paul perry
Posted: Sun Jul 12, 2009 5:07 am Post subject: Kreem Problem Again |
I have a KFIV speedster (purchased from orig builder about a yr ago) completed in 2001, and have discovered the "kreem" is coming off in at least the right side tank. I also have the mil-h-6000 fuel lines so I am going to replace those even though on initial inspection they appear to be ok. I'm not sure about the left tank, it looks ok from what I can see, but I'm going to try to come up with a "mini-webcam" to visually inspect the inside of the tank. I have read as many of the posts on these subjects as I could find, but most were going back several years, so I would like to ask the following:
1) Which is the better solvent for the Kreem, MEK or acetone?
2) Approx how long(solvent in contact with kreem) does it take to dissolve (talking minutes, hours or days?) 3) Has anyone successfully re-sloshed a tank after it had been in use for several years?
Thanks to everyone who posts on this forum, as it has been very helpful!
Paul Perry
Bloomfield, MO pperryrph(at)sbcglobal.net
Roger Lee
Posted: Sun Jul 12, 2009 5:57 am Post subject: Re: Kreem Problem Again |
Hi Paul,
MEK not acetone. You will not dissolve the Kreem. It is meant to stand up to most all fluids or it wouldn't be any good. Sounds like some one didn't do a good job of pre-cleaning or sloshing the tank the first time. It should not peal or flake.
Get as much of the loose Kreem out as possible. Use the MEK to clean the tank, but it is not necessary to leave it in long periods and depending on the tank material might be harmful to do so. You can re-slosh your tank with out any problems. Just do a good job of sloshing and rotating the tank. Do it at least three times in one day. Rotate slowly and completely.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Fox5flyer Guest
Posted: Sun Jul 12, 2009 6:42 am Post subject: Kreem Problem Again |
I agree with Roger, but will just add a couple things. First, Acetone will
work, but not near as well as MEK. Kreem is MEK based, but more expensive
than acetone and not as easy to find. If you can find MEK it will make the
job easier, but keep it away from your paint job.
Also, when you re-slosh (recommended), I would advise diluting the Kreem
50/50 with MEK. Kreem as it comes from the can is quite thick and difficult
to cover the whole inside of the tank without having thick spots, which you
don't want. By diluting it, it covers the whole inside of the tank easily
and makes it much easier to pour out the what isn't needed.
Good luck,
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 425+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jul 12, 2009 8:44 am Post subject: Kreem Problem Again |
Like Deke, I agree with most, but I tend to disagree on the MEK vs Acetone
issue. After reading this thread, I went to the hangar and poured a little
Kreem in a cup and added some Acetone. It thinned it just like MEK would.
I also ran a small test to see if it would remove the Kreem from some small
parts I had. It did. So as far as the MEK and Acetone question, the choice
is yours - in my opinion. If you want to check to make sure, fish a couple
of flakes of the Kreem from the tank and soak it in a small amount of
acetone to see what happens.
I resloshed one tank in the mid life of my Model IV and used Acetone to
clean out the old Kreem. The primary reason I used acetone was cost. I
could tell the Kreem rinsed out by the color of the several rinses getting
less white, and the absense of white color on the surface of the tank
interior. Put plugs in all tank outlets and keep in mind that while
removing the Kreem (at least with acetone) a slight pressure will be built
up and you will want to vent the tank a couple of times with each rinse.
Cover top and bottom of the tank with plastic attached carefully with
masking tape to protect the surface as Deke mentioned.
It will take at least two of you to do the rinse and sloshing and preferably
big guys. Those wings are heavy when holding them and moving them around to
get the Kreem out and resloshing. It would help to have some sort of stand
to put the wing on to rest your arms from time to time.
I think I used about three gallons of Acetone in three separate rinses.
