jeff(at)westcottpress.com Guest
Posted: Tue Aug 11, 2009 4:44 pm Post subject: Right Side Exterior Door Lock and Handle |
I'm considering leaving off the right side exterior door lock and door
handle. Any opinions?
Jeff Carpenter
40304
Futzing with the left side lock
gengrumpy(at)aol.com Guest
Posted: Tue Aug 11, 2009 4:49 pm Post subject: Right Side Exterior Door Lock and Handle |
You will regret not having it there once you get flying.....
grumpy
N184JM
On Aug 11, 2009, at 7:37 PM, Jeff Carpenter wrote:
door handle. Any opinions?
Jeff Carpenter
40304
dmaib@me.com
Posted: Tue Aug 11, 2009 5:12 pm Post subject: Right Side Exterior Door Lock and Handle |
I know of at least one other -10 that left off the exterior handle, but I am not sure why the builder made that decision. Easy access to both sides of the airplane is one of the improvements over Bonanza/Mooney/Piper airplanes in my opinion. Having said that, getting to do it the way you want it is also one of the great things about building your own!
David Maib
40559
Flying
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
-Mark Twain
On Aug 11, 2009, at 8:37 PM, Jeff Carpenter wrote:
--> RV10-List message posted by: Jeff Carpenter <jeff(at)westcottpress.com (jeff(at)westcottpress.com)>
I'm considering leaving off the right side exterior door lock and door handle. Any opinions?
Jeff Carpenter
40304
Futzing with the left side =====================
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics--> http://forums.matronics.com
- List Contribution Web Site -Matt Dralle, href="http://www.matronics.com/contribution">http://www.matronics.com/co===================
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Deems Davis
Jeff, I'm not sure how far along in your build you are. But heres' some
things to consider:
1. The RV10 is NOT an easy airplane to get into and out of the front
seats with 2 doors. With only one door and having to deal with the
center console it would only aggravate the situation.
2. Think of resale, you may decide that for you and the people that will
fly with you that it's not a big issue. If you keep your plane forever
that will work great, but I believe most folks would look at the lack of
a passenger entry/exit as a negative.
3. After you mount the doors (or the last time), you will necessarily
need to enter/exit the aircraft through the passenger side opening at
least 500 times. this could add more time to your build than you'd
potentially save by not installing them. Not having an external handle
on the outside WILL add time to the mounting and adjustment of the
doors, unless you leave the window out til the end.
Deems Davis # 406
'Its all done....Its just not put together'
http://deemsrv10.com/
Jeff Carpenter
40304
robin1(at)mrmoisture.com Guest
I agree, you will regret it once in service.
Robin
flysrv10(at)gmail.com Guest
Posted: Tue Aug 11, 2009 5:23 pm Post subject: Right Side Exterior Door Lock and Handle |
Nooooooo!
On Tue, Aug 11, 2009 at 8:37 PM, Jeff Carpenter<jeff(at)westcottpress.com> wrote:
Jeff Carpenter
40304
Rob Kermanj
Posted: Tue Aug 11, 2009 5:25 pm Post subject: Right Side Exterior Door Lock and Handle |
That'll work fine unless you need to help someone get in the pass side
... get in, reach over and unlatch door, get out and walk around to
help pass .....
But you'll go a little faster. <GR>
Linn
Jeff Carpenter
40304
AV8ORJWC
Posted: Tue Aug 11, 2009 6:39 pm Post subject: Right Side Exterior Door Lock and Handle |
In the event of a fire, one might reconsider that decision.
I would bet that the building of an amateur approved kit (VANS RV-10)
has some trigger mechanism at DAR interpreted alterations that could go
beyond the initial design and structure intent. I am not one to talk
when it comes to mods to the RV-10, but it sure starts the thoughts
flowing. Oh the thrill of Experiments.
I might bet that you won't go a whit faster than the guys with the flush
mounted handles but you might throw your main tire weight on the left
main tire an ounce or two heavier than the right main.
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Tue Aug 11, 2009 6:45 pm Post subject: Re: Right Side Exterior Door Lock and Handle |
In the last 3 months we have had 2 planes flip over on landing. One pilot extraction was a bit tricky. The lesson here is think about off-normal or accident scenarios. There may be times when you want someone to access the pass side real fast.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
Posted: Tue Aug 11, 2009 6:52 pm Post subject: Right Side Exterior Door Lock and Handle |
John Cox wrote:
I doubt there will be a rush to get inside!
Aw, c'mon .... at least a whit!
| Quote: | mounted handles but you might throw your main tire weight on the left
Oh, the missing handle will cause asymmetric drag ..... more left trim
.. and more drag ..... and there goes the whit! Sheesh.
Now let me get my tongue outta my cheek!
Linn ..... do not archive
partner14
Posted: Tue Aug 11, 2009 10:42 pm Post subject: Right Side Exterior Door Lock and Handle |
Dave, what the heck is going on there that would produce 2 seperate incidents like flipping planes over. Maybe I DON'T want to come visit the Plantation!
Don McDonald
--- On Tue, 8/11/09, nukeflyboy <flymoore(at)charter.net> wrote:
Subject: Re: Right Side Exterior Door Lock and Handle
Date: Tuesday, August 11, 2009, 7:45 PM
--> RV10-List message posted by: "nukeflyboy" <flymoore(at)charter.net (flymoore(at)charter.net)>
Dave Moore
RV-6 flying
RV-10 QB - cabin top/fiberglass hell
http://forums.matronics.com/sp; --> http://foru - List Contribution We -Matt Dralle, Listm/contribution" target=_blank>http://www.matronics.com/contribution
40636 |
Bob Turner
Posted: Wed Aug 12, 2009 10:08 am Post subject: Re: Right Side Exterior Door Lock and Handle |
All the Cessnas that I'm use to flying have an external lock only on the left door. You have to reach inside the cabin to unlock the right door.
I'm planning on following that model. e.g., right door will have an external handle but will lock internally (I'll get a pin into the interior door handle which will prevent the latch pin from being pushed in). Said pin to be removed while in flight (emergency access issue).
Yes, this means in the left side, then walk around to the right, to help passengers if needed. But I always get in first anyway, do pre-flight, etc., while passengers watch from the shade (or stay in shelter from rain and cold)!
Not yet flying so this is all theory!
_________________ Bob Turner
RV-10 QB |
