fprobst(at)HOTMAIL.COM Guest
Posted: Mon Aug 17, 2009 7:44 pm Post subject: check your rudder bearing |
The other day on my preflight I noticed a significant amount of play in the top rudder attach point of my 601. Then I was at a fly in over the weekend with several 601's and they all had some play. One was really bad and the rest had quite a bit of play too. The hinge is just a bushing running in aluminium. Mine has worn in just 100 hours.
Has anyone come up with a better bearing idea?
Frank Probst
Stay on top of things C check email from other accounts! Check it out. [quote][b]
JohnDRead(at)aol.com Guest
Posted: Mon Aug 17, 2009 8:12 pm Post subject: check your rudder bearing |
Hi Frank;
I did not like the steel in aluminum bearing design so I made the following redesign of all of the various pivot designs on my CH701. I did submit them to the factory who commented that they did not see any problems with the designs. I have attached the Rudder Pivot redesigns drawings. The advantage of the designs is that the existing 4130 bushings are running in "Oilite" type bearings and are many times longer than the original Zenith designs.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 8/17/2009 9:45:31 P.M. Mountain Daylight Time, fprobst(at)HOTMAIL.COM writes:
Quote: | The other day on my preflight I noticed a significant amount of play in the top rudder attach point of my 601. Then I was at a fly in over the weekend with several 601's and they all had some play. One was really bad and the rest had quite a bit of play too. The hinge is just a bushing running in aluminium. Mine has worn in just 100 hours.
Frank Probst
Stay on top of things, check email from other accounts! Check it out. |
Posted: Tue Aug 18, 2009 5:25 am Post subject: check your rudder bearing |
Frank,
I had the same issue last annual inspection and found the pin was not
snug on the bushing ends. I made another bushing just a tad longer and
it solved the problem.
The bushing has to be a tight fit between the angles or it will allow
motion to tear up the aluminum. I also added a little white lithium
grease on assembly.
Frank Probst
<http://go.microsoft.com/?linkid=9671350>
ggower_99(at)yahoo.com Guest
Posted: Thu Aug 27, 2009 8:14 am Post subject: check your rudder bearing |
A drop of oil every once in a while... At least every engine service.
I aply a drop of oil in all moving parts everytime I wash the airplane..
In harbor freight they sell a little one for less than 3 dls
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1106
Every flying day, with the preflight, at least I wash the widshield with plenty of water (avoid scratches) and clean the leading edges with rag and water.
All airplanes need a little love and care...
Saludos
Gary Gower
701 912S 250 hrs
building 601XL Jab 3300
--- On Mon, 8/17/09, Frank Probst <fprobst(at)HOTMAIL.COM> wrote:
Quote: |
Subject: check your rudder bearing
Date: Monday, August 17, 2009, 11:43 PM
#yiv1859061757 .hmmessage P { margin:0px;padding:0px;} #yiv1859061757 { font-size:10pt;font-family:Verdana;} The other day on my preflight I noticed a significant amount of play in the top rudder attach point of my 601. Then I was at a fly in over the weekend with several 601's and they all had some play. One was really bad and the rest had quite a bit of play too. The hinge is just a bushing running in aluminium. Mine has worn in just 100 hours.
Frank Probst
Stay on top of things, check email from other accounts! Check it out. Quote: |
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith-List
start: 0000-00-00 end: 0000-00-00 [quote][b]
jaybannist(at)cs.com Guest
Posted: Thu Aug 27, 2009 10:19 am Post subject: check your rudder bearing |
Gary,
I have been cautioned to avoid using oil on external control hinges and pivot points. The objection is that the oil will attract dust, which will accelerate wear. I have been advised to use the white powder lubricant made for locks.
Jay Bannister