One last thought, I made a gimbal device that attached to the outboard end
of the wing that was attached to castored stand. This stand supported the
wing for easy removal and then allowed for one end of the wing to be
supported as it was sloshed. I still have the gimbal and would be happy to
send it to you if you think it would help - the stand became a work bench.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Covering
Paul A. Franz, P.E.
Posted: Sun Jul 12, 2009 10:15 am Post subject: Kreem Problem Again |
On Sun, July 12, 2009 6:07 am, pperrynas wrote:
| Quote: | 1) Which is the better solvent for the Kreem, MEK or acetone?
MEK - methyl ethyl ketone is probably a little better as regards to saturation and
hence is a little faster acting than acetone and should require fewer slosh, rinse
drain cycles than acetone. Prolonged MEK exposure to some composites can cause
swelling and softening. MEK is probably at least twice the unit cost of acetone but
should require about a third less. Now here is the real kicker - MEK is very toxic and
exposure effects are cumulative. One should not breathe any vapors and it passes right
through your bare skin into your bloodstream. You can die from a single exposure
event. You must be very careful using it and have a safety plan. MEK is very flammable
too and the flames are totally invisible. Acetone is less flammable but still it
presents a risk.
| Quote: | 2) Approx how long(solvent in contact with kreem) does it take to dissolve (talking
Both MEK and acetone start to soften and dissolve the kreem surface immediately. The
one time I watched the process was on aluminum tanks with rivet construction. The
tanks were going to be modified for more capacity. The tank size started at 11 gallons
and was expanded to 17 gallons. The tanks were removed from the wing, openings sealed
and first flushed with under a quart of MEK for 5 to 10 minutes of rotation then left
to sit about 20 minutes or so then rotated again for 5 minutes after opening to the
fill cap to release the pressure. That process exposed the cap seal to MEK and it
began to leak. Then the tank was drained and I was surprised that what was drained out
was about the thickness of latex wall paint. The process would have continued but by
now the tank filler cap gasket was totally destroyed and a temporary fix had to be
done to continue. The solution was a leather gasket made from an old work shoe. The
second rinse was repeated with close to a quart and a half of MEK and the drainage was
not thick and the inside of the aluminum tank looked pretty clean with sort of a
frosting everywhere and a tiny bit of kreem remaining at the edge of some of the
rivets but it might have been liquid there too. The third rinse was with about a pint
of MEK and that was done for three sessions of rotating at least 5 minutes and a rest
of 1 to 20 minutes. There was nearly nothing discoloring the drained MEK and the
inside of the tanks appeared shiny clean.
After the tanks were opened, welded and rivets added they were resloshed and the
result appears to be permanent.
I don't know if you could follow this same procedure with fiberglass tanks or not.
Might have to not soak them so long. At the time I saw this done, I was not aware of
the level of toxicity of MEK although I used some kind of plastic gloves and a
respirator when I helped. I didn't get any on my skin but I sure got to know the smell
of it. Painters using MEK use a forced fresh air supply piped into their clothes so
they get zero exposure to it.
I was lead to believe that even though the MEK was more expensive, you needed less and
the dissolving time was faster. I don't know from experience though.
| Quote: | 2) Has anyone
I have no experience with fiberglass tanks at all. It's sure been reported to occur
plenty of times over the years on this mail list though.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
"To take from one, because it is thought his own industry and that
of his fathers has acquired too much, in order to spare to others,
who, or whose fathers, have not exercised equal industry and
skill, is to violate arbitrarily the first principle of
association, the guarantee to everyone the free exercise of his
industry and the fruits acquired by it."
-- Thomas Jefferson
"We maintain our strength in order to deter and defend against aggression -- to
preserve freedom and peace. Since the dawn of the atomic age, we've sought to
reduce the risk of war by maintaining a strong deterrent and by seeking genuine
arms control. 'Deterrence' means simply this: making sure any adversary who
thinks about attacking the United States, or our allies, or our vital
interests, concludes that the risks to him outweigh any potential gains. Once
he understands that, he won't attack. We maintain the peace through our
strength; weakness only invites aggression."
