saolesen(at)sirentel.net Guest
Posted: Mon Aug 24, 2009 6:18 am Post subject: Power point presentation on LOP |
If anyone is interested there is a power point presentation by one of
the GAMI guys on LOP operations. It details where the problem ROP
and LOP temps are (the RED Box). The List won't accept the format so
email me off list for a copy.
Sheldon Olesen
N475PV 106 hours
Tim Olson
Posted: Mon Aug 24, 2009 7:17 am Post subject: Power point presentation on LOP |
Sheldon, if you can get me the link, I'll add it to the write-up
where people can grab it. I don't want to put the original file
in a public write-up though, because I've had my hand slapped once
for even posting a screenshot of a companies website.
Tim Olson - RV-10 N104CD
Sheldon Olesen wrote:
the GAMI guys on LOP operations. It details where the problem ROP and
LOP temps are (the RED Box). The List won't accept the format so email
Sheldon Olesen
N475PV 106 hours
Posted: Mon Aug 24, 2009 7:20 am Post subject: Power point presentation on LOP |
I'm interested. Thanks,
Linn
Sheldon Olesen
N475PV 106 hours
AV8ORJWC
Posted: Mon Aug 24, 2009 8:22 am Post subject: Power point presentation on LOP |
The powerpoint presentation on Tim's site would be great!
Taking the chance that I might be out of line with Tim and many of you
(What's new), I would like to point out one idea for consideration. FAR
43, Appendix D has as its last entry (j) as a catch all. You each might
ask your DAR if not doing Mag Timing at a Conditional is appropriate or
to be taken only cautiously before moving ahead. I have been instructed
that to maintain the TCDS on a Lycoming engine, it is the responsibility
of the repairman, mechanic to confirm the ignition system is providing
fire at the correct number of degrees from TDC. Almost all engines have
one systems a little off note. Klaus might have a perspective on this
idea. Some might assume it is the RV-10 owner's responsibility to
confirm correct ignition event prior to LOP ops or injector balancing
I do not subscribe to 10:1 compression as introducing a problem to
correctly maintained engines. Some people love 8.7:1. A TN
(turbo-normalized) GAMI engine does just fine when all the musical
instruments are playing the same sheet of music at the same timing i.e.
Cirrus G3.
On a separate note, I hope a few of you will join me in November as Don
graduates a handful of us in his Airflow Performance FI class. It is
held in beautiful Spartanburg, just after the passing of the '09
hurricane season.
Running LOP and fuel injector balancing begins with the perception that
all of the concentric circles are aligned by you the technician.
Compression, Spark, Valve movement, Atmospherics (density of air
mass/temp/humidity) and the correct Air:Fuel ratio (Peak =
Stoichiometric). As Deem's asked to bring it on, Kelly responded with
some sage advice.
There is good stuff there... Saving money, less carbon footprint and
knowledge of your respective system. Sheldon you are welcome to send it
my way.
Kelly McMullen
Posted: Mon Aug 24, 2009 1:38 pm Post subject: Power point presentation on LOP |
Yes, checking mag timing is a required task for an A&P/IA on a
certified plane for 100 hour or annual. As I understand it, a
repairman doing condition inspection must develop a checklist equal to
or in greater depth than Part 43 Appendix D, so I believe ignition
timing should be a requirement.
That said, the TIO540 in Mooney TLS/Bravo is one of the most difficult
engines around to run LOP. Symptoms indicate it is either the
pressurized Slick mags, or the combustion chamber design. Some will
run fine LOP, including one I know of, that as soon as one of the
Slick mags was overhauled, would no longer run LOP at all. On that
engine the mags often require overhaul in less than 500 hours.
They also tend to tear up exhaust systems when run LOP. Don't
understand that either, just what owners have experienced.
The Lycoming IO-540 is a very different engine than the IO550
Continental the Cirrus operates with, and stock compression is 8.5:1.
The TCM runs fine LOP. Not all Lyc IO-540s will.
On Mon, Aug 24, 2009 at 9:20 AM, John Cox<johnwcox(at)pacificnw.com> wrote:
Quote: | I do not subscribe to 10:1 compression as introducing a problem to
Cirrus G3.
A&P/IA, EAA Tech Counselor
KCHD |
speckter(at)comcast.net Guest
Posted: Mon Aug 24, 2009 3:57 pm Post subject: Power point presentation on LOP |
Speaking of condition inspections, does any one have a good checklist? I
have one I made up but it might be nice to cross check it.
Gary Specketer
billderou(at)yahoo.com Guest
Posted: Tue Aug 25, 2009 12:24 pm Post subject: Power point presentation on LOP |
Please send a copy.
--- On Mon, 8/24/09, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
Quote: |
Subject: Re: Power point presentation on LOP
Date: Monday, August 24, 2009, 7:55 AM
--> RV10-List message posted by: Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)>
Linn
Quote: | --> RV10-List message posted by: Sheldon Olesen <saolesen(at)sirentel.net (saolesen(at)sirentel.net)>
If anyone is interested there is a power point presentation by one of the GAMI guys on LOP operations. It details where the problem ROP and LOP temps are (the RED Box). The List won't accept the format so email me off list for a copy.
Sheldon Olesen
N475PV 106 hours
sp; --> http://foru - List Contribution Web Site -
_; &nbef="http://www.matronics.com/contribution" target=_blank>http://www.mat=====================
| [quote][b]
