HBaker
Posted: Sun Apr 05, 2009 4:35 pm Post subject: Looking for parts |
Hi guys
I am looking for a pulley on the prop governor and the power lead for the shower of sparks, and also the metal cap for the tach drive. I am hooking up the shower of sparks , and someone asked me if you anyone hooks up a bypass so you could hand prop the engine in case the battery failed?
Henry
Moose 294
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
_________________ Currently building a Murphy Moose - any help would be appreciated. |
Posted: Mon Apr 06, 2009 2:05 pm Post subject: Looking for parts |
Henry, what do you mean by: "and someone asked me if you anyone hooks up
a bypass so you could hand prop the engine in case the battery failed?"
If the battery fails, you will have no starting ignition system. Period.
What would you need to bypass if the battery was dead? The "shower of
sparks" system (or boost coil if you will) requires battery voltage to
operate. No way around that fact. Of course you could use an external
power source as an alternative, and the Russian aircraft have provisions for
doing exactly that using an external power connection. Is that what you are
talking about?
If the battery is dead, and you try to hand prop the engine, you are going
to be doing it on the mags alone. Which may or may not work, (and is very
dangerous) depending on who you talk to. Sometimes the engine seems to fire
instantly using hand propping on mags only. Sometimes it will not start at
all. I have spun it with compressed air and no shower of sparks with the
mags on and it never hit a lick. Other people just bump the prop and it
starts all by itself with the mags on. (I actually saw that happen once and
the prop hit the person doing it).
So what are you going to by-pass?
Mark
Description: |
 Download |
Filename: |
smime.p7s |
Filesize: |
4.81 KB |
Downloaded: |
896 Time(s) |
HBaker
Posted: Mon Apr 06, 2009 6:48 pm Post subject: Re: Looking for parts |
Mark
I guess your right , if you don't have battery power than you don't have to worry because there is no fire on the shower of sparks, I had a aircraft mechanic in the weekend and he mentioned about bypassing the start switch , because it would be hard to hand prop and depress the starter button at the same time, we are starting to wire it up and trying to find out how, I guess he wasn't thinking about that . can you use a regular silicone wire from the shower of sparks to the left mag??
Henry
skytrucks(at)aol.com Guest
Posted: Mon Apr 06, 2009 7:23 pm Post subject: Looking for parts |
Hello, this is maybe a little off subject, I will mention that I have adopted the use of the Yak cowling ring which is a beautiful piece of work, to a cowling system built and designed mostly by a friend of mine. The lower cowling is fiberglass amd we incorporated a 185 airbox and bracket air filter onto the M14P. I have an extra airbox and I could put anyone in touch with him on the fiberglass components.
Larry Luckinbill
SR 117 Moose
mikspin
Posted: Mon Apr 06, 2009 8:06 pm Post subject: Re: Looking for parts |
Henry,
I was just working on a Moose this weekend out in Wyoming, and the owner has a need for a metal cap for the tach drive. I suggested he track down a local machinist to turn a cap with metric threads to cover the original tach drive (he has the storage cap and of course the tach drive housing for patterns and threading measurements). If he comes up with something, I'll let you know, and by the same token, could you post here if you come up with one yourself?
Mike Hastings
Posted: Mon Apr 06, 2009 8:18 pm Post subject: Looking for parts |
Where is the Moose being built in Wyoming? I headquarter North West of Cody part time but am building my Moose just East of Billings MT at Columbus MT. I could also use a metal cap for my tach drive if some one comes up with a way to make some.
Larry Luckinbill
SR 117 Moose
cattoni(at)glastar.ca Guest
Posted: Mon Apr 06, 2009 9:22 pm Post subject: Looking for parts |
Hi Larry,
I am building a Moose with a friend . I would be interested in that air box . I live in Kelowna BC Canada . For how much would you sell it for ?
Peter
george(at)gesoco.com Guest
Posted: Tue Apr 07, 2009 4:04 am Post subject: Looking for parts |
Mike, We stock the metal caps.
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
SKYPE george.coy
motorstarna.com
mikspin
Posted: Tue Apr 07, 2009 5:15 am Post subject: Re: Looking for parts |
George,
Great! How much, and I assume they are drilled so they can be safety wired?
Also, I had a call into Cliff about the small rubber buttons that act as standoffs on the cylinder baffles (four per baffle), but have not heard back from him.
Mike Hastings
HBaker
Posted: Tue Apr 07, 2009 6:47 am Post subject: Re: Looking for parts |
Yes George
I would like to know how much for the caps as well, And is there a braided wire available for the shower of sparks as well or can you just use a silicone one?
Henry Moose 294
Posted: Tue Apr 07, 2009 11:30 am Post subject: Looking for parts |
Yes, that would work... I think what he is suggesting is this: Normally the
starter button activates the starter air valve and also turns on the
starting ignition system at the same time. You could in fact put in a
"bypass switch" that would allow you to PREVENT activating the starting air
system, yet STILL operate the starting ignition system. This could indeed
be used to handprop the aircraft and make it a tad bit safer since the
starter air valve would never be activated. This is a simple one wire
issue. It also assumes a 2 man procedure.
