jeff(at)westcottpress.com Guest
Posted: Sun Apr 05, 2009 7:27 am Post subject: Ethernet Hub |
In my quest to find a small ethernet hub (for the two AFS units to
talk to each other) yesterday I discovered that the common Linksys
and Netgear models are 7.5V. Should I be able to find a 12V hub?
If not, how do I step the voltage down?
Jeff Carpenter
40304
N410CF
Posted: Sun Apr 05, 2009 8:38 am Post subject: Ethernet Hub |
GRT recently shipped me a unit to connect my 3 GRT units. It was a bit
pricey at $165. I questioned whether I should be able to just go out
and find a hub for a better price. They commented that this is an
'industrial' or 'commercial' grade product and that I might have a hard
time finding something equivalent.
It's a EIBA5100T/R (DIN- rail mount) from Comtemporary Controls. The
installation guides says "....hubs are designed for the Building
Automation Environment". It has 5 ports, it s 3.5x3.31 by 1". It can
be powered by AC 8-24V or DC 10-36V - no setup reuqired
www.ccontrols.com
Looks good to this builder.
Bill Watson
40605
Jeff Carpenter wrote:
talk to each other) yesterday I discovered that the common Linksys and
Netgear models are 7.5V. Should I be able to find a 12V hub? If
Jeff Carpenter
40304
N410CF
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Sun Apr 05, 2009 9:18 am Post subject: Re: Ethernet Hub |
That manufacturer sells online..
EIBA5-100T/R Five-port 10BASE-T/100BASE-TX switching hub, DIN-rail mount $99
(http://www.ccontrols.com/store/unmanaged.shtml#basswitch)
_________________ RV-7A
N777TY |
deej(at)deej.net Guest
Posted: Sun Apr 05, 2009 9:19 am Post subject: Ethernet Hub |
Quote: | In my quest to find a small ethernet hub (for the two AFS units to talk
Netgear models are 7.5V. Should I be able to find a 12V hub? If not,
Hi Jeff,
If you only have two ethernet devices, you should be able to use an
ethernet cross-over cable and have no need for a ethernet hub/switch.
If you have 3 or more ethernet devices, you'll need a hub or switch.
Here is a link to a typical cross-over cable:
<http://www.newegg.com/Product/Product.aspx?Item=N82E16812107216>
Here are lots more to choose from:
<http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N 52810132%201230513960&bop=And&Order=RATING>
Here are lots of ethernet switches - One of them will likely run off
12v directly:
<http://www.newegg.com/Store/SubCategory.aspx?SubCategory=30&name=Switches>
Does AFS have any recommendations? If you can use a direct cross-over
cable, that would be best I think.
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118 N421DJ KR-2 Builder N770DJ
http://deej.net/sportsman/ http://deej.net/kr-2/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
LarryRosen
Posted: Sun Apr 05, 2009 9:45 am Post subject: Ethernet Hub |
A search through the AFS support forum turn up the recommendation of a
Linksys SD205 5 port switch.
It is 12 volts and costs about $35.
Here is the spec sheet.
<http://www-qa.linksys.com/servlet/Satellite?blobcol=urldata&blobheadername1=Content-Type&blobheadername2=Content-Disposition&blobheadervalue1=application%2Fpdf&blobheadervalue2=inline%3B+filename%3Dsd205_ds%252C7.pdf&blobkey=id&blobtable=MungoBlobs&blobwhere=1193762395327&ssbinary=true&lid=0620947063B04>
Larry Rosen
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
daveleikam(at)wi.rr.com Guest
Posted: Sun Apr 05, 2009 10:00 am Post subject: Ethernet Hub |
AFS doesn't provide for this?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
stein(at)steinair.com Guest
Posted: Sun Apr 05, 2009 12:24 pm Post subject: Ethernet Hub |
We have them on our website for $145 in the accessories section...same unit.
They indeed are great little boxes that are very nicely built. Industrial
panel mount with metal enclosures. It's what we've been installing for all
the AFS or GRT panels we've been using.
Cheers,
Stein
[quote]--
jim(at)CombsFive.Com Guest
Posted: Sun Apr 05, 2009 2:05 pm Post subject: Ethernet Hub |
You could use a crossover cable (No hub required or the AFS units might automatically do the crossover function. I would contact them before hunting for a hub. Jim CN312F - FlyingDo Not Archive-----------------------------------------------------------------------------------------------------------> RV10-List message posted by: "Dave Leikam" <daveleikam(at)wi.rr.com>AFS doesn't provide for this?Dave LeikamRV-10 #40496N89DA (Reserved)Muskego, WI---
drfred(at)suddenlinkmail. Guest
Posted: Sun Apr 05, 2009 4:05 pm Post subject: Ethernet Hub |
I have a 3500 and a 3400. They just hooked together with a cable. No
need for a hub. I'd call AFS before I bought a hub.
Fred.
Jeff Carpenter
40304
N410CF
mauledriver(at)nc.rr.com Guest
Posted: Sun Apr 05, 2009 4:41 pm Post subject: Ethernet Hub |
You're welcome!
RV-7A
N777TY
http://forums.matronics.com/viewtopic.php?p 37827#237827
Posted: Sun Apr 05, 2009 5:28 pm Post subject: Ethernet Hub |
I have installed this in 2 different planes with multiple AFS screens
and the Wx receiver and have had no problems.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Apr 5, 2009, at 1:40 PM, Larry Rosen wrote:
a Linksys SD205 5 port switch.
Here is the spec sheet. <http://www-qa.linksys.com/servlet/Satellite?blobcol=urldata&blobheadername1=Content-Type&blobheadername2=Content-Disposition&blobheadervalue1=application%2Fpdf&blobheadervalue2=inline%3B+filename%3Dsd205_ds%252C7.pdf&blobkey=id&blobtable=MungoBlobs&blobwhere=1193762395327&ssbinary=true&lid=0620947063B04
Larry Rosen
jcumins(at)jcis.net Guest
Posted: Mon Apr 06, 2009 6:22 am Post subject: Ethernet Hub |
If your just linking 2 ea afs units then you can just use a Ethernet Cross
over cable and will not need a hub. If you want to connect more then 2
devices then you will need a Ethernet switch/hib.
If you want more info on a cross over cable shhot me a e-mail off list and I
will assist you.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
