Posted: Mon Jul 20, 2009 11:36 am Post subject: Autopilots vs. "The Right Stuff" |
At 09:04 AM 7/20/2009, you wrote:
Good Morning 'Lectric Bob,
Interesting thoughts from Doctor Dee.
It brings me to question if my strong advocacy of the T&B over the TC
might be some evidence of my personal conditioning.
It also leads me to think that maybe I am right in my feelings and
that the quandary we find ourselves in when we get confused about
which way is up is caused by that lack of consistency in our perceptions
Sooo .... I have already added another thing for me to worry about! <G>
The debate for visual display of yaw rate and
apparent center of the earth (gravity) as
a flight instrument is only slightly related to
the task of providing a practical automatic
flight control system. For a simple yaw damper
to work, it needs only numerical knowledge of
turning rate about the yaw axis.
However, given that the process of turning the airplane
to a new heading BEGINS with a change in roll
followed by a change in yaw rate. Doing the job
smoothly with a single rate sensor required some
knowledge of both roll (to anticipate a heading
change) and yaw (to quantify the rate of change
after the turn was established).
While the T&B may well be best suited to recovering
from an upset condition, the TC is best suited for
avoiding that upset in the first place. I.e, Brittain
could not have achieved the design goal without a
carefully considered "pollution" of TB data.
Not sure where you were working at the time or how close you were to
automatic flight, but I bet you know about how Beech competed with
Mooney's PC.
Only vaguely. I'll have to ask some of the grey-beards
if they recall the system. I guess I could get on
the computer and check service parts catalogs. I think
Beech listed their A/P hardware in those books.
Beech installed a Century I (The folks who made it were called Edo
Aire Mitchell at the time) Wing Leveler and my memory is that they
called it the Constant Copilot. The main difference was that Beech
provided an ON/OFF switch so the pilot could choose to use it or not.
My recollection is that Piper offered a similar unit, but I do not
recall who made it for them or what they called it.
I believe Piper had the Brittian system too but
featured a valve in the vacuum supply line to
shut if off if wanted. I think that valve was
added to the Mooneys later.
Back to the Constant Copilot.
If the switch was left on, the wing leveler worked full time just
like the Mooney PC. It could be easily over ridden without causing
any damage to the unit and it was made inoperative by pressing an
interrupter switch on the control wheel. Take your thumb off the
switch button and the leveler took over.
We always told our customers to use it regularly.
Almost nobody did!
Yeah, the "Right Stuff" syndrome. I guess it
depends on what you use the airplane for and
how you assess risk for the situations in which
you fly. I enjoy flying. I enjoyed honing my
under-the-hood skills. But when it was necessary
to competently and smoothly manage a transition
though IMC, I've never been adverse to calling
up what ever support was available to reduce both
sweat and risk.
I've run the traps with some fellow techo-wiennies
here in Wichita for a roll servo that contains
a dedicated GPS receiver, canted roll/yaw rate
sensor and a micro-controller that will "hold that
GPS track" to plus/minus 1 degree. Controls would
be limited to an on/off switch and bi-directional
track increment buttons. Click one for each degree
of track change. Hold button for standard rate turn.
The servo would have a serial port that accepts
commands for "new track to make good". The same
line outputs system status. As a single installation,
you install a servo, hook up an antenna, hook up
14v and you're done. As a dual installation, there
would be a "arbitrator box" that compares data
to and from the pair of wing levelers with data from
a panel mounted GPS and raises a warning flag if
one of the systems mis-behaves. Each system is
powered from a separate source.
It's my belief that such a system would allow a
pilot to comfortably enter a controlled airspace
environment and comply with all ATC instructions
with great precision, low risk and very low
sweat factor . . . and never have to touch the
stick. E.g. cluttering the panel with attitude
displays would add nothing to the design goal.
Bill of materials for the full-up system is under
$200. All I need is a 36 hour day and a relaxation
of other duties!
Bob. . .
BobsV35B(at)aol.com Guest
Posted: Mon Jul 20, 2009 12:24 pm Post subject: Autopilots vs. "The Right Stuff" |
Good Afternoon 'Lectric Bob,
I totally agree with you that the canted gyro works better for a wing leveler than does a T&B, but I do NOT feel it works well with we human pilots. Too much conflict with our semi circular canal sensors. But I have expanded on that thought here many times in the past.
I would love to see something new and modern that would replace the T&B and the TC. Your thought on using a sequential GPS position seems to me to have considerable merit.
