coop85(at)bellsouth.net Guest
Posted: Thu Mar 23, 2006 4:12 pm Post subject: Top Cowling Hinge Pins Access |
I suspect this will fall under the incredibly stupid question category, but
here goes. I'm installing the cowling and all is going well but I am
completely stumped about access to the top hinge pins. I installed the
center bracket per the plans and have no idea how to remove the pins with it
in place. Since the plans call for galling the screws, removing the plate
certainly isn't the solution. Maybe I gave up thinking about it to early,
but any advice would be deeply appreciated.
Marcus
40286
DEFINITELY Do Not Archive
Tim(at)MyRV10.com Guest
Posted: Thu Mar 23, 2006 4:38 pm Post subject: Top Cowling Hinge Pins Access |
The bracket fits flush with the cowling skin. When you loosen the
screws, you push the bracket down, leaving a gap all around it so
that you can pull the pins. The galling is just so that you don't
lose the bracket by screwing the screws out to far I think. I
didn't gall mine.
Marcus Cooper wrote:
Marcus
40286
Posted: Thu Mar 23, 2006 7:52 pm Post subject: Top Cowling Hinge Pins Access |
AAAHHHHH, thanks Tim. I don't think I would have figured that out.
Marcus
40286, cowling dangerously close to being finished
flysrv10(at)gmail.com Guest
Posted: Fri Mar 24, 2006 1:33 am Post subject: Top Cowling Hinge Pins Access |
The screws are supposed to be long. Long enough that the center
bracket can fall below the level of the pins when you unscrew the
fasterners. The galling just prevents the bracket from unscrewing all
the way and falling in the cowl. I hope thsi explanation is clear
enough.
On 3/23/06, Marcus Cooper <coop85(at)bellsouth.net> wrote:
Marcus
40286
