369PL
Posted: Sat Jun 13, 2009 1:21 pm Post subject: radio noise |
I was flying my plane last weekend. I noticed I had a lot of radio noise. was flying with two other planes. They said radio transmission was garbled. I started experimenting turning off electronic things one at a time. Found out my GPS was the culprit. A Garmin 195. My radio is a Icom IC-A22. Anyone have any suggestions?
KITFOXZ(at)aol.com Guest
Posted: Sat Jun 13, 2009 4:54 pm Post subject: radio noise |
In a message dated 6/13/2009 5:23:25 P.M. Eastern Daylight Time, n3pupnc(at)aol.com writes:
Quote: | I was flying my plane last weekend. I noticed I had a lot of radio noise. was flying with two other planes. They said radio transmission was garbled. I started experimenting turning off electronic things one at a time. Found out my GPS was the culprit. A Garmin 195. My radio is a Icom IC-A22. Anyone have any suggestions? |
Hello 369PL,
I'll give you some ideas on what to take a look at. I will assume your avionics package was working well together at some point and now there are noise problems. Radio noise or interference comes into your radio from one of two sources, the antenna or the power supply.
As an avionics tech I know to tell you to always look at the power supply first. Get a digital volt meter from Radio Shack or from your local Lowes or home store. An expensive one is not necessary. Measure the voltage of your battery with the volt meter. Do this with the meter leads connected directly across the battery posts first, not the battery terminals but, the battery posts. A good reading with a fully charged battery is 12.5 to 13 VDC. Poor (corroded) battery terminal connections or a weak or bad battery could very likely be your whole problem.
Then, read the battery voltage with the engine running and the alternator online. Check the reading at several engine RPMs. You want to see the voltage remain consistent at about 13.8 to 14.0 VDC. Now read those voltages with the negative lead of the meter connected to the ship's ground (a good bare metal point on the fuselage) and the positive lead connected to the positive battery post. Use the engine block for the negative meter lead point next. What you are looking for is consistent voltage readings that will indicate that your ship is well bonded to the negative side of the battery.
Next read the voltage with the negative meter lead connected to your avionics common ground point or negative power bus. Read the voltage with the positive meter lead connected to the avionics positive power bus and the negative lead connected to the negative bus point and then check it with the negative lead connected to the battery negative post and then to the fuselage bare ground point. These reading should all be the same.
Read the voltage from the negative post of the battery to the bare fuselage ground point and next from the negative post of the battery to the engine block. This reading is made with either meter lead connected. Meter lead polarity is not a concern here, what you are checking for is to see that no voltage is measured between the negative post of the battery and any ground point. Ground bonding is very important and this reading is proof of it's integrity.
Finally, read the voltage with the positive meter lead connected to your radio's power connection point and the negative lead connected to the battery negative post and then to ground.
This reading could have been done first and would tell us a lot but, I just wanted you to be sure of all of your power system's critical readings first. The radio needs to see a solid 12.5 to 13.8 voltage measured across it's power input to be able to perform well and it needs to be well grounded. Take this reading with the radio keyed also and with the engine running at different RPMs.
Repeat these readings for the GPS receiver too. It is very likely that you have a poor ground for the GPS receiver or your radio.
Another approach is to do a blind "TEST AND SEE": Connect a jumper wire from the negative battery post to the chassis of your radio and next to your GPS's chassis. If the noise goes away, you will know the problem is improper grounding.
If the GPS receiver is not grounded well, it will become a source for radio interference noise that gets "received" by your radio's antenna input circuits. The same grounding problem for the radio can cause the radio receiver to "see" signals that are not really there because it's improper grounding makes it detect "ghost" signals. The radio needs a solid signal reference ground and a solid power ground to do it's thing well.
This has ended up being a bit long so check these readings out and then I can suggest some other things to look at. You could just simply have a bad GPS receiver too!
John
John P. Marzluf
Columbus, OHio
Outback (out back in the garage)
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
thesupe(at)hotmail.com Guest
Posted: Sat Jun 13, 2009 8:13 pm Post subject: radio noise |
A while back I rearanged things on the panel and had the GPS next to my handheld radio. I noticed noise on the radio also which quit if I shut the GPS off. Ended up moving the handheld over to my left which put them about 2' apart and the noise went away. Might be worth a try to get some distance between them. Take care C Jim Chuk Avids C Kitfox. Mn
Quote: | Subject: Kitfox-List: radio noise
Date: Sat C 13 Jun 2009 14:21:51 -0700
--> Kitfox-List message posted by: "369PL" <n3pupnc(at)aol.com>
http://forums.matronics.com/viewtopic.php?p=247978#247978
Lauren found her dream laptop. Find the PC that’s right for you.
