsis of the choices available.
Have fun.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Wed, 3/4/09, Paul Franz - Merlin GT <paul(at)eucleides.com> wrote:
Quote: | From: Paul Franz - Merlin GT <paul(at)eucleides.com>
Subject: Re: Engine choice
Date: Wednesday, March 4, 2009, 12:27 AM
Quote: | --> Kitfox-List message posted by: "Paul Franz - Merlin GT"
a
Quote: | kitfox Mark IV. I am really excited and wondering what people are using
for
Quote: | engines and why. We all want the best bang for our bucks and hopefully I
can
Quote: | learn from all of you why you chose your engine. Thanks for any help you
can
You're
Here's some
things to consider.
example, if
definitely going
initial
lighter but
important. A
your
suited for
initial
heavier but
operational
it mostly.
but if
Rotax
582.
favor a
want
though.
Most
selections.
flexibility
right to
I have
mountain
didn't find
Rotax
recommendation.
also
chat with
support
and costs.
some
Paul A. Franz
Bellevue WA
425.241.1618 Cell
Description: |
 Download |
Filename: |
Engine_choices.xls |
Filesize: |
23.5 KB |
Downloaded: |
592 Time(s) |
rjdaugh
Posted: Wed Mar 04, 2009 8:23 am Post subject: Engine choice |
I agree Paul! Well said!
Now I know where to go when I need help picking a religion.
Randy
Series 5/7, 912S (the best choice!) Warpdrive taper tip
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Wednesday, March 04, 2009 5:26 AM
Dick Maddux
Fox 4-1200
912 UL
Pensacola,Fl
Need a job? Find employment help in your area. 0123456789
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Mar 04, 2009 11:35 am Post subject: Engine choice |
Great resource Marko.
I have one observation, however. Of course flying behind a Rotax 912 UL for
900 hours before losing that airplane in a forced landing, that is the first
place I looked on the spreadsheet. What caught my eye was the fuel
consumption and a fairly large factor in the cost per hour.
I kept a spread sheet for about the first four years tracking fuel per hour
consumption and for that period it averaged 2.2 gallons per hour. That
figure along with a flight, probably in 2002 or 3 when a group of six flew
from Rancho Murietta, CA to Winnemucca, NV on our way to exlporing the Idaho
back country. The flight was right at three hours (three hours and about 20
minutes as my flight path took me from Cameron Park to Rancho Murietta) and
I topped up in Winnemucca taking 7.7 gallons. Others in the group took as
much as 11 gallons, a little over half of what shows for fuel gph on the
spead sheet. Keep in mind that the typical Kitfox flying around the patch
is not in full power settings but a small fraction of the time.
I guess the point is that the religion analogy is a very good one. There is
a lot of belief and opinion factored into the equation and hard facts (at
least universally accepted ones) are pretty hard to come by. I have beliefs
based on some experience and observation and they move me back to the 912 UL
like I had. I am sure other opinions will vary.
Lowell
rjdaugh
Posted: Wed Mar 04, 2009 1:03 pm Post subject: Engine choice |
Lowell,
I sure agree that the 912 engines are thrifty. When I had a wrong propeller
on my 912S early on, fuel burn was averaging under 3 gph. Now with a better
propeller (108 - 110 mph cruise versus 95 mph) the average is now closer to
3.5 gph when going somewhere. Like you say, when just out to check the
sights or enjoy the evening, fuel burn is much lower. I usually fly at
about 5-6,000' - my strip is at 4400'. I don't know if that affects my burn
rate.
I love that engine.
Randy
Kitfox 5/7 912S
Guy Buchanan
Posted: Wed Mar 04, 2009 1:36 pm Post subject: Engine choice |
At 07:44 PM 3/3/2009, you wrote:
Quote: | I'm a new kid on the block and it looks like I may be able to buy a kitfox Mark IV. I am really excited and wondering what people are using for engines and why. We all want the best bang for our bucks and hopefully I can learn from all of you why you chose your engine. |
I run a 582 C box with a 70" Warp 3 blade on a Kitfox IV-1200.
