Dick Maddux
Posted: Sat Mar 07, 2009 5:17 am Post subject: gear weight |
Deke,
It just so happens that I weighed my original gear yesterday as I am getting ready to sell it on EBAY and need to find out what the shipping will be to put in my auction.
The gear legs weighed 16 lbs for the pair and the "Kingfox "tires,wheels,Matco brakes and axles weighed roughly 18 lbs each (not selling those). So we have a total of 52 lbs plus maybe 1/2 lb of bolts for the standard gear. That will give you a ball park figure for your curiosity.
Dick Maddux
Fox 4
Pensacola,Fl
Need a job? Find employment help in your area.
Fox5flyer Guest
Posted: Sat Mar 07, 2009 9:12 am Post subject: gear weight |
Thanks. I think there was more than one type of gear sold by Grove for the Kitfox and I'm finding out that the S5 gear was much different than the IV. Mine is one continuous gear that is about a 1.25" thick on the cross piece under the belly and it's also significantly taller than the IV gear. Not two pieces. Also, I have all Cleveland wheel hardware. After having looked at a IV gear recently, mine is noticeably heavier looking and also by the scales. Gross weight of the 5 is 1550lbs which, I assume, requires a larger and heavier gear. It came with the airplane package so I was stuck with it. If I'd had any idea before the purchase how heavy it was I'd have gone with the tube gear. One thing I can attest to though is that it will definitely soak up some bad landings so I'm not in any rush to change it just to save a few lbs.
Lowell's gear looks to be the perfect setup for the rough ground that mine is subjected to about 90 percent of the time. I don't recall anyone saying what Lowells' gear weighs, all-up complete with fairings. Anybody know? Lowell?
Deke
Lynn Matteson
Posted: Sat Mar 07, 2009 10:29 am Post subject: gear weight |
Deke-
I got curious about the weight of my Grove gear...model IV
'fox....and went to their site....24.3 lbs for the 3 and 4, 34.3 lbs
for the 5,6, and 7. Calc out the old tube gear and the weight gain is
minimal on the 3 and 4. Can't say about the 5,6, and 7, because I
don't have the old stuff to heft/weigh. When I was building mine, and
learning to fly at the same time, I saw (in Grove) a wider gear and
stronger, and didn't give it a second thought, because I knew
eventually I'd make a bad landing....and that didn't take long! : )
Given Dick's post of 16 lbs for the old tubes, I gained 8.3 lbs for
the added insurance of a wider, stronger gear, and I'll pay that
weight penalty any day.
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 7, 2009, at 12:11 PM, fox5flyer wrote:
[quote] Thanks. I think there was more than one type of gear sold by Grove
Deke
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
lkc(at)juno.com Guest
Posted: Sat Mar 07, 2009 4:03 pm Post subject: gear weight |
Deke... I have the same setup as you including engine... I've been learning to fly in the Series5 and had the left tube gear break. Mine now has the grove gear on and I'm a happy camper again. The gear weighs more but I found a way to drop another 25 lbs of flying weight. The pilot now weighs 140 lbs and will probably live to fly many years longer. How much time do we spend trying to save 10 lbs of aircraft weight when we can just quit stuffing our face. Layne
[url=_blank]Criminal Lawyers - Click here.[/url]
lcfitt(at)sbcglobal.net Guest
Posted: Sat Mar 07, 2009 10:42 pm Post subject: gear weight |
I don't know if I totally agree with the numbers.
My set of original gear (powder coated) weighs 7 lbs 15 ounces (4 lbs. and 3
lbs. 15 oz). The bungees weigh exactly a pound - just weighed them. The
(drilled) axles and axle nuts weigh 1 lb. 5 oz.. Mounting hardware comes
in at 3 oz.
Bungee gear total 10 lbs. 7 oz. Unfaired, powdercoated
Dick's bungee gear had fairings which likely explains the 16 lbs. he
measured.
