Door Strap Location
jeff(at)westcottpress.com
PostPosted: Fri Jul 17, 2009 2:12 pm    Post subject: Door Strap Location Reply with quote
I'm considering a leather strap to pull the door closed... appx 1'
long running along the lower inside edge of the door. The ideal
location for this strap would be both reachable and result in the door
pulling in evenly (fore and aft) when held in the center. It seems to
me that that could be one of two locations... centered in the length
of the door or centered on a line drawn down between the two hinge
points. Does anyone flying have a feel for where that might be?
Jeff Carpenter
40304
partner14
PostPosted: Fri Jul 17, 2009 6:53 pm    Post subject: Door Strap Location Reply with quote
I looked quite a few places and finally found these at an $8.98 store in Roseville Ca. They were perfect, and only $1.98. I cut them to length, and then had them sew up. They work perfect.... so nice to be able to just reach up and close the door.
Don McDonald
#40636 - 55 hours FLYING
--- On Fri, 7/17/09, Jeff Carpenter <jeff(at)westcottpress.com> wrote:
Subject: Door Strap Location
Date: Friday, July 17, 2009, 3:04 PM
--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)>
I'm considering a leather strap to pull the door closed... appx 1' long running along the lower inside edge of the door. The ideal location for this strap would be both reachable and result in the door pulling in evenly (fore and aft) when held in the center. It seems to me that that could be one of two locations... centered in the length of the door or centered on a line drawn down between the two hinge points. Does anyone flying have a feel for where that might be?
Jeff Carpenteonics.com/Navigator?RV10-List" target=_blank>http://www.matronics.com/Nav - MATRONICS WEB A href="http://www.matronics.com/contribution" target=_blank>http://www=======================
 Filesize:  352.42 KB
 Viewed:  1624 Time(s)
 Filesize:  129.58 KB
Don A. McDonald
40636