Most folks just shut off the main air line and bleed the air system until
there is nothing left to GO to the starter air valve, but to each their own.
Pushing the starter button and hand propping at the same time? I guess you
mean doing this all by yourself? No one in the cockpit? Well... That is
the exact method that was used to provide me my spare YAK-50. A nice fella
tried to do just that... It started. Away it went. Right into a hangar.
Not really something I would ever want to do. Further, the shower of sparks
// boost coil system is not something you want to turn on, get out of the
cockpit, walk around to the front of the aircraft, start it, then go back
and turn it off and then switch on the mags. Just not do-able. It also
would be really close to stupid. I doubt your mechanic meant that.
The system in the YAKS use a very very high voltage wire. It is a stranded
center conductor with a Teflon tape wind around it, and then a shield over
top of that. Remember that this wire goes directly into the mag cap itself,
and there is a ton of energy in that thing when it is both starting and then
running off the mag itself. This produces a lot of RF energy from all the
sparks, which will tear your radio to pieces. I have never tried straight
8mm silicone wire, but it should work.
Mark
Description: |
 Download |
Filename: |
smime.p7s |
Filesize: |
4.81 KB |
Downloaded: |
987 Time(s) |
Posted: Wed Apr 08, 2009 6:21 am Post subject: Looking for parts |
The Metal Cover for 14-611-283 Tach Flange is $26.50
Please call and give shipping address and credit card. You can use standard
shielded wire from an ols airplane harness. The shielding is necessary to
provide radio noise protection.
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
motorstarna.com
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
Posted: Wed Apr 08, 2009 6:23 am Post subject: Looking for parts |
The Metal Cover for 14-611-283 Tach Flange is $26.50. We do not have the
rubber buttons as a separate part. If you just need a few I can pull them
off some new old stock baffling.
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
motorstarna.com
HBaker
Posted: Sun Apr 19, 2009 5:57 pm Post subject: Re: Looking for parts |
How much trouble do you have with the shower of sparks? Or are you guys using the electronic one, and how much is it.
Posted: Mon Apr 20, 2009 3:17 am Post subject: Looking for parts |
They are quite reliable. Usually the problem is the wire from the starting coil to the magneto. A simple test is to make the spark jump to ground. If it is working properly when you press the button with 24-25 volts applied to the unit, it should jump to ground about 10 - 12 mm. If you have to hold it close to ground to get the spark to jump, the coil is weak or the internal points have build up on them.
Dennis
Posted: Mon Apr 20, 2009 9:17 am Post subject: Looking for parts |
To add to that comment.... I have had some really nasty problems getting
the high tension wire to properly make contact in the mag cap itself.
The spark is so strong that when it did not make good contact with the
"screw" that is supposed to penetrate the center of the high tension
wire from the high voltage starting coil (this is a Teflon insulated
wire on stock Russian systems) the high voltage arced out of the entry
point on the cap for the wire and to the mag's metal top cover. If you
ever smell something like rotten eggs after starting your engine, that
is the smell produced from the phenolic material burning up in the mag
cap as an arc burns it. My solution was to use a metal wire crimp
shortened to about 1/4 inch that I crimped onto the end of the high
tension wire, and then shoved that into the mag cap. When the screw
went in, it made a very good electrical contact to the metal wire crimp
and I have had no further problems. Before that, I would get it
working, or so it seemed, and then on a hot start the thing would just
not work at all... As in the engine would not start. Take it apart, cut
a little off the wire, re-penetrate the starting high tension wire with
the screw... And it would work AGAIN, for a few months.. And then do it
all over again. I did this no less than 5 times. The crimp thingy
fixed it.
Not suggesting this with the actual spark plug wires. If you have not
already done so, rip the stock ignition harness off your M-14 and
install Dennis Savarese's replacement kit. Considering the cost of the
kit as compared to the improvement to the engine, it is the best "bang
for the buck" of any M-14 modification I have ever seen. Don't leave
home without it!
This may sound like an advertisement... Sorry. It just is a big mistake
to not do this on an M-14 that you expect to be reliable in extreme
conditions. Like in a Moose.
Mark Bitterlich
db2005(at)2wings.com Guest
Posted: Mon Apr 20, 2009 2:17 pm Post subject: Looking for parts |
Mark,
Can you send any pictures of the crimp thing you're talking about?
Thanks!
Darin Bishop
www.2wings.com
yakplt(at)yahoo.com Guest
Posted: Mon Apr 20, 2009 2:34 pm Post subject: Looking for parts |
I'll go you one better. Send me your address and I'll send you a few.
You need a good crimp tool though... sorry, can't give you that!
Mark
send your address to: mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)
To: m14pengines-list(at)matronics.com
Sent: Monday, April 20, 2009 6:16:17 PM
Subject: Re: Re: Looking for parts
--> M14PEngines-List message posted by: "Darin Bishop" <db2005(at)2wings.com (db2005(at)2wings.com)>
Mark,
Thanks!
Darin Bishop
HBaker
Posted: Sun Jul 26, 2009 5:00 pm Post subject: Re: Looking for parts |
Hi this is Henry with Moose 294. skytrucks did you say you have a airBox for sale and if so how much??
Henry
