HBaker
Posted: Fri Mar 13, 2009 2:37 pm Post subject: Manifold Drain Lines |
Hi Guys
Can anyone tell me what size lines are used on the manifold Quick drain lines, 1/8 or 1/4?
Henry
Moose # 294
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
_________________ Currently building a Murphy Moose - any help would be appreciated. |
Posted: Mon Mar 16, 2009 3:05 pm Post subject: Manifold Drain Lines |
Henry, I assume you are talking about the intake manifold drains lines used
on the lower 3 cylinders?
Typically these systems use AN#4 fittings. Some people have used hard
Aluminum lines to connect everything together. I would recommend against
this because every system I have seen that does it that way eventually
cracks these lines due to engine vibration and then you end up with a intake
air leak which can be really insidious to find.
Instead use AN-4 fittings with steel braided flex hose. Suggest hose such
as this:
http://www.hrpworld.com/index.cfm?tpc=Aeroquip_AQP_Stainless_Steel_Braided_R
acing_Hose&form_prod_id=614,600_331&action=product
Typical AN#4 braided hose has a .22 ID and a .44 OD.
Best Regards,
Mark Bitterlich
Description: |
 Download |
Filename: |
smime.p7s |
Filesize: |
4.81 KB |
Downloaded: |
639 Time(s) |
HBaker
Posted: Mon Mar 16, 2009 4:03 pm Post subject: Re: Manifold Drain Lines |
Hi Mark
Yes ,I was referring to the manifold drain lines , thanks for the info, theirs nothing like some one who has already been down the road.
Thanks very much Mark!
Posted: Mon Mar 16, 2009 4:18 pm Post subject: Manifold Drain Lines |
Yep, you guessed correctly. I used to use hard aluminum lines. Yep,
one cracked. Yep, it took awhile to realize what was going on with the
engine! Yep, I immediately switched to braided steel flexible lines.
Take care,
Mark
P.S. Here's a little hint. Leave the intake manifold drain valve OPEN
during engine priming. Reach in the cockpit and INTENTIONALLY
over-prime the engine. Don't go nuts here... Say about 10-12 strokes of
the primer. The excess fuel SHOULD come out the intake drain. If it
does not, do not start your engine, you have oil backed up in those
drain lines, and you also might have oil IN THE INTAKES that you do not
want to suck into the cylinder!
After doing this... Assuming fuel does come out the drain.. Look
carefully at all the lines and fittings in the system for fuel leaks.
I.E., It is hard to see anything coming out of these lines with the
engine running. It IS EASY to see fuel coming out of these lines and
fittings when you over-prime the engine and one is cracked or loose,
etc.
Lastly, after doing this, always gently pull the engine through making
sure you don't have any kind of hydraulic lock from the over-prime fuel
in a cylinder itself. This has never happened to me, but it is indeed
possible if you go nuts with the priming and happen to have an intake
valve open! As in.. I am saying this to cover my ass.
HBaker
Posted: Tue Mar 17, 2009 3:32 am Post subject: Re: Manifold Drain Lines |
Thanks again Mark
Once again, I hope I can learn from others as these mistakes could ruin my fishing trip! Thanks again for taking the time responding to my Question.
Henry
yakplt(at)yahoo.com Guest
Posted: Tue Mar 17, 2009 3:48 pm Post subject: Manifold Drain Lines |
Anytime. My pleasure.
Mark
To: m14pengines-list(at)matronics.com
Sent: Tuesday, March 17, 2009 7:32:31 AM
Subject: Re: Manifold Drain Lines
--> M14PEngines-List message posted by: "HBaker" <henry.baker(at)nf.sympatico.ca (henry.baker(at)nf.sympatico.ca)>
Thanks again Mark
Henry
http://forums.matronics.com/viewtopic.php?p=234952#234952
Claytonfly(at)comcast.net Guest
Posted: Tue Mar 17, 2009 5:51 pm Post subject: Manifold Drain Lines |
The Kimball's down in Florida have a system all readily developed. It uses
stainless lines and a quick drain. I just installed one on my Pitts 12
project and it went in good.
John Clayton
HBaker
Posted: Sun Apr 05, 2009 4:02 pm Post subject: Re: Manifold Drain Lines |
Thanks Mark
I used an fittings, and all stainless steel braid lines and it worked perfectly the swivel female to female can be bought at any hydraulic shop !!
Thanks again
Henry
Posted: Mon Apr 06, 2009 2:08 pm Post subject: Manifold Drain Lines |
The swivel fitting is a nice touch!
Mark Bitterlich
Description: |
 Download |
Filename: |
smime.p7s |
Filesize: |
4.81 KB |
Downloaded: |
679 Time(s) |
