Canopy weather stripping
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith650-List
lwinger
PostPosted: Tue Jul 21, 2009 10:41 am    Post subject: Canopy weather stripping Reply with quote
What have you used (or seen in use) for sealing between two areas: (1) the canopy front edge to the forward top skin, and (2) between the two rear "hoops" in addition to the flashing?
- The Matronics Zenith650-List Email Forum -
http://www.matronics.com/Navigator?Zenith650-List
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
larry(at)macsmachine.com
PostPosted: Tue Jul 21, 2009 11:55 am    Post subject: Canopy weather stripping Reply with quote
Larry,
I've seen one HD with just a trim strip on the fuselage forward top skin
that provided a good fit and cushion for the bare edge of the canopy. I
used the typical 3/4-inch
rubber edge with a slot for the canopy and glued it a drop at a time
1-inch spacing with crazy glue to keep the stuff inside the slot. Both
these systems work well.
Neither needed the flashing with such a good fit between canopy and skin.
Larry Winger
Tustin, CA
Fuselage on gear
Canopy nearly complete
http://forums.matronics.com/viewtopic.php?p 54152#254152
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith650-List All times are GMT - 8 Hours