Happy Skies,
Old Bob
LL22
Piper Pacer N2858P
In a message dated 7/20/2009 2:37:45 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | Bill of materials for the full-up system is under
of other duties!
Bob. . .
What's for dinner tonight? Find quick and easy dinner ideas for any occasion.
mprather(at)spro.net Guest
Posted: Mon Jul 20, 2009 12:57 pm Post subject: Autopilots vs. "The Right Stuff" |
Modern autopilots are remarkably better performers than their elder
parents.. The P3 Orion had an autopilot which had a component with a
limited operating life.. Crews would often hand fly en route to and from
their station in order to improve the odds that the autopilot would work
during a critical period.
My only personal experience with autopilots is in late 70's Archers which
I think had a rebadged Century III. They do the job (track a nav source),
but sloppily. They tend to wander heading a fair amount and if the rudder
trim isn't spot-on they can see-saw back and forth. In a flight regime
with low indicated airspeed (climb or high altitude cruise) the increased
adverse yaw makes the ride somewhat unpleasant and is kind of distracting.
Especially in an airplane with fairly strong roll-yaw coupling. If that
were the state of the art for autopilots, I'd be much less excited about
having one.
My impression is that the modern autopilots are much, much better.
Although, I did get a ride in the right seat of a PC12.. At cruise (in
the low FL's) in smooth air the airplane tended to slowly vary altitude
+/-100ft from the programmed value. Seemed a bit odd in a brand new
(30TTSN) multi-million dollar machine. Probably just needed a bit of
tuning.
Finally, pilots need to train like they fly, and fly like they train.
Pilots need to let George fly enough so that they have confidence in "his"
abilities.
Matt-
<nuckolls.bob(at)aeroelectric.com>
snip
jbr79r(at)yahoo.com Guest
Posted: Mon Jul 20, 2009 1:25 pm Post subject: Autopilots vs. "The Right Stuff" |
We have something better than T&B or TC. It's call glass panels with pictorial displays that the mind doesn't have to do much to interpret Strong visual information .
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Monday, July 20, 2009 2:17:26 PM
Subject: Re: Autopilots vs. "The Right Stuff"
Happy Skies,
Old Bob
LL22
Piper Pacer N2858P
of other duties!
Bob. . .
Posted: Mon Jul 20, 2009 3:18 pm Post subject: Autopilots vs. "The Right Stuff" |
Good Evening James,
I sure hope something works out along that line, but suitable reliability and usability has not yet been demonstrated.
Glass is also way out of my price range at the present time. The TC and T&B have been fairly economical in the past, though the prices have skyrocketed in the last couple of years. Do you figure on two glass units to provide back up or are you willing to go with a single source of information? I kinda like Jim Younkin's instrument for experimental aircraft. We who fly certified antiques are not allowed to use Jim's stuff.
Happy Skies,
Old Bob
In a message dated 7/20/2009 4:26:37 P.M. Central Daylight Time, jbr79r(at)yahoo.com writes:
| Quote: | We have something better than T&B or TC. It's call glass panels with pictorial displays that the mind doesn't have to do much to interpret Strong visual information .
James Robinson
Glasair lll N79R
Spanish Fork UT U77 |
An Excellent21323041x1201367261/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JulyExcfooterNO62>See Yours in Just 2 Easy Steps!
Bruce(at)glasair.org Guest
Posted: Mon Jul 20, 2009 3:36 pm Post subject: Autopilots vs. "The Right Stuff" |
Hi Jim,
It’s been proven time and time again that you’re better off using a backup system that uses a different method of operation when your panel goes dark.
Bruce
www.Glasair.org
Posted: Mon Jul 20, 2009 4:40 pm Post subject: Autopilots vs. "The Right Stuff" |
I have the trutrak auto pilot and it has been very dependable. Also the support has be very good. I fly with 2 screen Cheltons with some round gauges as backup and a AOA. I am all electric with a 2 alternator setup. It definitely ups the ante however
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Monday, July 20, 2009 5:15:07 PM
Good Evening James,
Happy Skies,
Old Bob
James Robinson
Glasair lll N79R
[b]An [quote][b]
I have backup round gauges and auto pilot and AOA to help me out
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Monday, July 20, 2009 5:32:14 PM
Subject: RE: Autopilots vs. "The Right Stuff"
Hi Jim,
Bruce
www.Glasair.org
Posted: Mon Jul 20, 2009 7:38 pm Post subject: Autopilots vs. "The Right Stuff" |
At 03:17 PM 7/20/2009, you wrote:
| Quote: | Good Afternoon 'Lectric Bob,
I would love to see something new and modern that would replace the T&B and the TC. Your thought on using a sequential GPS position seems to me to have considerable merit. |
Stabilization and control of the airframe is
still based on interpretation of rotational
rate values. The sensors are now all solid
state as opposed to spinning up a rotor
on bearings. The rate sensors have become
so commonplace that simple versions are offered
to augment pilot controls for flying model
r/c helicopters . . . and they're just a
few dollars.
http://tinyurl.com/lcuqkc
Two more technologies have come forward to make
the job easier and better. GPS and microprocessors.
