nickc(at)mtaonline.net Guest
Posted: Sun Mar 15, 2009 8:50 pm Post subject: How many gallons per hour with VW Redrive |
Rick, and any other VW redrives,
How many gallons per hour do burn with your VW Redrive. I read about your creation in the archives, but I did not see anything regarding GPH and what type of fuel do use?
I am try to narrow engine choices… that I can afford.
Nick Cassara
Proto-type Kolbra
Palmer, Alaska
Posted: Mon Mar 16, 2009 5:03 am Post subject: How many gallons per hour with VW Redrive |
Nick
I burn 4 gallons per hour of regular automotive fuel. I had my engine built for a 7.8-9 to one compression ratio. Higher compression requires higher octane.
I have been told the VW engine mount that Kolb makes is too wide for the Kolbra.
Rick Neilsen
Redrive VW powered MKIIIC
herbgh(at)nctc.com Guest
Posted: Mon Mar 16, 2009 7:17 am Post subject: How many gallons per hour with VW Redrive |
Rick
Sounds as if you are running at near 50 horses...? What redrive ratio and cruise rpms? Cruise speed? Thanks Herb
At 08:02 AM 3/16/2009, you wrote:
[quote]Nick
Rick Neilsen
Posted: Mon Mar 16, 2009 7:42 am Post subject: How many gallons per hour with VW Redrive |
Herb
Since it is a custom engine the power is a bit unknown but I cruise at a greatly reduced power level. I assume you extrapolated the 50 HP from the fuel burn. You are assuming a lot but might be close. Climb and cruise are very close to a 80 HP Rotax.
The redrive ratio is 1.6 to 1 and I cruise at 3200 engine RPMs. The cruise is 75 MPH. I'm currently turning a 71 inch three bladed F model PowerFin prop.
Rick Neilsen
Posted: Mon Mar 16, 2009 9:22 am Post subject: How many gallons per hour with VW Redrive |
12 hp per gal per hour is a little high for the 912UL.
My experience with the 912UL is 4 gph at 5,000; 4.25 gph at 5,200, 4.5 gph at 5,400 rpm. These figures are based on many hours of cross country flying, not around the patch fuel consumption figures.
The 912ULS is not nearly as efficient as the old 80. 5 gph at 5,000 and 5.5 gph at 5,000. Got to pay for the extra kick.
I can not remember what type bearing is used for con rods.
Give Ronnie Smith a call.
[quote] My assumptions are based on a burn of 12 hp per gal per hour . Herb
ps anyone know if the rods on the 912 use needle bearings ?
_________________ John Hauck
Titus, Alabama |
Posted: Mon Mar 16, 2009 9:56 am Post subject: How many gallons per hour with VW Redrive |
Knew it was going to be better... Sounds like 16 or so hp per gal per hr...? Could not find a hp/torque curve in the CPS catalog for the 100 hp engine.. Thazzz purty gud...
Who is flying the Geo Metro on the list? Might make a good comparison...Herb
At 12:21 PM 3/16/2009, you wrote:
[quote]12 hp per gal per hour is a little high for the 912UL.
lucien
Posted: Mon Mar 16, 2009 10:54 am Post subject: How many gallons per hour with VW Redrive |
| Quote: | I believe the 912 rods use "regular old" sleeve/bushing type bearings
which are supported by oil pressure. I don't think they use needle
bearings.
And I don't want to have to find out. Ever....
LS
The main bearings are "inserts". I remember that from 912 course, but can
not remember the con rods.
Guess I could do a little research in the heavy maintenance manual, but
don't have time now.
Titus, Alabama |
Posted: Mon Mar 16, 2009 11:24 am Post subject: How many gallons per hour with VW Redrive |
Herb, because the geo is only 1 liter and high compression it does very well at being frugal.It also burns low octane gas with no protest. I did notice a slight loss when they started putting
ethanol in it. I can't give any numbers because I haven't done a real test. As with any engine though, it
gets thirstier if I push it harder.
Same goes for rate of climb. Never measured it but I think I would need to look at the hour hand
instead of the minute hand.
Been beautiful flying weather here for the past three days but spring is a busy time around here
so that's wishful thinking. -besides, I still have to change my legs over to the new steel jobbers.
Something new every year.
BB
| Quote: | 12 hp per gal per hour is a little high for the 912UL.
| [b]
Posted: Mon Mar 16, 2009 11:26 am Post subject: How many gallons per hour with VW Redrive |
Herb C
Currently C there are two gentlemen presently flying the GEO engine. Bob Bean C who has his set up with a carburetor C and Vic (I think Gibson) C who more than likely has TBI (throttle body fuel injection C which probably retains the ECU computer for engine controls).
I am in the final stages of attaching all the extraneous engine items on my turbocharged GEO 1.0 liter. So far C I've got the turbocharger C radiator C intercooler and oil cooler fabrication completed and mounted these items. Right now C I'm working on the finishing touches on my turbo exhaust.
The exhaust is all built C I'm just putting on the O2 bungs C etc. I'll most likely have these exhaust pieces cermicoated.
Recently I received my high performance cam and reworked cam gear back from the Teamswift.net GEO engine guru. This guy has a machine shop C and knows quite a bit about high performance GEO modifications. There are dozens C if not hundreds C of people that have installed his performance parts C and every one of them rave about how much better their engine's power is improved.
