Float Flyr
Posted: Thu Apr 23, 2009 5:39 am Post subject: Kitfox Control Surface Flutter Mitigation |
I’m off the water generally in less than 500 ft reasonably calm conditions full gross. I can “land” in less than 300 ft for sure. 2/3 flap.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of W Duke
Sent: Thursday, April 23, 2009 9:31 AM
Subject: Re: Re: Kitfox Control Surface Flutter Mitigation
I use full flaps to land short. Full flap has not scared me. Maybe I don't know enough to be scared but I use full flaps almost all the time. Again, I usually do not use any flap until on final. Try getting slow at altitude to get the feel for it. (I may not be able afford new gear for you right now.) There is a change in the feel of the plane that takes a little getting used to. Nose is very high and once you get slow enough it feels almost like you are going down more than forward. But there is still elevator authority to flare. Not having that extra speed at flare really shortens the glide and landing distance.
Maxwell Duke
S6/TD/IO240
Dublin, GA
--- On Wed, 4/22/09, n85ae <n85ae(at)yahoo.com> wrote:
Subject: Re: Kitfox Control Surface Flutter Mitigation
Date: Wednesday, April 22, 2009, 8:57 PM | Quote: | --> Kitfox-List message posted by: "n85ae" <n85ae(at)yahoo.com> Maxwell - I take it you're doing this with 1 notch of flaperons? Winds permitting Imight work on this tommorrow after work. I generally slip it in around60, and then start flaring after the slip. 50 seems slow, but still there'sprobably about 10 mph left. If I bend the gear, I'll blame you. Definetly don't want to do that if it's gusting at all. Even with my | 0123456789012345678901
23456789 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 0 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 1 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 2 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 3 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 4 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 5 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 6 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 7 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 8 | Quote: | | I take it you're doing this with 1 notch of flaperons? Winds permitting I | 9 | Quote: | | might work on this tommorrow after work. I generally slip it in around | 0 | Quote: | | might work on this tommorrow after work. I generally slip it in around | 1
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Fox5flyer Guest
Posted: Thu Apr 23, 2009 7:17 am Post subject: Kitfox Control Surface Flutter Mitigation |
Jeff, mine acts the same way. I don't often use the full flaps for the same
reasons. Too squirrely. It feels like the ailerons are blocking out the
rudder in some way because I have to use about twice as much rudder to keep
it straight. If things are calm and I'm on short final I'll pull in full
flaps to slow my landing speed to get in short, but only when I absolutely
need it. Otherwise I always use first notch.
I'll take second dibs on the gear.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 405+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Maxwell -
I'm comfortable with the nose high attitude the plane gets when slow, so
that's no problem.
What I don't like is the full flaperons. I think at full nose up trim I
still have
to hold a lot of back stick, plus it really screws up the roll control.
I'll let
you be the expert on this subject.
Can we just start calling you Madmax on the forum from now on?
By the way, I think you have the same gear I have, so ... If you're
lacking funds you can just ship me yours.
Jeff
http://forums.matronics.com/viewtopic.php?p 40893#240893
n85ae
Posted: Thu Apr 23, 2009 9:55 am Post subject: Re: Kitfox Control Surface Flutter Mitigation |
Deke -
I flew mine a few times, and played with the second notch, but honestly
I do not like the handling of the plane and it makes me feel distinctly
uncomfortable with them like that. It uses all the trim just to fly it, and
the yaw, and roll control feel's weird, and spooky.
I wouldn't go so far as to safe it's not safe to fly the plane that way
but I sure feel insecure when they are deployed that much.
Jeff
Float Flyr
Posted: Thu Apr 23, 2009 10:33 am Post subject: Kitfox Control Surface Flutter Mitigation |
There is a point that I should make. When I got my plane I checked on the
adjustment of the ailerons. I didn't like the idea of a binding in the
mixing box when the ailerons were fully deflected. I decided to set my
adjustment so that there would be no binding. That gives me a degree or two
of reflex of my ailerons. Yes my ailerons are nowhere as deflected as they
were but then again there is also no way I can get my ailerons into reverse
control.