Pro: - Light. (To pull the engine I unbolt it, pick it up by hand, and set it on a bench. Try THAT with any other engine.)
- Really, REALLY, easy to work on.
- Quiet.
- Reliable. (So far.)
- Swings a big prop very slowly. (More thrust.)
- Very cheap to buy.
- Can change gear ratios for an amazing array of prop options.
- Super easy to start. (Like a snowmobile.)
- No need to pre-heat. (Like a snowmobile.)
Con: - Higher fuel burn. (4.5 gph (at) cruise.)
- Vibration. (2 cylinder typical.)
- Higher acoustic pitch. (Not for the manly man.)
- Very low TBO. (300 hours, though the folks in South Africa have some studies indicating much higher numbers are appropriate, and have increased their TBO to 600 hours.)
- Parts are expensive, relative to auto.
- It burns oil, so if you're going just about anywhere you have to carry all the oil you're going to use for that trip, or stage it accordingly. Interestingly this seriously degrades any weight reduction normally attributed to the motor.
- Low permanent magnet alternator output. (12 amps continuous.)
- Great care required in operation to keep EGT's in line. (No big deal with a mixture control and a little experience, but you do have to be careful.)
I've been very happy with mine, but will eventually switch to either a 912 or a diesel. I do lots of cross countries and am tired of carrying oil instead of passengers.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Posted: Wed Mar 04, 2009 2:25 pm Post subject: Engine choice |
What religion you pick doesn't matter much. Picking an engine does!
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: RE: Engine choice
Date: Wed C 4 Mar 2009 09:22:31 -0700
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_EmailStyle18 {font-family:Arial;color:navy;} .ExternalClass span.EC_SpellE {;} .ExternalClass span.EC_GramE {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Randy
Series 5/7 C 912S (the best choice!) Warpdrive taper tip
Sent: Wednesday C March 04 C 2009 5:26 AM
Dick Maddux
Fox 4-1200
912 UL
Pensacola CFl
Need a job? Find employment help in your area.01
2 [quote][b]
Posted: Thu Mar 05, 2009 1:38 pm Post subject: Engine choice |
Lowell,
I make no claims to accuracy or completeness of the data contained in the spreadsheet. But I can say that the information it contains comes from the engine manufacturer's and/or distributor's own sources. My intent was to initiate a tool for empirical, apples-to-apples comparison, to the extent possible. I continue to encourage everyone to add verifiable data as they see fit and to share it with the rest of us.
Marco Menezes N99KX
Date: Wednesday, March 4, 2009, 2:27 PM
place I looked on the spreadsheet. What caught my eye was the fuel consumption
consumption and for that period it averaged 2.2 gallons per hour. That figure
along with a flight, probably in 2002 or 3 when a group of six flew from Rancho
Murietta, CA to Winnemucca, NV on our way to exlporing the Idaho back country.
The flight was right at three hours (three hours and about 20 minutes as my
flight path took me from Cameron Park to Rancho Murietta) and I topped up in
Winnemucca taking 7.7 gallons. Others in the group took as much as 11 gallons,
a little over half of what shows for fuel gph on the spead sheet. Keep in mind
that the typical Kitfox flying around the patch is not in full power settings
I guess the point is that the religion analogy is a very good one. There is a
lot of belief and opinion factored into the equation and hard facts (at least
universally accepted ones) are pretty hard to come by. I have beliefs based on
some experience and observation and they move me back to the 912 UL like I had.
Lowell
Posted: Thu Mar 05, 2009 5:25 pm Post subject: Engine choice |
I fully understand, Marco. I hope it didn't sound like I was criticising
your effort. I was just trying to point out how difficult it is to get
everyday data for comparison. I wouldn't give much credence to published
weights either. I think the best information there is the final empty
weight of various projects and look for trends, i.e. the low 600 lb. Model
IV with a 912. I remember Lance Wheeler - NSI - stating that their EA81 was
35 lbs heavier than the 912 then builders were forced to offset the extra
100 ft lbs forward of the datum with 200 ft lbs. aft.
