pilotdds(at)aol.com Guest
Posted: Sun May 10, 2009 4:39 pm Post subject: Front wheel service |
Anyone use the nut at the bottom of the fork as a jacking point to service the front wheel?What are you guys doing to jack up the aircraft for front wheel service.I am told weighting down the tail can cause damabe.thanks-jim
dlm46007(at)cox.net Guest
Posted: Sun May 10, 2009 5:54 pm Post subject: Front wheel service |
we use wing jacks and a tail weight (attached at the tie down ring) to lift the aircraft off the floor. A floor jack would be ok if just the nose wheel needs service but still should be aware not to raise the nose to high to avoid an inadvertent tail strike.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com
Sent: Sunday, May 10, 2009 5:38 PM
Subject: Front wheel service
Jim Berry
Posted: Mon May 11, 2009 7:47 am Post subject: Re: Front wheel service |
I use a loop of 1" nylon webbing through the upper tubes of the engine mount, then lift with my engine hoist. Get the stuff climbers use, not the HD stuff. Climbers webbing is good for 6,000 lbs.
Jim Berry
40482
N15JB
gengrumpy(at)aol.com Guest
Posted: Mon May 11, 2009 8:19 am Post subject: Front wheel service |
I have used it, but makes checking the torque on the fork swing impossible.
I just used a 2x4 (padded) and 2 bottle jacks (built like Tim's) just aft of the exhaust pipes under the fuselage. Worked great!
grumpy
On May 10, 2009, at 7:38 PM, pilotdds(at)aol.com (pilotdds(at)aol.com) wrote:
[quote]Anyone use the nut at the bottom of the fork as a jacking point to service the front wheel?What are you guys doing to jack up the aircraft for front wheel service.I am told weighting down the tail can cause damabe.thanks-jim
Tim Olson
Posted: Mon May 11, 2009 6:19 pm Post subject: Front wheel service |
I used to be worried about using the tail ring to pull down on the
tail and jack up the nose, so before, I would un-cowl and use
an engine hoist to lift up the front. It was very inconvenient, but
it worked. More recently though I started to think about it a
bit...
The RV-10 has had NUMEROUS cases of 2 people trying to board the
plane at the same time, resulting in a tail strike. Yeah, it
balances fine on it's 3 legs, but it doesn't take THAT much
force to tip it. If you are really concerned, you can always
keep maybe 4 lead shot bags in the hangar and throw them in the aft
baggage area, and that would help offset some nose weight during
the pull. So now I'm perfectly comfortable with the concept
of pulling the tail down to lift the nose. It just
doesn't take that much force. What I did is to cut a hole
in my asphalt hangar, and pour in a 1'x1'x1' cube of concrete
under the floor, with an embedded large 12" long turn buckle
that came up flush to the floor. So now I just thread in the
tail eye, and a floor eye, and I use a simple come-a-long
cable puller to crank the plane down and hold it.
I'm less comfortable with the aft loading that it would take to
tow the plane into the hangar with a winch, although I've done that
a couple times now and it's worked out fine. I only used it when
I had to tow over ice. I have a remote-controlled winch that only
runs about 1 second per button push, and I push on the front
of the plane while I run the winch, so even that cable isn't having
to pull too awful hard. I wouldn't do it if I had to pull
up a steep incline though.
Tim Olson - RV-10 N104CD
David McNeill wrote:
[quote] we use wing jacks and a tail weight (attached at the tie down ring) to
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*pilotdds(at)aol.com
*Sent:* Sunday, May 10, 2009 5:38 PM
*To:* rv10-list(at)matronics.com
*Subject:* Front wheel service
damabe.thanks-jim
billderou(at)yahoo.com Guest
Posted: Tue May 12, 2009 8:13 am Post subject: Front wheel service |
I have tried using a block & tackle pulling the tail to the floor, and building a bench and using bottle jacks under the firewall to lift the nose. Not happy with either method.
Got busy designing and my latest scheme thusfar is the safest and most convenient.
From the tail tiedown I suspended a hook with weights just like a balance beam. Each weight or platter weights 35 lbs and is 3.5" thick made from cast concrete (with some ribarb support embedded). The basic hook is 3/8" ribarb that is approx 18" top to bottom with a platter cast into the bottom. I just add the platters until the tail is somewhat balanced with the nose wheel. Since the main gear provides an "over-center" geometry I can (with one hand and a coffee cup in the other) drop the tail within 18" of the ground or raise the tail and the nose will stay on the ground.
Very quick and handy and I only need to move 35 lbs at a time. Six or seven platters will do the trick. Sorry for the lack of a picture but I am traveling at this time.
If anyone has factual information from Vans engineering that this technique will harm the airframe then please respond.
