Posted: Mon Apr 13, 2009 4:22 pm Post subject: pitot tube connectors |
Guys...
I have carelessly allowed the barb on the pitot tube connector used at
the wing root to be snapped off...these are those cute little white
nylon male/female connectors. I need a replacement. I note in the
Acft. Spruce catalog an item which APPEARS to be the right part; a P/
N 05-01036 which is listed as a fuel line connector for 1/4" tubing.
Inasmuch as the actual hole in the barb and tubing supplied w/ the kit
is only about 1/16" diameter, I question whether this size would be
appropriate for use as part of a fuel system.
Before I order the replacement part, is there anyone who can verify
that the P/N above is the correct size for the pitot system?
Thankx,
Fred
A194
believed to be clean.
paul.the.aviator(at)gmail Guest
Posted: Mon Apr 13, 2009 5:51 pm Post subject: pitot tube connectors |
Hi Fred,
I can't confirm that it is the correct part or not, but if it turns out that it isn't then I think you can find what you need at McMaster Carr. Take a look at:
http://www.mcmaster.com/#catalog/115/184/=1fnqwu
Which should be (if I haven't messed it up) page 183 of their catalog.
Also, when you get to plumbing up pitot static system I see that Stenair have some really neat connector systems. See http://www.steinair.com/pitot.htm
Regards, Paul
Posted: Mon Apr 13, 2009 6:32 pm Post subject: pitot tube connectors |
On Apr 13, 2009, at 6:49 PM, Paul McAllister wrote:
Thanks Paul...right on the money!
Fred
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. [quote][b]
budyerly(at)msn.com Guest
Posted: Mon Apr 13, 2009 7:20 pm Post subject: pitot tube connectors |
Fred C
The part is made by Colder Products Company (PC1701 and 1201 I believe) and I stock them in sets as I go through them like water and use them many more places. Some additional uses are: the manifold line C alternate static sources C Dynon pitot tubes where I build them on to a panel for convenient access C altitude encoder for testing C etc.
Everybody should have a spare set and a spare static end for the pitot. Good insurance.
They are about $5.00 a set.
email me off line and I can get you some.
Bud
Custom Flight Creations (813) 653-4989
Subject: Re: pitot tube connectors
Date: Mon C 13 Apr 2009 19:31:13 -0700
Fred
dangerous content by MailScanner C and is
| Quote: | http://www.matronics.com/Navigator?Europa-List
ronics.com
ww.matronics.com/contribution
rampil
Posted: Wed Apr 15, 2009 6:50 am Post subject: Re: pitot tube connectors |
If you would something really nice for the panel connection and the wing root, check out the Winter 9005 5x quick-disconnect at
http://www.cumulus-soaring.com/winter.htm#Tubing,_Connectors,_and_Miscellaneous
