bdanbish(at)gmail.com Guest
Posted: Mon Apr 13, 2009 9:29 pm Post subject: Door Hinges |
Since it looks like my kit is missing door hinges of any type, I'll have to get some. I seem to remember talk of stronger hinges for the doors being spec'd out at some point. Anyone have a vendor/part # handy?
Dan
Visit - www.EuropaOwners.org
kevann(at)gotsky.com Guest
Posted: Tue Apr 14, 2009 2:40 am Post subject: Door Hinges |
Hi Dan,
I used some stainless steel hinge that worked out nicely. I have several
feet of it left over because I had to order a minimum of 4 feet I think.
Want me to send you some?
Kevin
budyerly(at)msn.com Guest
Posted: Tue Apr 14, 2009 6:28 am Post subject: Door Hinges |
RE: Door hinges.
If you believe stronger hinges are needed C keep in mind that you will rip out the fiberglass in the cabin top or door tang instead of the hinge failing and maybe causing some minor cracking which is easily repaired.
During start and run up if you insist on leaving the door open C stronger hinges may be OK but you better lay some extra glass on the top.
I've replaced three sprung or lost doors over the last five years. He who had the stronger hinges paid more to have the top of the aircraft repaired C vs replacing the door.
The hing material is MS 20001-5. Available at Aircraft Spruce.
Custom Flight Creations (813) 653-4989
[quote] Subject: Door Hinges
Date: Tue C 14 Apr 2009 08:26:18 +0300
--> Europa-List message posted by: "danbish" <bdanbish(at)gmail.com>
Since it looks like my kit is missing door hinges of any type C I'll have to get some. I seem to remember talk of stronger hinges for the doors being spec'd out at some point. Anyone have a vendor/part # handy?
Thanks C
Dan
Posted: Tue Apr 14, 2009 9:30 am Post subject: Door Hinges |
Thanks guys, much appreciated.