The cabane gear sent to Dick came in at 17 lbs 2 oz. (bare metal) without
the fairings. The fairings added 1 lb. 13 oz with attaching screws (bare
metal as well) . Using the same axles, weight 1 lb 5 oz. and the attaching
hardware 7 oz.
Cabane Gear total 19 lbs. 11 oz. bare metal
The Grove gear is advertised as weighing 24 lbs 3 oz. But again, this is
one of the frustrating things when searching companies web sites. In an
exchange of e-mails from Grove on this subject the following is what I
received from them last July.
"Lowell
The gear weighs approx 24.3 lbs, I just weighed the brackets, mounting
hardware, and axles. this is an additional 6.5 lbs.
The price of the kit is $1590.00 which includes:
Gear
gun drilled brake lines
brackets
mounting hardware and instructions
axles
axle hardware.
The kit is complete, you will have all that you need to install the gear
using your existing wheels."
Grove total weight 30.5 lbs. (30 lbs 8oz.) Bare metal
All these gear sets are identical in configuration except for the bungee
gear being powder coated and the other two types will have varying amounts
of paint, probably not to exceed 3 or 4 ounces, I would guess.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
working on the elevator gap cuffs
Lynn Matteson
Posted: Sun Mar 08, 2009 2:34 am Post subject: gear weight |
Here, here! I'd like to shed about 5-15 lbs. of pilot weight, too,
Layne....make the plane a lot safer if it was made lighter that way. : )
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 7, 2009, at 11:57 PM, lkc(at)juno.com wrote:
| Quote: | Deke... I have the same setup as you including engine... I've been
www.matronics.com/contribution _-
N369LM |
Lynn Matteson
Posted: Sun Mar 08, 2009 2:48 am Post subject: gear weight |
You're probably right about the Grove advertised weight, Lowell. I
looked at their site and they only state the weight of the "gear" not
the mounting brackets. I should have weighed mine before
installation, but did not. I figured what I installed, I installed,
and wasn't going to quibble about the weight when the important
thing...to me...was to improve a narrow tread-width, possibly
squirrelly, landing gear with a wider, lower (I think) gear which, I
was told on this forum, was better suited for a beginner to learn on.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 8, 2009, at 1:36 AM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
lbs. and 3 lbs. 15 oz). The bungees weigh exactly a pound - just
weighed them. The (drilled) axles and axle nuts weigh 1 lb. 5
oz.. Mounting hardware comes in at 3 oz.
he measured.
without the fairings. The fairings added 1 lb. 13 oz with
attaching screws (bare metal as well) . Using the same axles,
weight 1 lb 5 oz. and the attaching hardware 7 oz.
this is one of the frustrating things when searching companies web
sites. In an exchange of e-mails from Grove on this subject the
following is what I
"Lowell
Gear
brackets
axles
axle hardware.
gear
bungee gear being powder coated and the other two types will have
varying amounts of paint, probably not to exceed 3 or 4 ounces, I
would guess.
Lowell Fitt
Cameron Park, CA
N369LM |
Dick Maddux
Posted: Sun Mar 08, 2009 5:21 am Post subject: gear weight |
Deke,
I just realized I made an error. The stock gear legs with plastic fairings weighed aprox 13 1/2 lbs not 16. I was trying to go from memory but I had it written down. Lets just say for round numbers Lowells gear is about 4lbs lighter, close enough.
Dick Maddux
Pensacola,Fl
Dick Maddux
Deke,
Lowells gear weighs 9 lbs with the fairings (about 4 lbs less than the original gear legs with fairings) Lets say it is 10 lbs with paint and incidentals. Now this does not include the wheels,brakes and axles of course just the gear legs,cabane ,springs,bolts and fairings.