Michel
Posted: Sat Jun 13, 2009 10:35 pm Post subject: radio noise |
And this is why we are asked to switch off all electronic instruments as we board an airliner. The GPS is only a receiver and shouldn't produce any radio frequency interferences. But any receiver with a malfunction can work as a sender.
By the way, I was wondering: Does your GPS have a Bluetooth port? Perhaps that's the problem. If so, can you disable it?
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
dave
Posted: Sun Jun 14, 2009 1:56 am Post subject: Re: radio noise |
I have a Garmin 196 on left side of dash and Icom handheld on right side. I only get RF issues when tuned around 119 area . I have to run the squelch at max .
I have no transmit or receive issues. You will always get some RF leakage from a GPS as they have a micro processor inside.
I see guys with troubles, poor wiring, bad grounds, poor connectors and cheap coax. That is 95 % of radio issues right there.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
pwmac(at)sisna.com Guest
Posted: Sun Jun 14, 2009 5:49 am Post subject: radio noise |
A few years ago on the Aeroelectric list there was a discussion as to
how far the GPS antenna should be from the radio antenna. My fabulous
memory indicates that 2' would eliminate any conflict. Of course for
hand held units is pretty easy to just move them apart. For panel
mounting hand helds be sure to keep them on separate ends of the
panel. Not every combination of different units will have conflict.
Example; in my truck I have a Lowrance powered remote GPS antenna
about 3" from my VHF antenna and have no conflict at all. I even have
a Serius antenna within 3" of both and all is well. In my truck
example the Lowrance head is mounted 2" from the VHF radio. Different
results for different units.
Paul
dave
Posted: Sun Jun 14, 2009 9:06 am Post subject: Re: radio noise |
Rf will come from processor in GPS . I only get a conflict around the 118 to 120 area. after that no issues. My antenna is mounted on turtle deck for radio and GPS antenna on dash.
Dave
Float Flyr
Posted: Sun Jun 14, 2009 3:24 pm Post subject: radio noise |
GPS units have a microprocessor a possible source of RFI (Radio Frequency
Interference) They also have LCD screens or TFT screens which can certainly
cause a lot of RFI noise at very close range.
Most of the airlines ask you to turn off for two reasons... one is some of
the planes are fly by wire and the other reason is they get a royalty every
time you use their sat phone. Generally speaking computers which are now ok
are a lot noisier than phones or radio receivers which they also don't want
to see.... the excuse there is that the IF frequency will interfere with
nav and com systems... they never mention that almost every flight
something minor goes wrong on the flight deck and they don't want you to
start a panic behind them.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
MDKitfox(at)aol.com Guest
Posted: Sun Jun 14, 2009 6:19 pm Post subject: radio noise |
On Jun 14, 2009, at 9:53 PM, Noel wrote:
start a panic behind them. |
Noel,
Everything you said was alright until this point, but really, I flew RJ's (lots of electronics - EFIS, MFD, EICAS, etc.) for years and I had very few flights where anything went wrong. I'm not sure where you got the stats from, but they seem skewed. BTW, we didn't have Sat phones so royalties weren't an issue for us, I think you may be right about that one.
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
= [quote][b]
369PL
Posted: Mon Jun 15, 2009 3:26 am Post subject: Re: radio noise |
I flew my plane yesterday for a about 30 min. I used batteries in the gps instead of the 12v plane power. I had no noise. I then unhooked the batteries and plugged back into the plane and still no noise. I guess I have a intermitten problem. My gps does not have a bluetooth. I checked the voltage with the gps it says 9.6 my volt meeter says 12.9 the volt meeter on the dash says almost 14. I have noticed that when I run my stobes my engine temp jumps up about 20 degrees (indicated not actual). I have a grey head 582. with a key west rectifier. How much joltage should I have. I will will take my cowl off this week and check the ground connection as suggested.
Thanks guys for the suggestions
Warren
Float Flyr
Posted: Mon Jun 15, 2009 5:11 am Post subject: radio noise |
That actually came from the days when after every trans-Atlantic flight there would be several jugs on the huge 28 cylinder engines replaced. They used to say you could tell who the AME at the airport was... he always drove the biggest car! So much overtime replacing jugs. Years ago there was a guy who used to fly a connie from England to Canada as a freighter. On one trip in mid Atlantic he lost one engine. Rather than feathering the blades and dragging it the rest of the way. He didn’t think he had the fuel to make it anywhere with his load, he fined the pitch and caused the prop to over rev until for lack of oil the engine seized and tore itself off the plane. He then landed in Gander and had the engine, mount, cowling etc. replaced.
The other point is what you as a pilot could consider a standard operating procedure, a passenger who is on their first flight, could get worried about. Even ATC communications can be misinterpreted as a problem and create anxiety in the cabin. I remember talking to an aircraft maintenance instructor about his first flight in a BAE 146. When the tucked the gear he thought the side was coming out of the plane... it was worse when the gear was dropped! All that was normal but if it caused a seasoned maintenance engineer some concern imagine what it would do to some guy who heard on his pocket radio the plane sent for a go around because of wind shear!
