rickpegser(at)yahoo.com Guest
Posted: Sat Jun 06, 2009 8:36 pm Post subject: telemetry |
we have been playing with telemtry for our rockets. using gps modules to track them and an interface to the altimeters. the equipment has come to the cost point that that you can build a remote telemetry module for less then 500$ with a 7 mile range. durring test flight this might be a good idea, forget watching the panel the ground crew is doing it for you. just a thought. if anybody wants to know how to do it give me an email off list at rickpegser(at)yahoo."you know what"
rick
--- On Sat, 6/6/09, Kevin Horton <khorton01(at)rogers.com> wrote:
| Quote: | From: Kevin Horton <khorton01(at)rogers.com>
Subject: Re: ROD END BEARING JAM NUT - Torque
To: rv-list(at)matronics.com
Date: Saturday, June 6, 2009, 10:30 AM
If you could get a torque wrench on it, you would want to
use a torque value for a shear nut. E.g., if it was
10-24, you would want 12-15 in-lb, according to the torque
table in AC43.13-1B.
Kevin Horton
On 6-Jun-09, at 09:25 , Michael Kraus wrote:
> Why would you not use the standard torque specified
for a bolt/nut of the size being
torqued?? Like if it is 10-24 then it would
be 20-25 in lbs.... Etc
> Sent from my iPhone
> On Jun 6, 2009, at 8:40 AM, Kelly McMullen <kellym(at)aviating.com>
wrote:
>> Yes. If that is sufficiently tight for your
calibrated wrist and ability to hold wrench on nut, it isn't
going anywhere.
>> Garey Wittich wrote:
>>> . Is this 1/8 turn adequate for the Jam
Nut tightness, if NOT how do you turn the Nut (since it is
recessed) ????
>>> W
>> <mime-attachment.jpeg>
Kevin Horton
Ottawa, Canada
Forum -
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
sbuc(at)hiwaay.net Guest
Posted: Sun Jun 07, 2009 5:55 am Post subject: telemetry |
RICHARD MILLER wrote:
The infrastructure is already in place for *worldwide* monitoring of
flight data. Many of us have adopted the APRS protocol for tracking our
aircraft:
http://www.vansairforce.com/community/forumdisplay.php?f=104
http://www.vansairforce.com/community/showthread.php?t 7773
http://aprs.fi/?call=N399SB&mt=m&z=10&timerange=3600
This is a service in the ham radio two-meter band that already provides
GPS location, heading, speed, and altitude. The data is displayed on
internet servers that provide real-time monitoring anywhere at no cost.
There are some new APRS trackers coming soon that will allow much more
data to be transmitted. It will be up to someone to engineer the
interface between the aircraft parameters and the tracker, but with
engine monitors spitting out a serial stream, this shouldn't be
unsurmountable.
Sam Buchanan
Posted: Sun Jun 07, 2009 5:20 pm Post subject: telemetry |
SAM
we have this for the rockets too. the reason most of us don't use it, is the test requirements and the cost. for the rockets we use two xbee pro xsc radio modems. one mounted to a ttl serial board this one talks to the on board pic which does three axis g, baro altimeter , fire the ejection charges, and passes the gps info the modem. cost to build 200.00$
base unit xbee pro xsc mounted in a usb board attached to the laptops. cost to build 100.00$
add on cost for aircraft telemtry. about three hundred for the extra sensors and pic capable of handling them. figure three axis gyro and accelerometer, static and pitot pressure, oil pressure and temp, cht and egt
our concern with the rockets is where the hell did they go. when you slap a 20 lb rocket in ths butt with 500lbs. of thrust, it has a tendancy to go out of sight. even if you can see it it will be a long walk and at three or more miles away they can be hard to find.
rick
--- On Sun, 6/7/09, Sam Buchanan <sbuc(at)hiwaay.net> wrote:
| Quote: | From: Sam Buchanan <sbuc(at)hiwaay.net>
Subject: Re: telemetry
Date: Sunday, June 7, 2009, 6:44 AM
<rickpegser(at)yahoo.com>
using gps modules
equipment has
remote telemetry
test flight
the ground crew
to know how to
monitoring of flight data. Many of us have adopted the APRS
protocol for tracking our aircraft:
already provides GPS location, heading, speed, and altitude.
The data is displayed on internet servers that provide
allow much more data to be transmitted. It will be up to
someone to engineer the interface between the aircraft
parameters and the tracker, but with engine monitors
unsurmountable.
Sam Buchanan
Forum -
FAQ,
-Matt
Dralle, List Admin.