I found this same weight thing when researching landing gear. Grove
advertises their spring gear for the Model IV at 34.3 lbs. I called and
asked what the total was including the mounting plates and hardware. It was
over 30 lbs. I guess if I was going to carry it around in the baggage sack
their figure is a keeper, but in order to use it it took another six poungs
of stuff. I am not sure Rotax includes such things as radiators, oil
coolers hoses and coolant in their engine weights either. I suspect not.
For the benefit of those thinking and doing the research maybe it would be
helpful to go back to the survey we did in 2006 and add empty weights,
actual fuel consumption, climb, cruise, fairings, etc. I just checked the
spreadsheet and out of 117 entries four listed empty weights - two Model
IVs and two Series 5s. The two fours came in at empty weights of 625 (on
wheels) and 673 and the 5s were 925 and 776. The IV's had 912s, and the 5s
an auto conversion and a 912ULS.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Building
Fox5flyer Guest
Posted: Fri Mar 06, 2009 4:38 am Post subject: Engine choice |
Let the flood gates open...again.
Quote: | weights either. I think the best information there is the final empty
Model IV with a 912. I remember Lance Wheeler - NSI - stating that their
EA81 was 35 lbs heavier than the 912 then builders were forced to offset
the extra 100 ft lbs forward of the datum with 200 ft lbs. aft.
I was waiting for something like this to come up, but you surprised me,
Lowell with the numbers you gave. You generally avoid anecdotal information
that can't be backed up. I'll stipulate that the 912x is a great engine and
very light for it's power output and there is no doubt in my mind that it is
probably the premier aircraft engine when used for it's intended design.
However, there is a hefty price for that and many of us do not have pockets
that are deep enough to go that route.
As for all up weights, I won't speak for the Model IV because mine is a V.
For balast the only thing I had to do was put my battery in the tail,
nothing more, and that was including the CAP prop, which by it'self is
relatively heavy. Also, I suppose there might be a 600 lb Model IV with a
912 out there, but I suspect it's definitely not typical.
was over 30 lbs. I guess if I was going to carry it around in the baggage
sack their figure is a keeper, but in order to use it it took another six
poungs of stuff. I am not sure Rotax includes such things as radiators,
oil coolers hoses and coolant in their engine weights either. I suspect
not.
Exactly. It's been said that numbers don't lie, but unfortunately in the
experimental world no two people (or factories) provide their weights with a
verifiable standard which makes the numbers useful, but meaningless. And
for what it's worth, when I was building, I weighed my Grove gear along with
axles, bolts, nuts, clamps, wheels, tires, and brakes. Basically everything
that was required to keep the airplane off the ground. Surprisingly it came
out to almost exactly 75lbs. Then again, that weight is comparatively
meaningless because I have no idea how much the tube gear weighs with the
same items included. I've always wondered...
5s an auto conversion and a 912ULS.
Lowell Fitt
One thing that needs to be kept in perspective here is that regardless of
engine weights and periferals, the V with no engine at all is much heavier
than the IV with no engine. A given. Using all up weights between aircraft
whether they be IV or V or II has limited value because no two builders
build the same way nor do they use the same materials.
Personally, what I would like to see is a standard developed for weighing
engines. There are so many variables out there that it's really impossible
to find out what the real weights are unless you have one in your hands and
weigh it for yourself. Perhaps it would be a good project for submittal to
the EAA for publication, but I doubt that will ever happen. Too many people
with there own agendas.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
mlpaton2000(at)yahoo.com Guest
Posted: Fri Mar 06, 2009 4:55 am Post subject: Engine choice |
soory to come in so late, lowell
i had a912 in a series 5,it works well but it decided to go for a sleep 13 hrs after servising it and i hit the deck, it was a ok engine but now i suspisios
cheers michael
had only 450 hrs on it
Date: Thursday, March 5, 2009, 5:20 PM
I fully understand, Marco. I hope it didn't sound like I was criticising your effort. I was just trying to point out how difficult it is to get everyday data for comparison. I wouldn't give much credence to published weights either. I think the best information there is the final empty weight of various projects and look for trends, i.e. the low 600 lb. Model IV with a 912. I remember Lance Wheeler - NSI - stating that their EA81 was 35 lbs heavier than the 912 then builders were forced to offset the extra 100 ft lbs forward of the datum with 200 ft lbs. aft.