When I studied aircraft maintenance we had one young fellow in our class that you couldn’t crowbar into a plane to go for a flight. He ended up joining the Canadian military and now he has to fly...not only that he has to fly on planes he is responsible for... Looks good on him J
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Weiss Richard
Sent: 14 June 2009 11:49 PM
Subject: Re: RE: radio noise
Noel,
Rick Weiss
SkyStar S/N 1
Port Orange, FL
= Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
Float Flyr
Posted: Mon Jun 15, 2009 6:22 am Post subject: radio noise |
13.8V.
Due to the limited output of the alternator (around 16A or 220 Watts) I'm a
bit surprised about the temperature increase while running your strobes. If
you turn the strobes off how long does it take for your temperature to come
down again? Do you experience any loss of rpm?
Noel
Kitfox III-A
akflyer
Posted: Mon Jun 15, 2009 8:46 am Post subject: Re: radio noise |
sounds more and more like a bad ground to me. The temp jumping when you hit the strobes is a pretty good indicator, and the noise going away when you unplugged then plugged the GPS back in would suggest a loose connection or possible broken wire.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
369PL
Posted: Mon Jun 15, 2009 5:39 pm Post subject: Re: radio noise |
Noel.
The temp drops as soon as you tune the switch off. It raises as soon as you turn it on.It does the same with the position lights and the cabin heater. The rpms stay constant.
Warren
Float Flyr
Posted: Mon Jun 15, 2009 7:02 pm Post subject: radio noise |
Sounds like a problem with the temp gauge... is it a standard thermocouple?
( unpowered)
Noel
Kitfox III-A
dave
Posted: Tue Jun 16, 2009 1:57 am Post subject: Re: radio noise |
Warren,
Different GPS use different voltages. So will regulate voltage themselves. MY Garmin 196 uses 4 AA batteries = 6V . but will take power 10 to 40 V .
If you getting noise through your power you got other issues.
Try moving a handheld radio near your GPS with both turned out through differnt freq. You will find some RFI/ EMI causes some noise.
DAve
369PL wrote: | I flew my plane yesterday for a about 30 min. I used batteries in the gps instead of the 12v plane power. I had no noise. I then unhooked the batteries and plugged back into the plane and still no noise. I guess I have a intermitten problem. My gps does not have a bluetooth. I checked the voltage with the gps it says 9.6 my volt meeter says 12.9 the volt meeter on the dash says almost 14. I have noticed that when I run my stobes my engine temp jumps up about 20 degrees (indicated not actual). I have a grey head 582. with a key west rectifier. How much joltage should I have. I will will take my cowl off this week and check the ground connection as suggested.
Warren |
Posted: Tue Jun 16, 2009 2:52 am Post subject: radio noise |
In a message dated 6/15/2009 7:27:58 A.M. Eastern Daylight Time, n3pupnc(at)aol.com writes:
Quote: | I flew my plane yesterday for a about 30 min. I used batteries in the gps instead of the 12v plane power. I had no noise. I then unhooked the batteries and plugged back into the plane and still no noise. I guess I have a intermitten problem. My gps does not have a bluetooth. I checked the voltage with the gps it says 9.6 my volt meeter says 12.9 the volt meeter on the dash says almost 14. I have noticed that when I run my stobes my engine temp jumps up about 20 degrees (indicated not actual). I have a grey head 582. with a key west rectifier. How much joltage should I have. I will will take my cowl off this week and check the ground connection as suggested.
Warren |
Warren,
Some GPS receivers have the capability of reading out their own power supply voltage. It sounds like yours has 6 dry cell batteries that will total a nominal 9 volts, 9.6 volts is a good reading with all batteries up to snuff. On external (ship's) power your GPS may be able to accept a wide range of voltage input, say from 6 to 40 volts. Check your owner's manual.
I am thinking that you may simply have a weak (soft) ship's battery. Load test your battery or replace it if it is more than two years old. Or substitute a known good battery for test purposes. If your battery is 100% known to be in good shape, take a look at the voltage readings I suggested in an earlier post. Your ship's power bus or your grounding is possibly not good enough to handle the loads you are requiring from it.
Look for good, tight, corrosion free, connections made with the correct size wire, etc.
Put a digital volt meter across your avionics bus to ground and watch the voltage as you turn on and off all of your panel items. This voltage reading must remain constant and above 12 volts under all loads. If it does not, you don't have enough battery capacity or enough good conductor capacity to your panel's equipment.
John
An0126575x1221823265x1201398681/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JuneExcfooterNO62>See Yours in Just 2 Easy Steps!