Our first autopilot for the MQM-107
http://www.designation-systems.net/dusrm/m-107.html
was totally analog. 741 op amps and fists full of
transistors. The next autopilot was a TI 9900
processor. All of a sudden, our calculating
ability combined with differentiation (anticipation)
made this bird fly even better yet.
We never got to put GPS on this bird but it went
into other products.
http://tinyurl.com/lhwmnp
The availability of ground track nav data opened
the horizons for auto flight AND auto navigation.
The thing that would be pretty cool with the products
I described is access to the serial data ports.
The stand-alone device would nicely steer an
airplane. But anyone handy with byte thrashing
could craft an auto-navigation application in the
portable number cruncher of their choice.
( -Thomas Paine 1776- )
raymondj(at)frontiernet.n Guest
Posted: Mon Jul 20, 2009 8:10 pm Post subject: Autopilots vs. "The Right Stuff" |
I recall hearing that the solid state sensors (gyros) had a problem with
drift. Is this still an issue?
Raymond Julian
Kettle River, MN
"Hope for the best, but prepare for the worst"
few dollars.
* http://tinyurl.com/lcuqkc*
* http://tinyurl.com/lhwmnp*
mjpereira68(at)gmail.com Guest
Posted: Tue Jul 21, 2009 12:27 am Post subject: Autopilots vs. "The Right Stuff" |
The cheap ones like the above don't work that well (although it will
still make the tail human controllable during helicopter aerobatics).
The quality futaba products aren't that cheap. The difference between
the quality and cheaper products are how much drift in yaw they allow
under normal circumstances and how that effect varies based on input
voltage variance and temperature variance and how well the gyro deals
with vibration. The expensive ones perform better in other ways that
matter in a rc helicopter but aren't needed in a wing leveler
environment (which would be levels of magnitude less demanding).
If i'm not mistaken Futaba actually produces their own sensors which
implies to me that signal conditioning commercial off the shelf
sensors must not be easy in demanding situations.
Then again you talk about gps input so with proper software you could
continually calibrate what signal from the gyro means "zero yaw" (or
any other yaw rate). The thing is if you're going to do that it might
just be as easy to buy a quality gps chipset and calculate for bank
angle based on ground speed and turning radius (like the Garmin 396
and later do on their instrument page). Without the gps input or
alternately a 3-axis compass input it would be difficult to not have
the autopilot (using whatever sensors are in the cheaper rc heli
gyros) continually command a very slow (yet highly annoying) turn.
c'ya,
Michael
Posted: Tue Jul 21, 2009 5:14 am Post subject: Autopilots vs. "The Right Stuff" |
Good Morning Michael,
Great information for an old guy like me that is still struggling with Ohms Law!
May I interject a few thoughts though?
This new technology is certain to provide us with excellent autopilots and situational awareness instrumentation. The advancements in technology are mind boggling. Anything we purchase becomes obsolete before the ink is dry on the check.
That is all to the good and I love to see it happening.
Back to the world of application.
The first time Wilbur, Orville or Glenn had difficulty establishing their reference to the natural horizon, folks realized that some instrumentation would be required to allow safe flight when visibility was reduced.
The principles of the gyroscope were well understood and it was not long before various adaptations were applied to aircraft control.
At the same time, the Wrights and other pioneers realized that there was benefit to building aerodynamic stability into their flying machines. As an aside, the Wrights had initially thought that the machine needed to be built with almost neutral stability in order for it to be controllable. The reason they never rebuilt the original Wright Flyer, but went on to another design is because their flights on December 17, 1903 taught them that the Flyer was not stable enough for practical flight.
By the end of World War One, the concept of making the airplane dynamically stable and using a gyroscope to tell the pilot he/she was turning was well established. Monster ship's gyroscopes were too expensive and too heavy for practical airborne use, but a simple gyroscope hooked to some sort of an indicator that could tell the pilot the craft was turning was light weight and cheap enough that it became common equipment. Most of those units used a needle of some sort to tell the pilot what was happening. Many of the ones developed by European interests had the needle hinged at the top. Most that were developed on our side of the pond had the needle hinged at the bottom.