-- Ronald Reagan
Americans are not a perfect people, but we are called to a perfect mission.
--Andrew Jackson
It's passionately interesting for me that the things that I learned in a
small town, in a very modest home, are just the things that I believe
have won the election.
-- Margaret Thatcher
The planter, the farmer, the mechanic, and the laborer... form the
great body of the people of the United States, they are the bone and
sinew of the country men who love liberty and desire nothing but
equal rights and equal laws.
-- Andrew Jackson
"The Founding Fathers established a system which meant a radical
break from that which preceded it. A written constitution would
provide a permanent form of government, limited in scope, but
effective in providing both liberty and order. Government was not
to be a matter of self-appointed rulers, governing by whim or harsh
ideology. It was not to be government by the strongest or for the
few. Our principles were revolutionary. We began as a small, weak
republic. But we survived. Our example inspired others, imperfectly
at times, but it inspired them nevertheless. This constitutional
republic, conceived in liberty and dedicated to the proposition
that all men are created equal, prospered and grew strong. To this
day, America is still the abiding alternative to tyranny. That is
our purpose in the world -- nothing more and nothing less."
-- Ronald Reagan
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Fox5flyer Guest
Posted: Sun Jul 12, 2009 11:38 am Post subject: Kreem Problem Again |
Good post Paul. Do you have any documentation that MEK is toxic, or at
least any more than Acetone? I haven't been able to find anything other
than anecdotal. No, I don't plan on making any mixed drinks with it, but
I've smelled a lot of that stuff and I'm still here. Then again, I don't
let any more get on my skin that I have to. Just being cautious.
Deke Morisse
Mikado Michigan
- Joseph Joubert
<paul(at)eucleides.com>
clip clip
saturation and
slosh, rinse
cause
acetone but
very toxic and
passes right
exposure
very flammable
still it
presents a risk.
Paul A. Franz, P.E.
Posted: Sun Jul 12, 2009 1:41 pm Post subject: Kreem Problem Again |
On Sun, July 12, 2009 12:29 pm, fox5flyer wrote:
than anecdotal.
No, other than the allegation that there have been cases of a toxic shock nature that
were fatal.
| Quote: | No, I don't plan on making any mixed drinks with it, but
MEK is regarded by PNL (Battelle, Richland) to have significant exposure risk as
compared to acetone.
I did not refer to any MSDS for my posting and should have as Lowell has pointed out.
Paul A. Franz
Bellevue WA
"In Washington, one person's waste is another person's pork. Every
dime spent by the federal government has well-connected advocates
who swear the money is vital to the national interest. ... It's not
that people in government aren't as good or competent as those in
the private sector (though that may be true). The difference lies in
the incentives and feedback they face. Bureaucracies have little
check on what they do, no bottom line, no market prices for their
'output.' What they do have is an incentive to spend all the money
budgeted or risk getting less next year. As Milton Friedman used to
say, no one spends other people's money as carefully as he spends
his own. It is absurd to think the humongous constellation of
federal bureaucracies is going to identify and root out 'waste' in
any significant way. It's just not in the nature of the beast."
-- ABC's "20/20" co-anchor John Stossel
Plan your work for today and every day, then work your plan.
Bellevue WA
425.241.1618 Cell
MDKitfox(at)aol.com Guest
Posted: Sun Jul 12, 2009 1:58 pm Post subject: Kreem Problem Again |
Here's an MSDS link for MEK. It's not a friendly chemical, but handled properly it's okay.
Just wear protective gloves and safety glasses (in case of it splashes) and you should be fine.
http://www.jtbaker.com/msds/englishhtml/m4628.htm
Rick Weiss
N39RW Series V Speedster, 912ULS
SkyStar S/N 1
Port Orange, FL
On Jul 12, 2009, at 5:30 PM, Paul Franz - Merlin GT wrote:
[quote]--> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com (paul(at)eucleides.com)>
| Quote: | --> Kitfox-List message posted by: "fox5flyer" <fox5flyer(at)idealwifi.net (fox5flyer(at)idealwifi.net)>
than anecdotal.
were fatal.