Noel
Kitfox III-A
Dick Maddux
Posted: Thu Apr 23, 2009 12:59 pm Post subject: Kitfox Control Surface Flutter Mitigation |
Speaking of flutter, I just returned from Lakeland. They had a Zenith 650 at the show and the hinges for the ailerons on that plane was the top wing skin ! There are no hinges ! Now perhaps I am getting the wrong picture here, but I like hinges. What happens when you bend aluminum sheet over and over and over. Eventualy it will fracture and break . Yeah ,I know it will take a while but I could not get close enough to the (crowds) Zenith folks to ask why they would do that.
I talked to an engineer at another mfg and asked why they would do that and he made sounds like a baby chicken (with a c)
Dick Maddux
Fox 4-1200
Pensacola,Fl
Big savings on Dell XPS Laptops and Desktops!
rjdaugh
Posted: Thu Apr 23, 2009 7:32 pm Post subject: Kitfox Control Surface Flutter Mitigation |
Jeff,
I wonder if you have your flaps setup correctly. I use full flaps a lot.
About the only times I don't use full flaps is if there is a lot of wind -
then I use half flaps. I also slip a lot. I need to try Maxwells
technique. I have some, but always chicken out and give a good shot of
power about 30' from ground.
Another item that I really like for getting in short is a lift reserve
instrument. Having this really changed the way I fly. I do not pay
attention to the airspeed gauge much any more and I usually climb out at a
much higher angle than I ever dared to before.
Randy
Series 5/7
912S, WarpDrive taper tip
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
matronics(at)bob.brennan. Guest
Posted: Fri Apr 24, 2009 3:21 am Post subject: Kitfox Control Surface Flutter Mitigation |
Randy -
Excuse my ignorance but what exactly is a "lift reserve instrument"?
Obviously I can surmise from the name what it does, and it sounds very
useful, but I have never heard of such a thing. I want one!
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade GSC prop
Wrightsville Pa
Patrick.Best(at)telus.com Guest
Posted: Fri Apr 24, 2009 5:08 am Post subject: Kitfox Control Surface Flutter Mitigation |
Chris Heintz wrote an article about the use of a skin as a hinge.
Design and Application of the
ZODIAC's Hingeless Aileron
http://www.zenithair.com/kit-data/ht-aileron.html
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Thursday, April 23, 2009 4:59 PM
Subject: Re: Kitfox-List: Kitfox Control Surface Flutter Mitigation
Dick Maddux
Fox 4-1200
Pensacola,Fl
[url=http:%2F%2Fad.doubleclick.net%2Fclk%3B214133440%3B36002254%3Bj]Big savings on Dell XPS Laptops and Desktops![/url]
ttp://www.matronics.com/Navigator?Kitfox-List
ics.com
.matronics.com/contribution
n85ae
Posted: Fri Apr 24, 2009 6:14 am Post subject: Re: Kitfox Control Surface Flutter Mitigation |
The plane is different with the 912
Yes they are set correctly. It may just be the heavier airplane. I'm at
967 empty weight with the the 240B. It's not an issue that I can't land
plane short, I can. The heavier nose airplane requires full trim which
means the tail incidence is all the down in the front. The roll control
is restricted, etc. So I don't use the second notch. The plane to me just
feels horrible handling in that configuration.
| rjdaugh wrote: | Jeff,
Float Flyr
Posted: Fri Apr 24, 2009 6:27 am Post subject: Kitfox Control Surface Flutter Mitigation |
It is also known as an AOA instrument... ( angle of Attack )
Noel
Kitfox III-A
Float Flyr
Posted: Fri Apr 24, 2009 6:43 am Post subject: Kitfox Control Surface Flutter Mitigation |
The zenith design of having a hingeless attachment of the ailerons is quite well proven. The length of the attach point, the grain of the metal and the smallmovement the ailerons make all combine to make it very safe. That is one part of the plane that is secure. Apparently there are reasons for and against having the hinged and hingeless ailerons. I’m suer the people at Zenith will be more than happy to let you in on all features of both systems.
Noel
Sent: Thursday, April 23, 2009 6:29 PM
Dick Maddux
Fox 4-1200
Pensacola,Fl
Big savings on Dell XPS Laptops and Desktops! | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
Posted: Fri Apr 24, 2009 6:54 am Post subject: Kitfox Control Surface Flutter Mitigation |
So can you derive "lift reserve" from angle-of-attack? I know that it's the
AoA that determines when a wing will stall, not the airspeed, but on flare
we hold the stick back for a high AoA to bleed off airspeed and hopefully
maintain a constant close distance to the ground, but during that time the
"lift reserve" is diminishing until the airplane settles onto the runway.