Bill DeRouchey
N939SB
--- On Mon, 5/11/09, Miller John <gengrumpy(at)aol.com> wrote:
Subject: Re: Front wheel service
Date: Monday, May 11, 2009, 9:11 AM
grumpy
bkbrown(at)minetfiber.com Guest
Posted: Tue May 12, 2009 9:13 am Post subject: Front wheel service |
Go to many aircraft shops and you’ll see many examples of something along the lines of a 5 gallon bucket (or plywood framed wooden box), on wheels, filled with a bag or two of sakrete (premixed concrete) and set with an anchor bolt with an eye on top just about in the center of the box or bucket. You can roll it around wherever you want it and use it as an anchor point for your tie down ring. Just another variation of mounting a tiedown ring in your hangar…I’ve also seen old tires used like this, but they’re not so convenient to move as a heavy “box” on wheels.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Tuesday, May 12, 2009 9:10 AM
Bill DeRouchey
N939SB
grumpy
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Wed May 13, 2009 9:48 am Post subject: Front wheel service |
One of the things that Bill's design does that some others do not is make it convenient – even _possible_ for some of us – to move the weights around. Also, it is self-centering - no need to place the tail exactly over a fixed anchor point.
The downward pull on my plane's tiedown ring is something just less than 300 lb, I think, with engine and prop, but no tail feathers or wings or interior seats and such.
My "anchor" comprises 12" X 12" X 1 1/2" concrete pavers in four stacks on a square wooden frame that has four casters near the corners. The frame is 2X4s on edge supporting a 1/2" plywood platform, about 28" X 28" overall. I needed twenty pavers, sixteen was too few. The pavers weigh about 17 lb for a total of 340 lb, more or less. A bolt placed horizontally through the frame at the center provides an attach point for the block and tackle that pulls the tail down. A small come-along would have been better, but I already had the block and tackle. The casters let the anchor center itself under the tiedown ring. If the pavers are not stacked evenly or if there are too few of them, the frame lifts off the floor and tips, so I strap the pavers down to the frame with nylon straps and ratchets from Costco "just in case" and use a few more pavers than the minimum required. That gives a nice, stable anchor.
This approach was cheaper and quicker (for me), but it's not nearly as elegant and usable as Bill's, nor is it as safe. Also, the anchor takes up a lot of floor space in the heavy traffic area at the tail.
"Next time" I would probably invest the time and effort needed to cast all those weights and follow Bill's approach.
On May 12, 2009, at 10:01 AM, Bob and Karen Brown wrote:
[quote]Go to many aircraft shops and you’ll see many examples of something along the lines of a 5 gallon bucket (or plywood framed wooden box), on wheels, filled with a bag or two of sakrete (premixed concrete) and set with an anchor bolt with an eye on top just about in the center of the box or bucket. You can roll it around wherever you want it and use it as an anchor point for your tie down ring. Just another variation of mounting a tiedown ring in your hangar…I’ve also seen old tires used like this, but they’re not so convenient to move as a heavy “box” on wheels.
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Bill DeRouchey
Bill DeRouchey
N939SB
--- On Mon, 5/11/09, Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)> wrote:
From: Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)>
grumpy
tc1234c(at)roadrunner.com Guest
Posted: Wed May 13, 2009 10:57 am Post subject: Front wheel service |
For my 9A I brought a round dolly with four swivel casters, two short rebars, a segment of steel chain, and a few bags of pre-mix concrete (80 lb each) from Lowes. I tied rebar in a cross and passed the center through one end of the chain links. Then I used cardboard to make a cylindrical form and kept the chain at the center of the cylinder by supporting the other end of the chain on top of the form. After mixing and pouring concrete in the form I made myself a free casting tail weight. It is cheap and easy to make.
Ted
T.C. Chang
http://3limafoxtrot.com/
RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, left Mag + right Lightspeed EI, Sensenich FP
GRT dual DU H1, TT DigiFlight II VSGV, 573 hrs Hobbs
Last flight: http://www.mail2600.com/cgi-bin/track.cgi?call=KD8IIR&last=1
RV10 emp, #40948
coop85(at)verizon.net Guest
Posted: Thu May 14, 2009 8:39 pm Post subject: Front wheel service |
Looks like I’m the first to respond Yes to your question. Very unconventional, but I found if I put a standard wheel chock forward of the wheel, then put a 2x4 under the nut on the bottom of the fork, over the chock and then sit on it I can lever the wheel up comfortably, remove the wheel and then put boards under the fork while I work on the wheel.
There are some stability concerns, but it’s worked great for me using a little caution.
Marcus
Do not archive.
Sent: Sunday, May 10, 2009 8:38 PM
Posted: Fri May 15, 2009 3:33 pm Post subject: Front wheel service |
Thanks Mark that is exactly what I did-worked great with caution.
