crvsecretary
Joined: 18 Mar 2007 Posts: 38 Location: Naugatuck, CT
Posted: Fri Aug 07, 2009 8:45 am Post subject: 601 to 650....is it worth it? |
Quote: | Hello Everyone:
Like everyone else, I have been reading about the tests and trials of our beloved homebuilt of choice and have taken note of the 650 series released by Zenith. All of this has
resulted in a self-imposed condition of 'builders paralysis'...I've done nothing for a very long time ! I'm about 1/2 way through the right wing with the tail feathers complete.
After looking through the list of 601 to 650 'improvements', I just cannot see through the advantages - or the possibilities - of incorporating these improvements into my airplane.
The new canopy is a no-brainer and is designed to retrofit - that's a good thing. But some changes - such as the angle of incidence - are just not possible or practical...yes?
What does the consensus think? My thoughts are to continue building the wings but NOT closing them up until well after recommendations are issued by Zenith,
and to order the 601 fuselage kit with the 650 canopy. My thoughts are that's the limit of 'improvements' I can make without some serious rework of my completed items.
Anyone care to share their thoughts?
Thank You in advance
Tracy Smith
N458XL (reserved) - Corvair powered
Naugatuck, CT
_________________ Zenith 601XL N458XL (reserved)
Naugatuck, CT
Tail Complete; working on wings |
z601a(at)anemicaardvark.c Guest
Posted: Fri Aug 07, 2009 9:10 am Post subject: 601 to 650....is it worth it? |
On Friday 07 August 2009 11:42, crvsecretary(at)aol.com wrote:
Quote: | Like everyone else, I have been reading about the tests and trials of our
by Zenith. All of this has resulted in a self-imposed condition of
I'm still chugging along. I figure this stuff will get resolved somehow or other. As Chris Heintz pointed out, most of the accidents have been people who did not build their planes. That suggests familiarity reduces the probability of difficulty when flying - a rather obvious statement, but perhaps more true in this case than in many.
Quote: | After looking through the list of 601 to 650 'improvements', I just cannot
improvements into my airplane. The new canopy is a no-brainer and is
I cannot see any obvious merit to the 650 improvements in my application. True, the new canopy gives more headroom, but it does so at the expense of the baggage compartment. If I had the 650 canopy, my baggage would rub against, and no doubt scar, the canopy. But to each his own.
Quote: | What does the consensus think? My thoughts are to continue building the
by Zenith, and to order the 601 fuselage kit with the 650 canopy. My
I find myself wondering if we will in fact see any meaningful recommendations from Zenith. That being the case, I'm sealing things as I go. This may prove to be a mistake, but without a firmer indication of the exact problem, just adding structure or balancing things seems to me to be grasping at straws. Zenith may be forced to do that for political reasons, but that's solving a problem of a different sort.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
============================================= [quote][b]
PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Fri Aug 07, 2009 9:12 am Post subject: Re: 601 to 650....is it worth it? |
Biggest reason would be for perception/reputation/resale value.
You'd probably do better selling an airplane registered as a "650" than you would one registered as an "XL", even through they are the same airplane.
Try this experiment: next time you're with a group of pilots, mention the XL. Likely somebody in that group will chime in about wing issues. Then ask that person what they think about the 650...
I should add that I'm comfortable enough that the "issues" have been mitigated that I am forging on ahead with my project am and looking forward to flying it.
- Pat
lwinger
Posted: Fri Aug 07, 2009 9:38 am Post subject: 601 to 650....is it worth it? |
Tracy,
I was working on the fuselage when the 650 became available. Because I am 6'6", making the shift to the 650 canopy was a given. I also liked the new latch system. Because I had done everything to that point based upon the 601XL angle of incidence, I elected not to change that, but incorporated virtually every other modification offered by the 650 (including remaking my rudder).
From what I have heard, the 650 baggage tunnel is a bear to make because of the compound curves. The 650 has no such curves and is a snap to build. On the other hand, everyone who has done both the 601XL and the 650 canopy has told me that the 650 canopy is harder to install. Splitting the canopy adds a whole new level of complexity, which I now completely understand. Having said that, if you are going with the 650 canopy, I would strongly advise you to build the 650 top rear structure that goes with it, so you don't get the worst of both worlds (difficult 601XL baggage tunnel and difficult 650 canopy).
