Posted: Mon Apr 13, 2009 8:13 am Post subject: MIG welding aluminum |
Kolb welding guys C
I recently had some heli-arc welding done on some aluminum for my MkIII turbocharger. (the intercooler and TBI "top-hat"). Although this method of welding aluminum is the best C it can get real expensive!! (I found the more often I went to this guy C the more expensive he got. (surprise C surprise!)
I talked to my local welding shop C and they say I can get some aluminum MIG welding wire C and use straight Argon gas (not the 25%/75% CO2/Argon mix I'm presently using for my small MIG welder)
The alum. wire and pure Argon allows one to weld "light" alum. projects.......they say.
Is there anyone out there that has experience with this combination C and can say whether or not it works very well? I have a lot of small aluminum projects that I'd do if I could weld them myself.
I have one of those 110V Lincoln wire feed welders C with the MIG conversion kit and 125 cu.ft. gas bottle. This set up is perfect for the home welder guy or gal. You can weld ALL kinds of things around the house. Nice set up. If I could switch steel wire to aluminum C that would be awesome!!
Mike Welch
MkIII
Quick access to your favorite MSN content and Windows Live with Internet Explorer 8. Download FREE now!
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out. [quote][b]
Posted: Mon Apr 13, 2009 8:23 am Post subject: MIG welding aluminum |
Kolb welding guys C
Mike Welch
MkIII
Quick access to your favorite MSN content and Windows Live with Internet Explorer 8. Download FREE now! [quote][b]
frank.goodnight(at)att.ne Guest
Posted: Mon Apr 13, 2009 9:10 am Post subject: MIG welding aluminum |
Mike I [think ] you can get a spool gun to go with you welder that uses flux core wire.and you do not have to use any gas. this may be bad info .But your welding suply store can tell you for sure.Frank Goodnight
Firestar 2
On Apr 13, 2009, at 10:08 AM, Mike Welch wrote:
| Quote: | Kolb welding guys,
I recently had some heli-arc welding done on some aluminum for my MkIII turbocharger. (the intercooler and TBI "top-hat"). Although this method of welding aluminum is the best, it can get real expensive!! (I found the more often I went to this guy, the more expensive he got. (surprise, surprise!)
I talked to my local welding shop, and they say I can get some aluminum MIG welding wire, and use straight Argon gas (not the 25%/75% CO2/Argon mix I'm presently using for my small MIG welder)
Is there anyone out there that has experience with this combination, and can say whether or not it works very well? I have a lot of small aluminum projects that I'd do if I could weld them myself.
I have one of those 110V Lincoln wire feed welders, with the MIG conversion kit and 125 cu.ft. gas bottle. This set up is perfect for the home welder guy or gal. You can weld ALL kinds of things around the house. Nice set up. If I could switch steel wire to aluminum, that would be awesome!!
Mike Welch
MkIII
Quick access to your favorite MSN content and Windows Live with Internet Explorer 8. Download FREE now! | Quote: | http://www.matronics.com/Navigator?Kolb-List
tlongo
Posted: Mon Apr 13, 2009 9:11 am Post subject: MIG welding aluminum |
Yes it works fine, the best type of gun for aluminum is one that pulls instead of pushes. I have that set up with a gun that pulls (spool on gun)
[quote] --
flykolb(at)pa.net Guest
Posted: Mon Apr 13, 2009 9:14 am Post subject: MIG welding aluminum |
Mike,
Theoretically you can use your mig for aluminum, but the big problem is the alum wire will jam in the welding cable very easily because the reel in your welder and needs to push the wire all the way through your welding cable, and … because the alum wire is not very stiff – it jams.
You probably would need a spool gun which has a small roll of aluminum right on the welding gun. Don’t know if they make a spool gun for your welder or not.
Dennis
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Mike Welch
Sent: Monday, April 13, 2009 11:50 AM
Subject: MIG welding aluminum
Kolb welding guys,
Mike Welch
MkIII
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out. | Quote: | | http://www.matronics.com/Navigator?Kolb-List | 0123456789
Posted: Mon Apr 13, 2009 9:27 am Post subject: MIG welding aluminum |
Mike: I have one of those Lincoln welders, but use flux core wire to weld steel. I used to weld aluminum with a "spool gun", where the roll of wire sits above your hand. I was told that a lot of the MIG's with the "whip feed" will not push the wire, and it will bind. See if you can get a roll to borrow (make sure you have the right tip in it) and see if yours will feed before you pick up the argon. Also, use a stainless steel wire brush or wheel to clean the oxide off aluminum before welding. You can weld heavy stuff, but one pass at a time. If it works, practice on a lot of scrap. You may also have to change the filter setting or lens number in the helmet. Be careful- if the aluminum gets too hot on multiple passes, it may collapse. It stays hot for quite a while, and the heat spreads through the material.
Good luck
Bill Sullivan
Windsor Locks, Ct.
FS 447
Posted: Mon Apr 13, 2009 9:28 am Post subject: MIG welding aluminum |
Tom and Frank C
Thanks for the replies. Frank C I wasn't concerned so much as using fluxless wire C as I was wondering how good a weld a guy could make. Since I have to have Argon gas C anyway C so for me to weld aluminum C I'd only have to change the wire roll.