I found this same weight thing when researching landing gear. Grove advertises their spring gear for the Model IV at 34.3 lbs. I called and asked what the total was including the mounting plates and hardware. It was over 30 lbs. I guess if I was going to carry it around in the baggage sack their figure is a keeper, but in order to use it it took another six poungs of stuff. I am not sure Rotax includes such things as radiators, oil coolers hoses and coolant in their engine weights either. I suspect not.
For the benefit of those thinking and doing the research maybe it would be helpful to go back to the survey we did in 2006 and add empty weights, actual fuel consumption, climb, cruise, fairings, etc. I just checked the spreadsheet and out of 117 entries four listed empty weights - two Model IVs and two Series 5s. The two fours came in at empty weights of 625 (on wheels) and 673 and the 5s were 925 and 776. The IV's had 912s, and the 5s an auto conversion and a 912ULS.
Lowell Fitt
Cameron Park, CA
Building
Lynn Matteson
Posted: Fri Mar 06, 2009 7:27 am Post subject: Engine choice |
I wasn't going to respond to this thread, but now that someone has
admitted to having trouble with a Rotax, I'll chime in with a
suggestion for the Jabiru 2200 engine. Mine made it to 562 hrs before
crapping the bed, but it's working just fine now. This is just to say
that all engine makes have a bad apple now and then, and no make is
exempt.
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 6, 2009, at 7:53 AM, michael paton wrote:
[quote] soory to come in so late, lowell
cheers michael
Lowell Fitt
Cameron Park, CA
Building
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
JetPilot
Posted: Tue Mar 10, 2009 9:22 am Post subject: Re: Engine choice |
lcfitt(at)sbcglobal.net wrote: | Great resource Marko.
Lowell
Lowell,
What caused your forced landing ? Was the plane not rebuildable ? What type of engine do you have now ? The 912 series has a reputation for being very reliable, I had not heard about your forced landing. The 912's are expensive engines, but considered well worth the money if you can afford it.
Kolb MK-III Xtra, 912-S |
Posted: Tue Mar 10, 2009 5:32 pm Post subject: Engine choice |
Mike, It was contamination in the oil that resulted in a drop in oil
pressure. We were on the way to the factory fly-in two years ago and over
the Sierra foothills. I decided that the prudent thing to do was make a
precautionary landing in a clearing. The landing didn't come out very well,
as I landed away from the river and powerlines, but found my path to
actually be downhill and the ground sank at just about the same rate as I
was and I put it down rather than take my chances with the oak trees.
The contamination was presumed to be from an oil bottle - possibly the ring
that secures the cap. The engine never quit.
Lowell
JetPilot
Posted: Tue Mar 10, 2009 8:16 pm Post subject: Re: Engine choice |
That had to suck, but thanks for sharing the story. I will be very careful of those rings when pouring oil into engines after hearing this.
shinco(at)bright.net Guest
Posted: Tue Mar 10, 2009 10:09 pm Post subject: engine choice |
I too belive that when you change things in your engine from stock.Like
changing pistons,cranks,rods,etc...you do increase HP.and may B more
speed..BUT...having sand rails that when I changed things for more
power,and HP..yes that is true..BUT down the road you will pay for it..I
found out in the long run..there was alot of reliability problems,,and
all ways working on them VW engines.and then when they broke down they
would cost even more to fix them..All so they would break down at the
darnest times.when you did not want then to..Like when going up a steep
hill..OH no the engine just blew up...this has happen many times...so
after all of that.messing with thoese VW engines..now I do not change
engines any more .I leave them stock...my life means more that a little
extra HP..and all so now I do not have to keep working on them either..a
lot more reliability..Just my thoughts on the matter...Steve Shinabery
N554KF KF2 rotax 582
Float Flyr
Posted: Wed Mar 11, 2009 12:09 pm Post subject: engine choice |
Good point as most certified engines are not hopped up but detuned for
reliability.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