In reality, there aren't that many parts that distinguish the 601XL from the 650 in the areas of the rear bulkheads/rear top skin and baggage floor. In order to avoid converting a 601XL baggage tunnel into a 650 canopy system, I would swap out the 601XL middle and baggage back bulkheads, rear top skin and baggage floor for the 650 counterparts, and then enjoy the benefits of a clean 650 install. If you'd like more details on the specific items that are different, feel free to contact me off line.
Just my 2 cents worth. Have fun, whichever way you go.
Larry Winger
650/Corvair
Canopy 99% finished
Tustin, CA
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
Gig Giacona
Posted: Fri Aug 07, 2009 10:05 am Post subject: Re: 601 to 650....is it worth it? |
Keep one big thing in mind if you are thinking of making the switch.
The 601 kits both quick and slow build are grandfathered in under the old 51% list. The 650 isn't on that list.
The good news is the FAA has backed off of their original plan which was very complex and would be hit or miss and would have certainly effected the quick build kits.
The bad news is the new version of the rule was just announced at OSH and really hasn't been vetted yet.
That said if you want the changes of the 650 there is noting in the world stopping you from calling it a 601XL.
601XL Under Construction
William Dominguez
Posted: Fri Aug 07, 2009 11:14 am Post subject: 601 to 650....is it worth it? |
See my comments in bold.
William Dominguez
Zodiac 601XL Plans
Miami Florida
http://sites.google.com/site/billplane/
From: "crvsecretary(at)aol.com" <crvsecretary(at)aol.com>
Sent: Friday, August 7, 2009 12:42:58 PM
Subject: 601 to 650....is it worth it?
Quote: | Hello Everyone:Like everyone else, I have been reading about the tests and trials of our beloved homebuilt of choice and have taken note of the 650 series released by Zenith. All of this hasresulted in a self-imposed condition of 'builders paralysis'...I've done nothing for a very long time ! I'm about 1/2 way through the right wing with the tail feathers complete. I haven't stopped working, I believe that if a modification is provided, it would be retro-fitable to a finished plane. Keep in mind that I'm building from plans so my progressis slower than kit builders.
After looking through the list of 601 to 650 'improvements', I just cannot see through the advantages - or the possibilities - of incorporating these improvements into my airplane. The new canopy is a no-brainer and is designed to retrofit - that's a good thing. But some changes - such as the angle of incidence - are just not possible or practical...yes?The canopy is an area where I'm also undecided so far. I like the 650 latching mechanism and the rollover bar but like the XL canopy in almost everything else. For a whileI have been considering putting the 601 XL canopy with the new latch and rollover bars. Adding the new latch to the 601 XL canopy would not be a problem but the rollover bars is another story.What does the consensus think? My thoughts are to continue building the wings but NOT closing them
up until well after recommendations are issued by Zenith,That is a good idea, postpone closing the wings as much as possible, but only as long as building continues with something else in the project. I wouldn't stop my project waiting for a recommendation or a mod.
Tracy Smith
Naugatuck, CT
_________________ William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom |
Gig Giacona
Posted: Fri Aug 07, 2009 12:03 pm Post subject: Re: 601 to 650....is it worth it? |
What comments?
William Dominguez wrote: | See my comments in bold.
William Dominguez
Zodiac 601XL Plans
Miami Florida |
psm(at)att.net Guest
Posted: Fri Aug 07, 2009 2:10 pm Post subject: 601 to 650....is it worth it? |
Hi Tracy,
If you are anything like me, by the time the changes are released
from Zenith you will have become a real expert at drilling out
rivets. So, My recommendation is to go ahead at your own pace and
complete things as you get to them.
Paul
XL waiting for engineering changes
At 09:42 AM 8/7/2009, you wrote:
Quote: | My thoughts are to continue building the wings but NOT closing them
Posted: Fri Aug 07, 2009 2:24 pm Post subject: 601 to 650....is it worth it? |
Tracy,
I'd recommend you continue work on your plane and consider the canopy
with a roll bar but not in separate pieces. The rear half of the canopy
would seem
to get in the way of access and egress. The latch is neat, much simpler.
