Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Fri May 29, 2009 9:42 am Post subject: Mounting the Engine |
I experienced zero problems hanging the engine prior the installing the forward upper skin on both the -6A and the -8. I completed all instrument wiring and tested the radios and other panel circuitry while the fuselage was still in the garage minus the wings. Indeed, having that open access greatly eases ergonomic complications when working behind the instrument panel. Make it easy on yourself. Put off installing that upper skin until you absolutely have to. The first photo documents engine installation on the -8 without the forward upper skin in place. In fact, for a good fit I recommend you do not complete the forward baggage door installation until AFTER the engine is hung.
As far starting the engine, as the second photo graphically shows I simply 100% clecoed the -6A upper skin into place for the first engine starts and the procedure worked out just fine, not one cleco managed to vibrate loose.
Rick Galati
N307R RV-6A "Darla!"
N308R RV-8
chris_hand(at)comcast.net Guest