My engine now has his "mild" street cam C and 6+ degrees advanced cam gear (to be repositioned to the new 6+ degree setting). It is the opinion of three people I've corresponded with (on that high performance chat group site) that my engine should be putting out around 95-100 HP C and around 120+ ft lbs of torque.
I make absolutely NO claim whatsoever as to whether it will or not have these perofrmance figures C until I fire the engine up and do some testing. I don't claim a thing until it is proven!!!
I expect I will do a thrust test at some point.
Oh yeah C there is one more guy who is building a GEO 1.3 L engine. His C also C will be fuel injection C but I think it's multi-port C IIRC.
Mike Welch
MkIII
Express your personality in color! Preview and select themes for Hotmail®. See how. [quote][b]
Posted: Mon Mar 16, 2009 12:28 pm Post subject: How many gallons per hour with VW Redrive |
> The durn picture on page 46 of the CPS catalog seems to indicate
| Quote: | that the crank is multiple pieces using big end needle bearings. ??? If
it used replaceable rods, then it could be re buildable which I think it
is not..? Herb
Picking up the phone, calling Ronnie Smith, was quicker than looking in the
book.
912 series crankshafts are press fit. Main bearings are split inserts and
the con rods are whole inserts. Crankshafts are not Service Center
rebuildable.
Titus, Alabama |
Posted: Mon Mar 16, 2009 12:55 pm Post subject: How many gallons per hour with VW Redrive |
Thanks John
Interesting concept...not sure that I have seen that
before? Makes me think that at 4k or so for the assy the after
market could make money rebuilding them with different rods
with split big ends.. Herb
At 03:27 PM 3/16/2009, you wrote:
>bearings. ??? If it used replaceable rods, then it could be re
>buildable which I think it is not..? Herb
in the book.
inserts and the con rods are whole inserts. Crankshafts are not
Service Center rebuildable.
Posted: Mon Mar 16, 2009 1:16 pm Post subject: How many gallons per hour with VW Redrive |
| Quote: | before? Makes me think that at 4k or so for the assy the after market
could make money rebuilding them with different rods with split big
ends.. Herb
Does anyone know why Rotax when the same route with cranks for 4 strokes as
they did for 2 strokes?
Not being an engineer, I have to rely on what little bit of good ole common
sense I inherited. A cursory glance at the crank tells me it may be lighter
and cleaner for turning higher speeds. Might reduce drag, increase
performance.
Just guessing. I don't know.
I do know that the only problem Rotax has experienced with a 912 crank was
oil starvation. A few seconds of oil starvation and the engine is toast.
What is the primary cause of oil starvation? Losing an oil line. Jim Lee,
Sharon, PA, lost his life near Lakeland, FL, when he was flying a Kolb MKIII
with floats. Lost an oil line on a 912, stalled and crashed.
Losing an oil line on a 912 should not happen. The intake line is under
vacuum, pump is pulling oil. The outlet line is under 3 to 5 psi (crankcase
pressure) to push oil out of the crankcase, back to the oil tank.
Titus, Alabama |
aslsa.rng(at)gmail.com Guest
Posted: Tue Mar 17, 2009 3:23 am Post subject: How many gallons per hour with VW Redrive |
The answer is weight. A built up crankshaft weighs less. It also allows the use of a "folded" (Eric Tucker's terminology) design of the crank throws, which makes the crank shorter, which makes a smaller, shorter crankcase which also reduces weight. Incidentally, the folded crank throw doesn't allow room for rod bolts, so no after market rods are likely. Okay, Dana, jump in and tell every one weight has absolutely nothing to do with it. :-}
Rick
On Mon, Mar 16, 2009 at 4:15 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote]--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
| Quote: | before? Makes me think that at 4k or so for the assy the after market could make money rebuilding them with different rods with split big ends.. Herb
Does anyone know why Rotax when the same route with cranks for 4 strokes as they did for 2 strokes?
Not being an engineer, I have to rely on what little bit of good ole common sense I inherited. A cursory glance at the crank tells me it may be lighter and cleaner for turning higher speeds. Might reduce drag, increase performance.
I do know that the only problem Rotax has experienced with a 912 crank was oil starvation. A few seconds of oil starvation and the engine is toast. What is the primary cause of oil starvation? Losing an oil line. Jim Lee, Sharon, PA, lost his life near Lakeland, FL, when he was flying a Kolb MKIII with floats. Lost an oil line on a 912, stalled and crashed.
Losing an oil line on a 912 should not happen. The intake line is under vacuum, pump is pulling oil. The outlet line is under 3 to 5 psi (crankcase pressure) to push oil out of the crankcase, back to the oil tank.
http://forums.matronics.com
le, List Admin.
Dana
Posted: Tue Mar 17, 2009 8:42 am Post subject: How many gallons per hour with VW Redrive |
At 07:23 AM 3/17/2009, Richard Girard wrote:
| Quote: | Okay, Dana, jump in and tell every one weight has absolutely nothing to do
with it. :-}
Are you kidding? Weight is EVERYTHING!
-Dana
The first rule of intelligent tinkering is to save all the parts.
