Richard Wheelwright
Joined: 15 Sep 2008 Posts: 111 Location: Halifax, West Yorkshire, UK
Posted: Tue Apr 07, 2009 12:26 pm Post subject: Fuel Vent Pipe |
Some Europas builders have mounted there fuel vent pipe on the bottom of there fuselage insted of the top. On the tri-gear, I was wondering what has been found to be the best location?
As picture paint a thousand words, I would be grateful for any you may have.
Thank you
Richard
Visit - www.EuropaOwners.org
_________________ Richard Wheelwright
G-IRPW
First Flight 24th July 2013 |
Posted: Tue Apr 07, 2009 3:10 pm Post subject: Fuel Vent Pipe |
Hi! Richard
If you do a bottom vent pipe exit (say out one of the flap control hinge
slots in the floor you need an anti-siphon collector bottle in the top
of the fuselage roof which can empty back into the tank with the vent
continuing out of the bottle in a higher mode.
Sorry no pictures available.
Bob Harrison G-PTAG Trike.
kevann(at)gotsky.com Guest
Posted: Tue Apr 07, 2009 5:50 pm Post subject: Fuel Vent Pipe |
I did mine the way Paul McAlister showed on his build web-site. Simple and
works very well. The "anti-siphon" fitting goes in the fuel filler neck. The
3/8" aluminum tubing vents well while filling the fuel. Thanks Paul!
Kevin
jeff(at)rmmm.net Guest
Posted: Tue Apr 07, 2009 7:37 pm Post subject: Fuel Vent Pipe |
Thats how I did mine and it's worked perfect for 2 years.
Jeff R.
A258 - N128LJ / Gold Rush 180 hours and hoping for clear weather for
Sn-N-Fun.
On Apr 7, 2009, at 8:48 PM, Kevin Klinefelter wrote:
<kevann(at)gotsky.com>
and works very well. The "anti-siphon" fitting goes in the fuel filler
neck. The 3/8" aluminum tubing vents well while filling the fuel.
Thanks Paul!
Kevin
