Torque values NSI
Michael Logan
PostPosted: Sun Mar 22, 2009 6:05 am    Post subject: Torque values NSI Reply with quote
Deke,
I went out and measured my bolts and looked at the NSI manual. The bolts on
mine are AN5-7a's and the torque value is 100 inch-pounds.
Mike Logan
Series 5 NSI Subaru converted by RAM
Mike Logan
Fredericksburg, VA
Fox5flyer
PostPosted: Sun Mar 22, 2009 10:11 am    Post subject: Torque values NSI Reply with quote
Hi, Mike. Thanks for the input. I just checked my bolts again and I was
wrong. They're actually AN5-11A, not -10A. The bolts I have are the ones
that came with the FWF package. My manual doesn't give a bolt size that I
can find, but it does clearly say to torque to 150 in lbs. Again, I checked
the chart I have and it says 180-220, but there are so many variables to
torque values that when using charts it's almost an estimate. Then I
checked for torque values using Google and that's when my head really began
to spin. Too many variables, like crow foot, oiled bolt, dry bolt, zinc
plate, no plating, tensile strength of bolt, strength of nut, etc. It just
goes on and on. Fortunately I have the NSI numbers or I'd end up not sure
at all what to use.
Anyway, I'll be using 150 in lbs, not only because it's what my manual says
to use, but it also sounds reasonable to me.
Actually, my question was what to use when there is no manufacturer number
and the chart says 180-220 in lbs. Never really got an answer to that, but
I'll let it go.
Thanks again,
Deke