It looks like both of you are on the same page C though C referring to the spool/gun.
I'll check this device out.
Thanks C Mike W
Subject: RE: MIG welding aluminum
Date: Mon C 13 Apr 2009 12:44:52 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Yes it works fine C the best type of gun for aluminum is one that pulls instead of pushes. I have that set up with a gun that pulls (spool on gun)
[quote] --
Posted: Mon Apr 13, 2009 9:43 am Post subject: MIG welding aluminum |
Dennis C
Ah ha!! Now I think I understand something a little better. I haven't checked out the spool/gun idea yet C but now I understand why the conversion kit for my welder has a new
cable.
When I talked to the guy at Airgas C he said the "MIG welding aluminum kit" has:
A) small aluminum wire roll
B) new feed cable with smooth teflon lining
He didn't exactly know why the new cable came with the kit. He wasn't familiar with the "softer" aluminum wire that may scrunch up. I asked him if I could just use my present unlined cable C and he said he didn't know why not. (now C I realize why not)
One thing he did say is that you HAVE to use straight Argon gas C no CO2/Argon mix C like I get away with for steel welding.
I think I'll take your advice C Dennis C toward the softer alum. wire C and go for the complete kit. I'll check and see if there is one of those spool/guns available.
Thanks guys C
Mike Welch
Subject: RE: Kolb-List: MIG welding aluminum
Date: Mon C 13 Apr 2009 13:02:53 -0400
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_EmailStyle19 {font-family:Arial;color:navy;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Mike C
Theoretically you can use your mig for aluminum C but the big problem is the alum wire will jam in the welding cable very easily because the reel in your welder and needs to push the wire all the way through your welding cable C and … because the alum wire is not very stiff – it jams.
Dennis
Sent: Monday C April 13 C 2009 11:50 AM
Kolb welding guys C
Mike Welch
MkIII
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out. | Quote: | | http://www.matronics.com/Navigator?Kolb-Listhttp://forums.matronics.com | 012
3Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out. [quote][b]
djwatson(at)olg.com Guest
Posted: Mon Apr 13, 2009 10:35 am Post subject: MIG welding aluminum |
Mike,
I probably have the same welder (WP-125) and my plan was to do lite aluminum also. I bought the MIG conversion, argon tank, aluminum wire, then found out that you also have to have a new non metallic liner in the cable that feeds the wire along with some other stuff, couldn't find the liner or "other stuff" so I have never been able to try it. The liner is needed to prevent the wire from binding and also to prevent contamination of the wire. I think the wire feed wheel is the "other stuff". Another way to go is to get a handle that has the wire spool attached which eliminates the wire having to go through the long cable.
Or you could buy your own AC/DC output TIG welder for a little over $2000.00 ---- It must be AC output or you cannot do aluminum.
My wish list is too long.
V/R,
Dennis in MD.
Posted: Mon Apr 13, 2009 10:39 am Post subject: MIG welding aluminum |
Sorry for the late response, should have read ahead, looks like you have the info.
Dennis in MD.
Posted: Mon Apr 13, 2009 12:15 pm Post subject: MIG welding aluminum |
Hi Dennis Watson C
Your welder is the newer version of mine. I have the 115V Lincoln "Weld Pak 100". Here's what I know C up to this point;
This is a dynomite welder for all the medium to small steel welding projects I do. I bought the K610-1 conversion kit C which turns it into a genuine MIG welder C plus I had to buy a decent size gas tank. I'm not sure it makes it all that much better. Maybe a little. Heck of a set up for around the shop!!
I haven't found anyone who sells a spool/gun that fits my small welder. However C I did find a product brochure that says to convert my Weld Pak 100 to weld aluminum C I need the additional K664-2 kit (along with the gas kit above K610-1). This kit has the smooth lined cable C to keep it from scrunching up.
A welding supply store sells the K664-2 kit on eBay for $65 C incl s/h. (The first kit K610-1 cost me about $135 or so. This kit contained the gauges C hose C and some misc parts to convert my welder to a MIG welder.)
So C I guess I'll go ahead and buy the aluminum conversion kit C and see how it does.
BTW. According to the Airgas guy C he said I don't need a darker lens for my helmet C like a TIG welder would need.
Thanks to all for your help C
Mike Welch
Subject: Re: Kolb-List: MIG welding aluminum
Date: Mon C 13 Apr 2009 14:33:46 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Mike C
I probably have the same welder (WP-125) and my plan was to do lite aluminum also. I bought the MIG conversion C argon tank C aluminum wire C then found out that you also have to have a new non metallic liner in the cable that feeds the wire along with some other stuff C couldn't find the liner or "other stuff" so I have never been able to try it. The liner is needed to prevent the wire from binding and also to prevent contamination of the wire. I think the wire feed wheel is the "other stuff". Another way to go is to get a handle that has the wire spool attached which eliminates the wire having to go through the long cable.
V/R C
Dennis in MD.