I've finally got confidence in the old system having taken time to
clearly mark a lock
position, but if I were to do over, the new latch is a more secure method
Larry McFarland 601HDS at www.macsmachine.com (140.5 hours on Stratus
Subaru and Warp Drive)
Quote: | See my comments in bold.
William Dominguez
Zodiac 601XL Plans
Miami Florida
*From:* "crvsecretary(at)aol.com" <crvsecretary(at)aol.com>
*To:* zenith-list(at)matronics.com
*Sent:* Friday, August 7, 2009 12:42:58 PM
*Subject:* 601 to 650....is it worth it?
Hello Everyone:
Tracy Smith
Naugatuck, CT
Ron Lendon
Posted: Fri Aug 07, 2009 4:15 pm Post subject: Re: 601 to 650....is it worth it? |
Tracy,
I'm building to the plans marked CH 601 XL. I might call it something else when I register it, I am the manufacturer and can call it whatever I want.
The XL has been flow for quite sometime now and I really think it will be a good airplane for my mission.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
William Dominguez
Posted: Fri Aug 07, 2009 4:27 pm Post subject: Re: 601 to 650....is it worth it? |
They should come thru this time, at least I can now see them in the preview, if you still can't see them, try the forum view of the list.
William Dominguez
Gig Giacona wrote: | What comments?
William Dominguez
Zodiac 601XL Plans
Miami Florida |
Hello Everyone:
Like everyone else, I have been reading about the tests and trials of our beloved homebuilt of choice and have taken note of the 650 series released by Zenith. All of this has resulted in a self-imposed condition of 'builders paralysis'...I've done nothing for a very long time ! I'm about 1/2 way through the right wing with the tail feathers complete.
I haven't stopped working, I believe that if a modification is provided, it would be retro-fitable to a finished plane. Keep in mind that I'm building from plans so my progress is slower than kit builders.
The canopy is an area where I'm also undecided so far. I like the 650 latching mechanism and the rollover bar but like the XL canopy in almost everything else. For a while I have been considering putting the 601 XL canopy with the new latch and rollover bars. Adding the new latch to the 601 XL canopy would not be a problem but the rollover bars is another story.
Tracy Smith
Naugatuck, CT
Zodiac 601XL Plans
Miami Florida
William Dominguez
Posted: Fri Aug 07, 2009 4:31 pm Post subject: Re: 601 to 650....is it worth it? |
Let's see if it work now, my comments are in bold and italics.
William Dominguez
William Dominguez wrote: | They should come thru this time, at least I can now see them in the preview, if you still can't see them, try the forum view of the list.
William Dominguez
William Dominguez
Zodiac 601XL Plans
Miami Florida |
Hello Everyone:
Tracy Smith
Naugatuck, CT |
Zodiac 601XL Plans
Miami Florida
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Fri Aug 07, 2009 4:38 pm Post subject: 601 to 650....is it worth it? |
On Fri, Aug 07, 2009 at 05:31:29PM -0700, William Dominguez wrote:
Quote: | Let's see if it work now, my comments are in bold and italics.
Not everyone reads email in HTML.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
chuck960
Posted: Fri Aug 07, 2009 8:42 pm Post subject: Re: 601 to 650....is it worth it? |
Since I am building the 650 kit I feel qualified to throw in a penny or two.
I see little advantage to change the wing incidence if you already have 601 parts. The angle change of 2 degrees is to make it easier to see over the nose. You need different front side skins, the four parts that make up the seat bottom, arm rest, rear wing attachment parts and more. The canopy switch might be worth it though. I really like the way it looks. It depends on how deep your pockets are and how tall you are.
PatrickW
Posted: Mon Aug 10, 2009 7:12 am Post subject: Re: 601 to 650....is it worth it? |
Guys who are not of above-average height could go with the one-piece XL canopy, but with the 650 latch system.
That's the best of both worlds. The two-piece 650 canopy (that I went with) is a lot of work, but the 650 latch system isn't too bad.
I'm 6'3", and while I've flown in a number of traditional XL's, the additional head room that the 650 canopy provides is welcome. For tall guys it starts to matter if you're "tall torso'd" or "tall legged".
- Pat
