frank(at)dykaslaw.com Guest
Posted: Fri Apr 24, 2009 12:36 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
I might be able to help here. Kitfox model currently in kit and LSA
production is the Super Sport. It's basically a refined Series 7. The
cabin is wider, and the plane is truly refined.
Here's a little history. The Series 1, 2 and 3 have a smaller fuselage,
much narrower passenger compartment, and need a lot of rudder control
inputs. The Series 4 was a redesign of the Series 3, and is a much better
handling airplane. There are probably a couple thousand Series 4's out
there. This is the design that most others copied (but not Zenith), think
of the Eurofox. It's a great aircraft, but again, a narrow cockpit that
will hold two people if they are good friends. It's about the same width at
the Zenith if I remember correctly.
There were two Series 5's. The original Series 5 has a gross weight of 1340
lbs, and was tailwheel only. The later Series 5 has a beefed up fuselage,
and a possible gross weight of 1550. I'm not sure, but I think all Series
5's are tail draggers. The Series 6, amongst other changes, is configurable
with either a nose wheel or tail dragger. It's often called the Vixen.
The Series 7 is a Series 6 with a much improved wing and flapperon assembly,
and is a refined aircraft. It is easily converted between nose wheel and
tail dragger. It's got a wider cockpit. Can fly with either the 80hp 912
or 100hp 912S. There are two configurations for elevator trim, first is a
stablator, second are trim tabs. Accord to John McBean, the stablator is
better and that is the current configuration for Super Sport.
The current production model is the Super Sport, and it's a refined Series
7, which adds back some of the better features of the Series 6 which were
dropped from the Series 7 when Skystar owned the company. It's a nice
airplane and it's much wider in the cockpit than the Zenith. It's also
faster. It can be built as an eLSA, with the lowered gross weight, or as a
straight experimental with a 1550 weight, or now purchased as a preassembled
LSA from Kitfox Aircraft. It is a versatile aircraft that can go low and
slow, in the mountains, yet still is comfortable enough to long cross
country travel.
I looked at both, and chose the Kitfox. Glad I did.
Frank
Float Flyr
MDKitfox(at)aol.com Guest
Posted: Fri Apr 24, 2009 1:37 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Frank,
Good run down. One slight correction. The original Series V was a 1400 LBS gross weight. A thicker spar upped it to 1550.
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Apr 24, 2009, at 4:35 PM, Frank Dykas wrote:
[quote]--> Kitfox-List message posted by: "Frank Dykas" <frank(at)dykaslaw.com (frank(at)dykaslaw.com)>
country travel.
Frank
rjdaugh
Posted: Fri Apr 24, 2009 3:02 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
As long as we are picking on Frank, one more correction. The series 5 could be purchased as either a tail dragger (Outback) or as tricycle gear (Vixen – I don’t know why they needed names!). You had to make a choice when you ordered. The 6 and 7 can be set up either way or switched back and forth.
Good job though Frank. It is easier and more fun to criticize….
And I am sure that the ktifox has a better glide ratio, but still not fantastic at about 10:1.
Randy – one of the biased Fox owners.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Weiss Richard
Sent: Friday, April 24, 2009 3:30 PM
Subject: Re: Newbie questions, which easier to fly a Kitfox or a CH 701
Frank,
Rick Weiss
SkyStar S/N 1
Port Orange, FL
<![if !supportLineBreakNewLine]> <![endif]>
country travel.
Frank
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
helili(at)chahtatushka.ne Guest
Posted: Fri Apr 24, 2009 3:09 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Actually, The Cessna 150 and larger Cessnas (170, 172, 175, 180, 185, 185,
etc.) are of SEMI-monocoque construction.
John Hart
KF IV, NSI Subaru
Wilburton, OK
motoadve
Posted: Fri Apr 24, 2009 5:35 pm Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH 7 |
Thanks a lot for the replies.
Wouldnt the CH 701 be safer at a stall speed of 30mph instead of 37of the kitfox 4 or 41 in the Super sport?
According to this numbers the Kitfox will stop flying before the CH 701 in case of an emergency.
Im not expert at all so flame away.
Float Flyr
Posted: Fri Apr 24, 2009 6:33 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Point! They do have a steel frame around the cockpit. But one good dent in
the rear fuse will ground them.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Fri Apr 24, 2009 6:52 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Sorry no flame here. To get the 30 mph stall the Zenith has to attain a
pretty extreme attitude and basically hang on the prop. Not the best
procedure for a power out landing. On the other hand I make almost every
landing on floats a power off final to touchdown.
Noel
Kitfox III-A
dave
Posted: Sat Apr 25, 2009 2:29 am Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH 7 |
701 is a high drag airplane. The glide ratio is far less that a Kitfox.