By using the Turn needle to keep any turning force to a minimum and by learning the idiosyncrasies of Magnetic Compass precession during turns, it became practical to fly in cloud. Not easy, but doable.
By the end of WW I the shape of future instrumentation was quite evident.
They had learned that if you stop the turn, you will survive!
Since coordinated flight was found to be advantageous, a simple inclinometer was added to the flight panel to display the degree of coordination being used. By the beginning of WWII, most turn instruments had that ball included within the same instrument case.
Gyroscopes that showed an artificial horizon were developed, but they tended to be very heavy, very expensive, very delicate and not at all reliable if their mechanical limitations were exceeded.
During the late twenties and early thirties, instrument flight became a practical endeavor. The Turn and Bank was the main thing used to allow the pilots to perceive a turning moment and the built in stability of the aircraft was such that it was relatively easy to evaluate the pitch and speed of the aircraft by the response of the airspeed indicator and the altimeter.
Thus we had Needle, Ball, and Airspeed IFR flight.
By the time WWII came along, the artificial horizons had gotten cheap enough and light enough such that they were fitted to most airliners and many larger military aircraft. Sure made for easier and smoother flight operations.
Notice that, thus far, we were still relying primarily on a human being to supply the motion need to position the controls?
Efforts had been made to build machinery that would perform that function, but was not yet well developed.
Since this dissertation is getting way too long for an avionics list, fast forward to today.
We now have almost unlimited calculating capability and there seems to be no reason why the human even needs to be involved other than as a mechanism to monitor what the electrons are doing. Given sufficient computing power, there is no doubt in my mind that it is relatively easy to make a machine that has a lower failure rate than do we mere humans.
So, I guess the question is, how much do we want humans to be involved?
Happy Skies,
Old Bob
LL22
Stearman N3977A
In a message dated 7/21/2009 3:28:15 A.M. Central Daylight Time, mjpereira68(at)gmail.com writes:
c'ya,
Michael
Posted: Tue Jul 21, 2009 5:23 am Post subject: Autopilots vs. "The Right Stuff" |
At 03:05 AM 7/21/2009, you wrote:
<mjpereira68(at)gmail.com>
The citation of this particular part was not intended to
suggest suitability to any task, only to illustrate the
advancements in micro-electronics for the sensing of physical
phenomena. Certainly there are moderately priced, solid state
rate sensors that may be better suited to the task of
crafting a flight augmentation system for a manned aircraft.
But even the best sensors have offset gain and temperature
coefficient errors that must be considered as part of the
overall error budget. The neat thing about teaming these devices
with micro-controllers is the ability to compare sensor outputs
with other, more stable data sources and deduce those errors
for the purposes of reducing/eliminating their effects.
For example, we could take the least expensive of
rate sensors combined with a GPS receiver and artfully
crafted software that would allow the autopilot to go through
some gentle maneuvers, compare expected GPS data with real
data and calculate new offset and gain values for the
as-installed rate sensor. Tailoring an autopilot
to a specific airframe and its installation is a tedious
and exacting process. However, for the simple heading-hold
wing leveler, a freshly installed system could be placed in
a temporary calibration mode and flown at altitude while
allowing the autopilot to wiggle the controls and deduce
appropriate gain and offset values for ALL of the as-installed
hardware. Once the calibration sequence is completed, a
switch is moved from the CAL to the FLY position and the
processor stores all the new values for operation.
If the el-cheeso rate sensor exhibits some degree of
long term drift, the CAL process can be repeated at
the owner's convenience to trim up system performance
at any time. Further, cross checking against GPS data,
allows small values of drift to be deduced on-the-fly
and accounted for. FAA rules for software qualification
would make such conveniences very difficult in a TC aircraft.
As I suggested in an earlier post, the availability
and capability of inexpensive GPS engines, micro-controllers
and low-cost rate sensors is head-and-shoulders above
those components which were the best we knew how to do
30 years ago.
Posted: Tue Jul 21, 2009 5:24 am Post subject: Autopilots vs. "The Right Stuff" |
At 10:58 PM 7/20/2009, you wrote:
with drift. Is this still an issue?
You betcha! But it's slow and can be accommodated
in software. See companion posting.
mjpereira68(at)GMAIL.COM Guest
Posted: Tue Jul 21, 2009 6:22 am Post subject: Autopilots vs. "The Right Stuff" |
On Tue, Jul 21, 2009 at 6:21 AM, Robert L. Nuckolls,
III<nuckolls.bob(at)aeroelectric.com> wrote:
Oh i agree with everything you've said. I think you'd have to manage
without a specific calibration routine however, it's something that
would have to run constantly (and that's assuming the quality
gyro/rate sensor).