Paul A. Franz
Bellevue WA
Plan your work for today an================================================-= -->
KITFOXZ(at)aol.com Guest
Posted: Sun Jul 12, 2009 5:33 pm Post subject: Kreem Problem Again |
I think MEK is the best choice for cleaning Kreem coated tanks simply because of the fact that Kreem is MEK based.
However, listen up!
I believe MEK killed my brother. Please use MEK with all reasonable protective measures available. Do not breath the stuff, get it on your skin or expose your eyes to it's vapors.
I have written about this death to the list in the past. MEK causes permanent damage to the brain, nervous system, kidneys, eyes and liver. These warnings are right on the MEK container.
My brother Tom was a licensed A&P mechanic. He chose to overlook all of the warnings and used MEK almost daily without protecting himself. He said: "You don't even smell the stuff after awhile". He loved the superior solvent that it is and used it to soak engine fuel injection system parts in. I can still picture him pouring a few gallons of the stuff in the parts washing tub and scrubbing fuel injectors with a brush and his bare hands. He'd hook up an injector to pressure with MEK as a medium and watch the perfect conical spray pattern in the bright light. He enjoyed doing the typical hanger rash repairs to aircraft by wet sanding wing tips, wheel pants etc. with MEK. He did a final wipe down with an MEK soaked rag, mixed the paint with MEK for thinning and sprayed on the paint. He had all of the hanger exhaust fans running and thought the concentrations that he exposed himself to were small.
At the end of his day he would wash the grease out of his hands and finger nails with a wash up session at the parts washing tank. He used to laugh at my concerns that he should use more caution. He was just 29 years old and a pretty cocky but, very talented guy. Pretty bull headed!
Tom's work was stressfull much of the time. He had to be right with his troubleshooting and quick with emergency repairs. Aircraft owners want things done yesterday. Tom began to experience heart burn problems and indigestion pains. The human liver produces enzymes for digestion. No one saw it coming. I told him to stop eating the beanie weinnies out of the machine in the hanger. I told him to take time to eat a balanced meal. The pain persisted and his gut began to swell. I teased him about too much beer even though he drank little of it.
Inside of two years time he was dead from liver failure. His death came on the morning of his 30th birthday June 19, 1992. His only daughter graduated from high school this year, 2009. She is a straight A student and beautiful. I wish she had known her daddy. He was a terrific guy!
No autopsy was performed due to the shock that the whole family was in. His doctor told me MEK was the likely culprit.
People can smoke their entire lives and not get lung cancer. You can lay in the sun for days and not get skin cancer. You can use MEK to slosh your tanks and not damage your eyes or liver. Tom saturated himself with the stuff. For me, I think I'll use a pressurized fresh air supply mask and gloves.
John P. Marzluf
Outback 912S
Columbus, Ohio
In a message dated 7/12/2009 2:16:02 P.M. Eastern Daylight Time, paul(at)eucleides.com writes:
| Quote: | --> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com>
| Quote: | --> Kitfox-List message posted by: "pperrynas" <pperryrph(at)sbcglobal.net>
clip clip
presents a risk.
Paul A. Franz
Bellevue WA
-- Thomas Jefferson
-- Ronald Reagan
--Andrew Jackson
-- Andrew Jackson
-- Ronald ===============================================
_-= the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
paul perry
Posted: Sun Jul 12, 2009 5:43 pm Post subject: Re: Kreem Problem Again |
I want to thank everyone who has responded to my questions as the input has been very helpful. I checked the msds sheets on both acetone and the mek and they were very similar..both rate the health risks as a "2" . I checked Lowes website and they show mek in 5gal for $99 and acetone in 1 gal for $16.98, so if they actually have them in the stores for those prices, there isn't much difference as far as cost. Again, thanks to everyone, but if someone else has personal experience with this type problem, please go ahead and reply as I will take all the advice I can get.