Would an AoA instrument give an indication that correlates to that,
specifically during flare?
bob
Guy Buchanan
Posted: Fri Apr 24, 2009 7:29 am Post subject: Kitfox Control Surface Flutter Mitigation |
At 06:06 AM 4/24/2009, you wrote:
| Quote: | Chris Heintz wrote an article about the use of a skin as a hinge.
An interesting article, as much for what it omits as for what it
includes. Though Mr. Heintz has done a great job of analyzing the
flexural properties of the hinge he says nothing whatsoever about its
lack of transverse stiffness. 3/4" of 0.016" aluminum has very little
shear stiffness. This allows the leading edge of the aileron to
translate perpendicular to the skin surface. I'm guessing I could get
the example leading edge to translate vertically +/- 1/16" without
much trouble. If that leading edge happens to be in front of the
aileron's CG you have a recipe for flutter. That's why most designers
use piano hinges. They locate the leading edge not only in the plane
of the skin, but perpendicular to the skin line as well.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Apr 24, 2009 7:43 am Post subject: Kitfox Control Surface Flutter Mitigation |
I think that an angle of attack indicator and lift reserve indicator do
pretty much the same thing. The typical angle of attach instrument uses a
small vane that mechanically determines the angle of attack. The lift
reserve indicator uses differential pressure from two ports on a short wand
to determine the same thing. I have always thought of the naming as just a
marketing thing to differentiate the mechanical from the differential
pressure approach to the measurement. There is one design that uses small
holes at different points of the leading edge if the wing to determine
differential pressures.
Regarding my installation. I plan on mounting the readout gauge below the
glare shield with a a mirror to correct the image before it bounces off a
clear glass reflector, just like the heads up displays on military aircraft.
I hope to have it exactly in my forward vision during the critical
attitudes.
Lowell
n981ms(at)yahoo.com Guest
Posted: Tue Apr 28, 2009 4:55 am Post subject: Kitfox Control Surface Flutter Mitigation |
Been off the list for a few days while at SNF. There is certainly adverse yaw with full flap roll control. One can see why when at full flap a right aileron input results in a little more down on the left flaperon and therefore more left drag and up flaperon on the right with less drag. Now that we are using words like spooky I am thinking I will go back out and compare 1 vs 2 notches and see. I just almost always use full flaps lately. Certainly I wish there was more up trim but I need more up for even one notch of flap. John McBean makes something to help with this.
By the way. It was good to see John and Kitfox at Sun N Fun again. For me, if they had not had a presence there when I was kit shopping I would probably have not built a Kitfox. I hope they sell a bunch of airplanes and continue to have a presence in the east.
Maxwell Duke
S6/TD/IO240
Dublin, GA
--- On Thu, 4/23/09, n85ae <n85ae(at)yahoo.com> wrote:
| Quote: | From: n85ae <n85ae(at)yahoo.com>
Subject: Kitfox-List: Re: Kitfox Control Surface Flutter Mitigation
Date: Thursday, April 23, 2009, 1:55 PM
Deke -
Jeff
http://forums.matronics.com/viewtopic.php?p=240930#240930
patreilly43(at)hotmail.co Guest
Posted: Tue Apr 28, 2009 1:50 pm Post subject: Kitfox Control Surface Flutter Mitigation |
Hey Guys C Lowell Fitt has an elevator trim tab installation that if you talk nice to him he will sell you the parts to install it yourself. I'm using the electric servos as he does. But C you could easily adapt it to cable control and with a little work you'll only spend peanuts for the whole setup.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Date: Tue C 28 Apr 2009 05:46:16 -0700
By the way. It was good to see John and Kitfox at Sun N Fun again. For me C if they had not had a presence there when I was kit shopping I would probably have not built a Kitfox. I hope they sell a bunch of airplanes and continue to have a presence in the east.
Maxwell Duke
S6/TD/IO240
Dublin C GA
Date: Thursday C April 23 C 2009 C 1:55 PM
Deke -
I flew mine a few times C and played with the second notch C but honestly
uncomfortable with them like that. It uses all the trim just to fly it C and
the yaw C and roll control feel's weird C and spooky.
Regards C
Jeff
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