Posted: Mon Apr 13, 2009 12:33 pm Post subject: MIG welding aluminum |
Mike , I belive that Miller makes a spool gun that works with linclon welder [ it,s quite a bit cheaper than the linclon spool gun. ] My welder is the linclon 140c and the Miller gun works
with it.
Frank Goodnight
Firestar2
H.K.S.
On Apr 13, 2009, at 3:14 PM, Mike Welch wrote:
[quote]Hi Dennis Watson,
Your welder is the newer version of mine. I have the 115V Lincoln "Weld Pak 100". Here's what I know, up to this point;
This is a dynomite welder for all the medium to small steel welding projects I do. I bought the K610-1 conversion kit, which turns it into a genuine MIG welder, plus I had to buy a decent size gas tank. I'm not sure it makes it all that much better. Maybe a little. Heck of a set up for around the shop!!
I haven't found anyone who sells a spool/gun that fits my small welder. However, I did find a product brochure that says to convert my Weld Pak 100 to weld aluminum, I need the additional K664-2 kit (along with the gas kit above K610-1). This kit has the smooth lined cable, to keep it from scrunching up.
A welding supply store sells the K664-2 kit on eBay for $65, incl s/h. (The first kit K610-1 cost me about $135 or so. This kit contained the gauges, hose, and some misc parts to convert my welder to a MIG welder.)
So, I guess I'll go ahead and buy the aluminum conversion kit, and see how it does.
BTW. According to the Airgas guy, he said I don't need a darker lens for my helmet, like a TIG welder would need.
Thanks to all for your help,
Mike Welch
Subject: Re: MIG welding aluminum
Date: Mon, 13 Apr 2009 14:33:46 -0400
Mike,
V/R,
Dennis in MD.
ElleryWeld(at)aol.com Guest
Posted: Mon Apr 13, 2009 5:11 pm Post subject: MIG welding aluminum |
I have been a Welder for over 30 years a lot of the guys have good info but here is my opinion of what I would do
First, How thick of material are you looking to weld, anything 1/8 inch and thicker, a spool gun works great I run a couple L-Tec 28-A spool guns and Profax spool gun I like the L-TEC better, but these are more for production work.
if your looking to weld any thickness material "thick or thin" a Tig Torch
hooked to a welding machine with AC & High Freq is best no matter what Process you decide on 100% Argon gas is the only one to use to weld Aluminum
keep the welding area super clean durty aluminum does not weld good at all, Stainless steel brush (good advice )
I never had much Luck with the smaller mig machines welding aluminum and I have tried a few different ones over the years
Good luck with your welding adventure and if I can be of any help feel free to ask
Ellery in Maine
Building MK3Xtra
The00126575x1221621489x1201450100/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DAprilAvgfooterNO62> See Yours in Just 2 Easy Steps!
Posted: Mon Apr 13, 2009 5:41 pm Post subject: MIG welding aluminum |
Thanks for the tips C Ellery. At his time C and within my budget C I think I'll have to try that kit made for my small MIG welder. I'll post a comment about my successes or failures C after I get a chance to check it out.
My aluminum welding is what most could call "light". Probably 1/8" or less. I'm just looking for something that can do small projects once in awhile C without spending money on a TIG welder.
BTW C are you back to work on the MKIII Xtra yet?
Thanks C Mike W
Date: Mon C 13 Apr 2009 20:04:51 -0400
First C How thick of material are you looking to weld C anything 1/8 inch and thicker C a spool gun works great I run a couple L-Tec 28-A spool guns and Profax spool gun I like the L-TEC better C but these are more for production work.
keep the welding area super clean durty aluminum does not weld good at all C Stainless steel brush (good advice )
Ellery in Maine
Building MK3Xtra
Rediscover Hotmail®: Get e-mail storage that grows with you. Check it out. [quote][b]
Posted: Tue Apr 14, 2009 5:51 pm Post subject: MIG welding aluminum |
Oh yes I am back to work on it still re working 3 other guys work on it someone re designed some things on it that I don't like the looks of and
im not really in a hurry to get it together real fast unless the wind blows a bunch of cash my way out of the money tree, so I plan on taking my time I plan on having this one for a long time
Ellery in Maine
Building MK3Xtra
In a message dated 4/13/2009 9:41:54 P.M. Eastern Daylight Time, mdnanwelch7(at)hotmail.com writes:
| Quote: | Thanks for the tips, Ellery. At his time, and within my budget, I think I'll have to try that kit made for my small MIG welder. I'll post a comment about my successes or failures, after I get a chance to check it out.
My aluminum welding is what most could call "light". Probably 1/8" or less. I'm just looking for something that can do small projects once in awhile, without spending money on a TIG welder.
BTW, are you back to work on the MKIII Xtra yet?
Thanks, Mike W
Date: Mon, 13 Apr 2009 20:04:51 -0400
Ellery in Maine
Building MK3Xtra
Rediscover Hotmail®: Get e-mail storage that grows with you. Check it out. | Quote: |
f="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
The Average US Credit Score is 692. See Yours in Just 2 Easy Steps!