Paul P.
Lynn Matteson
Posted: Mon Jul 13, 2009 2:57 am Post subject: Kreem Problem Again |
Personal experience based on advice from the former head honcho at
the former Kitfox builder, Skystar: I had 12-year old tanks that
WERE NEVER USED, but had been Kreeme'd.
I rinsed both (13-gallon wing tanks)...already installed in the
wings, by the way... with acetone, using 3 gallons in the process,
until the final application of acetone came out nearly clear. I
diluted the Kreeme with MEK as suggested, but not sure of exact
ratio, and applied by rotation. That was about 4 years ago. I've been
flying with 100LL for the past three-plus years, and no sign of any
flaking, peeling, or any other type of loss of the Kreeme.
Note: I followed the instructions on the can of Kreeme to the
letter, but did NOT use the tank prep material the the can
instructions refer to, just the acetone for the cleaning.
Lynn Matteson
Jabiru 2200, #2062, 701.3 hrs
Sensenich 62"x46" Wood prop
Status: flying
On Jul 12, 2009, at 9:43 PM, pperrynas wrote:
go ahead and reply and will take all the advice I can get.
Paul P.
http://forums.matronics.com/viewtopic.php?p 52734#252734
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
napierm(at)cisco.com Guest
Posted: Mon Jul 13, 2009 9:42 am Post subject: Kreem Problem Again |
Hi Paul,
I re-sloshed my left tank a couple of years back because it was leaking.
1st step was to spray on a water based masking compound onto nearby
areas of the wing to prevent damaging the paint.
Next was to make a simple jig to raise up the wing with ropes so I could
be sure that the new Kreem coated the inboard and outboard walls.
I rinsed the tank with acetone until it ran mostly clear. It still has
some white in it.
Last was to use the Kreem un-thinned, a lot of it. I got two quart
sized cans directly from Kreem. It's on their web site. Most all came
back out afterwards. Overkill but at least it worked -> the leak was
gone.
I just left the regular gas cap on for the rinse and the slosh and
cleaned up later.
The new Kreem *is* different from what was used in 1992. I don't know
when the change happened. Trying to clean up the cap and a couple of
fittings after the Kreem set up for a few days was interesting. It
whitened a little but didn't dissolve like the old stuff. Not in
acetone, MEK or denatured alcohol.
Now I have a different problem. I want to make my tanks alcohol-proof
and don't know how to do it short of buying new tanks from Kitfox. Not
sure if any of the tank sealing products are really up to it. There are
internal surfaces in the tank that will never be reached by a sloshing
operation so to do it right would mean taking the top off of the tank
and coating it inside with something. What that something is I don't
know.
Any one have some solid leads?
Mark Napier
Time: 07:00:32 AM PST US
Subject: Re: Kreem Problem Again
Hi Paul,
up to most
good
peal
or flake.
tank,
tank
any problems.
three
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Service Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p 52639#252639
Lynn Matteson
Posted: Mon Jul 13, 2009 10:24 am Post subject: Kreem Problem Again |
No leads on an alcohol-proof sealer, but just curious about your
statement "There are internal surfaces in the tank that will never be
reached by a sloshing operation"....I'm not sure what you mean by
this. And if you took the top off the tank, how would you ever seal
the inside seam where you re-joined the tank top?
All this worry about resisting the alcohol in mogas makes me wonder
why people don't bite the bullet and use 100LL....it's safe,
convenient to airports, doesn't eat through (most) fuel tanks, and
until they do, it's the fuel that the Feds haven't mucked around
with...YET! I'm not rich, but I'd rather pay the little extra for
100LL, and FLY, rather than putz around with fuel tank problems.