Here is some Deadsticking in a Kitfox http://www.youtube.com/watch?v=bm1iqcn8nFM
| motoadve wrote: | Thanks a lot for the replies.
Im not expert at all so flame away. |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
JetPilot
Posted: Sat Apr 25, 2009 5:55 am Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH 7 |
You can put VG's ( Vortex Generators ) on the Kitfox, and the stall numbers will be very close to the CH-701 if not the same... When you are only talking 2 or 3 MPH, there is no safety difference anymore due to speed, other things become much more important.
The Superior glide ratio of the Kitfox is a HUGE safety factor. Lets say you where at an altitude where you could glide a mile in a Zenair CH-701 and your engine quit, that would give you an area of 3.14
Square miles that you could land in. Now lets say you were in a Kitfox that has twice the glide ratio and your engine quit, you would have an area of 12.5 square miles in which to find a landing area. In other words, if you double the glide of an airplane, you have FOUR TIMES the amount of area to search potential landing spots. I am not saying the Kitfox does have exactly twice the glide, but it is a LOT better than the CH-701, and every time you double the glide ratio, landing areas increase by a factor of FOUR !!
The Kitfox will also give you more time in an engine out situation due to its much lower sink rate. Again, would you rather have 1 minute to chose a spot, and execute an emergency landing, or 2 minutes, the Kitfox has a HUGE safety advantage over the Zenith CH-701 in an engine out situation.
So that is the engine out performance comparison in a nutshell, Dave, did you read my post about the performance comparison of the Kitfox and the Zenair CH-701 that is located here:
http://forums.matronics.com/viewtopic.php?t=57516
Mike
Kolb MK-III Xtra, 912-S |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Apr 26, 2009 10:25 am Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Mike,
FYI, and this has been mentioned many times on the list, often by very
careful observers - vortex generators do very little to stall speed
reduction with the Kitfox wing - in most instances not measureable. Control
stability is almost universally reported, but no effect on stall speed.
All this despite what we all know about vortex generators.
I have heard some talk on this and it just might be that the Riblet airfoil
Kitfox uses is not a true airfoil as the design profile only exists at the
fuel tank, rib caps, the false ribs and maybe three inches at the wing tip.
A total of about four feet on each wing. The rest is a different profile
because of the depression due to the fabric shrinking between the ribs and
false ribs. Harry Riblet tells us that the most critical point on this
airfoil is the first five inches. This is exactly where the leading edge
cuff and spar give away to the collapsed fabric. There are several
airplanes currently being built with "D" profile leading edges that will
protect the leading edge shape and these might benefit from vortex
generators. But the proof will be in the testing rather than the hoping.
Lowell
motoadve
Posted: Sun Apr 26, 2009 10:50 am Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH 7 |
Thanks for the replies.
So vortex generators are made /tested and sold by the Kitfox factory? or is just an aftermarket product?
Is not totally tested yet?
I wanted the CH 701 becasue is a STOL and I also prefer all aluminum plane, I might not have a hangar all the time.
What about the Savannah? looks like the CH 701 but has no slats and the performance claims as STOL are the same.
Is the Highlander full aluminum?
I weight 165 and plan to fly always with friends or wife ect, usually go to the beach being able to fly low and slow over the shore, pick a place to land take a swim go up again.
Go following rivers, sightseen ect, just plain flying, not planned cross country trips because Costa Rica is montaneous windy , rainy and many Cessnas are burried in the mountains, the area I plan to fly is on the caribeanside which is totally flat.
Float Flyr
Posted: Sun Apr 26, 2009 2:03 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Several 701 owners have taken the slats off their wings and installed Vortex
Generators (VGs) From what I've read they get similar STOL performance with
better glide and speed.
Noel
Kitfox III-A
dave
Posted: Sun Apr 26, 2009 5:39 pm Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH 7 |
There is a VG thread started here http://rotaxaircraft.com/forum/viewforum.php?f=33
John Gilpin some STOLSPEED.com is over there too. I have used both Harrison and Stolspeed VGs. I prefer Stolspeed's to 2 main reasons.
1, rounded edge makes it easier for washing.
2. They come with kickass adhesive the harrioson ones do not.
Now I have tested VGs only at 10% on my Kitfox IV. Results are minimal. I plan to move them and see what changes.
Only things i noticed was maybe a reduction in stall 1 - 2 mph if that .
Power off stall no buffeting just a controlled mush.
Power on stalls - no warning or buffeting - you will get a fast wing drop and go into spin.
I think i might have a little steeper angle of climb now .
No change in cruise speed.
I still have them on.
I used some harrison VGs on cowl mod and reduced coolant temps
http://www.cfisher.com/cowl.html