Dick Maddux
Pensacola,Fl
Fox5flyer Guest
Posted: Sun Mar 08, 2009 6:01 am Post subject: gear weight |
Good point, Layne. I think most of us could easily drop 10 or 20 lbs. Some much more. Up here in NE MI, the winter days can be long, cold, and often, when the weather is rotten, not much else to do but eat. I generally put on about 10 over the winter then lose it by middle of June. Same old story, different year.
Deke
Fox5flyer Guest
Posted: Sun Mar 08, 2009 6:03 am Post subject: gear weight |
Lynn, I've learned in the experimental world to not put too much stock in
what is advertised by vendors. Also, I've often wondered about my gear
whether it is actually a Grove gear. The weight doesn't match what they
advertise, it's taller than what I've seen on other Kitfoxes, it's a
slightly different shape, and it's a single piece. It came with the package
straight from Skystar. Does anybody know if Skystar sold an aluminum gear
that was NOT made by Grove? Inquiring minds would like to know.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Fox5flyer Guest
Posted: Sun Mar 08, 2009 6:12 am Post subject: gear weight |
Nice. If I ever prang my gear (hopefully never) it's pretty obvious I would go with Lowell's gear. Mine works fine though as is, so other than to save weight, there is no reason at this time to change anything.
Deke
Lynn Matteson
Posted: Sun Mar 08, 2009 6:16 am Post subject: gear weight |
Deke, if you go to the Grove site, I think they say your 5 gear (if
it really IS a Grove) is 1" thick, while my IV is 7/8" thick. Of
course your 1.25" gear could still be a Grove, but of an earlier
"batch" or design.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 8, 2009, at 10:03 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
stock in what is advertised by vendors. Also, I've often wondered
about my gear whether it is actually a Grove gear. The weight
doesn't match what they advertise, it's taller than what I've seen
on other Kitfoxes, it's a slightly different shape, and it's a
single piece. It came with the package straight from Skystar.
Does anybody know if Skystar sold an aluminum gear that was NOT
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
vadert(at)shaw.ca Guest
Posted: Sun Mar 08, 2009 6:47 am Post subject: gear weight |
Deke
6nbsp;
There was a company called Hammerhead 6nbsp; Aviation that competed directly against Grove and built aluminum gear for Kitfoxes E 6nbsp;I was looking at it for 6nbsp;my IV when they and Grove were having a price war E That was 6nbsp;when they went out of business E
6nbsp;
Tim Vader
Kitfox IV
GPASC 2276
Repairing
rjdaugh
Posted: Sun Mar 08, 2009 6:49 am Post subject: gear weight |
Deke,
Maybe I live a sheltered life, but all the ktifox Grove gear I have ever
seen is one piece. (??) My first one came from Skystar and then I bent it
and got another from Grove. (Yeah, it is possible to bend it, but I had to
work at it!) They have changed alloy so they are making changes all the
time. I think also part of the uncertainty comes from different gear for
the IV or the 5/6/7.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Fox5flyer Guest
Posted: Sun Mar 08, 2009 7:03 am Post subject: gear weight |
Hmmm. I could swear that Lynn, or one of the other responders said their
Grove gear (IV) was in two pieces. Maybe I misunderstood. Nothing new.
Deke
Fox5flyer Guest
Posted: Sun Mar 08, 2009 7:07 am Post subject: gear weight |
I remember Hammerhead and it was too bad they went out of business. Competition is good for the sport. I think their gear was pretty much a carbon copy of Grove, or at least what I saw seemed to be. Like I said, mine is different. The legs are thicker, yet narrower and taller than the Grove gear I see on other airplanes.
Deke
propellerdesign(at)tele2. Guest
Fox5flyer Guest
Posted: Sun Mar 08, 2009 8:17 am Post subject: gear weight |
My mistake for poor use of cliché terms. Maybe, "close copy" would have worked better?
Deke
Posted: Sun Mar 08, 2009 8:42 am Post subject: gear weight |
It was no critic, just playing with words.
Lucky we are not German, they don't even have a name for humor.
Jan