Lynn Matteson
Status: flying
On Jul 13, 2009, at 1:30 PM, Mark Napier (napierm) wrote:
<napierm(at)cisco.com>
Hi Paul,
(snip)
| Quote: | Now I have a different problem. I want to make my tanks alcohol-proof
Not
There are
know.
Mark Napier
N369LM |
vadert(at)shaw.ca Guest
Posted: Mon Jul 13, 2009 10:59 am Post subject: Kreem Problem Again |
Mark
6nbsp;
I used this product E 6nbsp; I phoned Caswell 6nbsp;and they assured me that it was ethanol resistant E 6nbsp; Methanol C they weren 7t so sure about E
6nbsp;
http://www Ecaswellplating Ecom/aids/epoxygas Ehtm
6nbsp;
Tim Vader
Kitfox 6nbsp;IV
GPASC 6nbsp;VW
patreilly43(at)hotmail.co Guest
Posted: Mon Jul 13, 2009 12:03 pm Post subject: Kreem Problem Again |
Lynn C What is your Oshkosh schedule? do not archive
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Re: Kreem Problem Again
Date: Mon C 13 Jul 2009 14:22:20 -0400
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
No leads on an alcohol-proof sealer C but just curious about your
this. And if you took the top off the tank C how would you ever seal
why people don't bite the bullet and use 100LL....it's safe C
convenient to airports C doesn't eat through (most) fuel tanks C and
until they do C it's the fuel that the Feds haven't mucked around
with...YET! I'm not rich C but I'd rather pay the little extra for
100LL C and FLY C rather than putz around with fuel tank problems.
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 701.3 hrs
Status: flying
On Jul 13 C 2009 C at 1:30 PM C Mark Napier (napierm) wrote:
> --> Kitfox-List message posted by: "Mark Napier (napierm)"
> Hi Paul C
(snip)
> Not
> There are
> know.
> Thanks C
> Mark Napier
Posted: Mon Jul 13, 2009 1:50 pm Post subject: Kreem Problem Again |
This subject is very timely for me. I was planning on covering the left
wing soon and my tanks are 1992 vintage with vintage Kreem. I guess I
should be thinking of a re-do of the liner to a more up to date version. I
was very tempted to try the epoxy liner that Tim used and did a bit of
looking and found a discussion board where one guy used it and if flaked -
metal tank and definitely not our issue - but the point of his post was that
he can't find anything that will remove it. He's looking at new tanks.
Then, the application of the epoxy liner requires total removal of Kreem
with a paint remover type compound after the Acetone/MEK treatment and like
Paul I my tanks are in a flying configuration with lots of effort to reslosh
and get the liner everywhere - been there done that once already!
The permanence of the phenol novolac epoxy is interesting to me because I
like to think anything on my airplane is serviceable to some extent. I
suppose that surface preperation is what caused the flaking on the metal
tank but the multistep prep on my already Kreemed tanks gives me pause
because if my prep is not perfect, I am looking at two entire wing rebuilds.
I need some input - encouragement or discouragement - Any wisdom would be
appreciated at this point.
Lowell Fitt
Cameron Park, CA
Covering
Posted: Mon Jul 13, 2009 2:26 pm Post subject: Kreem Problem Again |
Lowell C If it was me C and my wing wasn't covered C I would attempt to secure tanks that didn't require Kreem or similar coating. I had an experience with a streetrod C 47 Ford coupe C that I built using the original tank that I had Kreemed. The tank prep was probably lacking I will admit. But the Kreem let go in big flakes that didn't pass through the pickup tube so that none was picked up in the filters. I thought I had a vaporlock problem because the fuel line did run closer to the exhaust than I wanted. It took me a long C long time to realize that the pickup tube was being blocked intermitently by big pieces of Kreem. I now have a brand new plastic rotomolded tank in that car. I swore I'd never use Kreem again. I'll bite the bullet and purchase new tanks for any projects in the future C and that includes aircraft projects. That's just me though.