The thing with the cheesy sensors as applied to the rc heli gyros is
the drift varies from minute to minute requiring constant trim
adjustments to the tail channel so it'll sit (relatively) still while
the stick is at neutral. Now, the problem could be more related to
crummy software than the sensor itself. No way to know in this kind of
black box situation what components are generating what percentage of
the total error.
Whatever the case is with the cheesy gyros, futaba has it nailed with
their more expensive stuff. Their tech is probably good enough for
the cockpit (at least in general aviation). The drift errors are
small, that has to make writing the calibration software easier. They
probably aren't crazy enough to license it to that market considering
the market size/liability issues though.
| Quote: | As I suggested in an earlier post, the availability
30 years ago.
So i'm curious. I've read a bit about 3-axis electronic compasses
(basically the 3d allows the device to automatically compensate for
magnetic tilt errors). If these devices are accurate enough and update
fast enough, could one of these alone drive a simple wing leveler ?
ie. change in heading divided by time equals rate of turn, etc. Well
actually, I guess it would act nuts if you were operating close enough
to one of the magnetic poles, nevermind. lol.
c'ya,
Michael
Posted: Tue Jul 21, 2009 7:30 am Post subject: Autopilots vs. "The Right Stuff" |
gyro/rate sensor).
Sure, with the GPS engine data we can resolve slow, short term
drifts and compensate on-the-fly. The larger calibration
corrections would probably be a one-time thing that would
wash out initial offset, gains and mechanism transfer
functions.
| Quote: | The thing with the cheesy sensors as applied to the rc heli gyros is
the total error.
We would probably not choose to get THAT cheesy. There's a host
of rate sensors offered by the micro-machined chip manufacturers
with very useable drift characteristics.
| Quote: | Whatever the case is with the cheesy gyros, futaba has it nailed with
Wouldn't seek a "license" . . . there are plenty of
commercial, off-the-shelf devices to choose from that
have no more liability for airplanes falling out of the
sky than do the nail manufacturer's have to shoulder for
houses falling down.
| Quote: | > As I suggested in an earlier post, the availability
> 30 years ago.
They're interesting devices and we looked at them several
times at the Beech/RAC Targets division. Problem is that
there are 3 conditions of orientation where these devices
fall out of bed. That's when any one of the three axes are
exactly aligned with earth magnetic flux lines. Under that
condition, the other two axes see the same data no matter
how the device is rotated about that axis. While these
may be transient conditions, they offered enough risk to
operation of the fully aerobatic target that we rejected
their incorporation into the product.
It may be that one could use them with more confidence
where the design goal is not to recover from an unusual attitude
but to keep from getting into an unusual attitude.
skywagon
Posted: Tue Jul 21, 2009 7:43 am Post subject: Autopilots vs. "The Right Stuff" |
Great review......
Dave
jaybannist(at)cs.com Guest
Posted: Tue Jul 21, 2009 8:48 am Post subject: Autopilots vs. "The Right Stuff" |
Yes, with the wondrous capabilities and reliability of today's computer controlled machines, be assured that nothing can go wrong...go wrong...go wrong....go........
I seem to recall reading about several accidents caused by the erroneous actions of computer controlled servo systems; actions that couldn't be detected nor corrected by the pilots. Admittedly, these were the result of faulty assumptions being built into the computer's database by humans. I guess it comes down to "who (or what) do you trust?"
Jay
echristley(at)nc.rr.com Guest
Posted: Tue Jul 21, 2009 5:14 pm Post subject: Autopilots vs. "The Right Stuff" |
BobsV35B(at)aol.com wrote:
| Quote: | Good Morning Michael,
Law!
on the check.
You still write checks? Don't you know that technology have made them
obsolete? 8*)
<snip>
I didn't get a pilot's license so that a machine could fly me around. 8*)
http://www.ernest.isa-geek.org
Posted: Tue Jul 21, 2009 5:43 pm Post subject: Autopilots vs. "The Right Stuff" |
Good Evening Ernest,
May I take it from that statement that you prefer a Boeing over an Airbus?
I repeat: The question is, how much do we want humans to be involved?
Happy Skies,
Old Bob
In a message dated 7/21/2009 8:16:03 P.M. Central Daylight Time, echristley(at)nc.rr.com writes:
| Quote: | I didn't get a pilot's license so that a machine could fly me around. 8*)
