deej(at)deej.net Guest
Posted: Wed Jul 22, 2009 7:09 am Post subject: differences in fuses versus circuit breakers |
Hi Bob,
For the 12v/24v DC circuits typically used in our aircraft, is there
any difference in the rating one would select if using a fuse versus a
circuit breaker? In other words, a hypothetical example, if one arrived
at a value of 15 amps to protect a wire, would a 15 amp fuse be
interchangeable with a 15 amp circuit breaker for protecting the wire?
I ask for two reasons - in a discussion on another mailing list,
someone has said that fuses and circuit breakers of the same rated value
are not interchangeable, and AC43.13-1B table 11-3 on page 11-15 in
Section 4 shows a 15 amp CB or a 10 amp fuse to protect a 16 gauge
copper wire (picture attached).
If there is a difference, do you know and can you explain in simple
terms why?
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ
http://deej.net/sportsman/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
95.43 KB |
1550 Time(s) |
Posted: Wed Jul 22, 2009 5:40 pm Post subject: differences in fuses versus circuit breakers |
On 7/22/2009 7:25 PM, Robert L. Nuckolls, III wrote:
| Quote: | For our purposes, breakers and fuses are size-for-size interchangeable.
Thanks!
-Dj