P.S. Got the bush gear completely mounted with wheels and on the ground. I need to make some cuffs at fuselage. That gear sure looks good on a KF. I never thought Grove gear looked period correct on a KF and am glad I didn't purchase it prior to your development of bush gear. And C thanks for desigining that fairing set up C absolutely beautiful! Your suggestion of using a 4x30 tap to align the fairing worked as described. I only had to use it on 4 or 5 holes so your apology was not warrented. I don't think the fairing holes could have been aligned any better. I will post pictures of the plane in a couple of weeks.
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
[quote] From: lcfitt(at)sbcglobal.net
Date: Mon C 13 Jul 2009 14:45:04 -0700
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Then C the application of the epoxy liner requires total removal of Kreem
because if my prep is not perfect C I am looking at two entire wing rebuilds.
Lowell Fitt
Cameron Park C CA
Covering
Lynn Matteson
Posted: Mon Jul 13, 2009 2:43 pm Post subject: Kreem Problem Again |
I'm probably going to leave here on Sat or Sun, the weekend before
they open, and stay for 4-5 days. I like to get there before the good
spots in homebuilt camping are all gone. By good spots, that means
close to the showers/johns, but more importantly the ICE!
Lynn Matteson
Jabiru 2200, #2062, 702 hrs
Status: flying
On Jul 13, 2009, at 3:59 PM, patrick reilly wrote:
| Quote: | Lynn, What is your Oshkosh schedule? do not archive
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Date: Mon, 13 Jul 2009 14:22:20 -0400
> To: kitfox-list(at)matronics.com
never be
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Electroair direct-fire ignition system
> Status: flying
> > Hi Paul,
> (snip)
proof
> > Not
> > There are
sloshing
the tank
don't
> > know.
> > Thanks,
> > Mark Napier
============================================================ _-
contribution_-
N369LM |
Lynn Matteson
Posted: Mon Jul 13, 2009 3:26 pm Post subject: Kreem Problem Again |
Lowell-
My tanks were January 1994 vintage, and Frank Miller suggested that I
slosh out the old Kreeme and *install* a fresh coating. I had already
glued the tanks into the wings, so I had to rotate the entire wing on
the jig, AND turn it end-for-end...by myself....so it can be done.
This was no small feat with a 12-foot wing and an 11-foot 10-inch or
so, ceiling. It was cold weather here, and you don't have that
problem. : )
Lynn Matteson
Status: flying
On Jul 13, 2009, at 5:45 PM, Lowell Fitt wrote:
left wing soon and my tanks are 1992 vintage with vintage Kreem. I
guess I should be thinking of a re-do of the liner to a more up to
date version. I was very tempted to try the epoxy liner that Tim
used and did a bit of looking and found a discussion board where
one guy used it and if flaked - metal tank and definitely not our
issue - but the point of his post was that he can't find anything
that will remove it. He's looking at new tanks. Then, the
application of the epoxy liner requires total removal of Kreem with
like Paul I my tanks are in a flying configuration with lots of
effort to reslosh and get the liner everywhere - been there done
that once already!
because I like to think anything on my airplane is serviceable to
some extent. I suppose that surface preperation is what caused the
flaking on the metal tank but the multistep prep on my already
Kreemed tanks gives me pause because if my prep is not perfect, I
would be appreciated at this point.
Lowell Fitt
Cameron Park, CA
Covering
N369LM |
Lynn Matteson
Posted: Mon Jul 13, 2009 3:37 pm Post subject: Kreem Problem Again |
Just like sex, preparation is everything, Patrick.....maybe you
didn't talk sweet enough to that hot rod tank. : )
Lynn Matteson
Status: flying
On Jul 13, 2009, at 6:23 PM, patrick reilly wrote:
| Quote: | The tank prep was probably lacking I will admit.
N369LM |
